- Oct 9, 2007
- 46,390 (7.68/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Although liquid Cooling has excellent cooling performance, gamers still worry about it will take too much space in the chassis. Now, this problem can be solved by Thermaltake new liquid cooling system, ProWater880i.
ProWater880i is developed to solve the dilemma of good performance and space saving. With the special designed mounting kit, gamer can easily install ProWater880i in the back of the chassis. It brings two benefits. One is that the radiator can be cooled by the cold air outside and generate better cooling performance. The other benefit is the space allocation within the chassis can be optimized.
To achieve maximized performance, ProWater880i comes with many exciting features. First, it can support the latest and fastest Intel Core i7 processor with the included clip. The 24cm Motorsport Radiator can speed up the heat dissipation. Meanwhile, the two efficient 12cm fans generate maximum air flow. P500 pump and big capacity tank create perfect coolant circulation and cool down all the major components. The all-copper waterblock has been through industrial-grade sealed. Leakage problem won't happen to PW880i and users can just enjoy the high cooling performance brought by it.
With all these features, ProWater880 definitely is a state-of-the-art liquid cooling product. By owning ProWater880i, users can be brought a new whole generation. For more information, visit this page.
