thermaltake TR2 RX 750 WATT or coolermaster silent pro 700 WATT both cost the same
Discussion in 'General Hardware' started by Achilles1600, Oct 24, 2010.
  1. Achilles1600
    Achilles1600 New Member
    Jul 5, 2009
    276 (0.11/day)
    13
    edmonton alberta canada
    Hi, im planning on getting the thermaltake TR2 RX 750 watt, or the coolermaster silent pro 700 watt, what should i get they both cost $119.99 in canada at a store called memory express.
    what should i get.? :wtf:
  2. aCid888*
    aCid888* New Member
    May 19, 2008
    2,754 (0.98/day)
    645
    In a state of flux...
    None.
    If its to power the rig in your SysSpecs then a Corsair 600w will do just fine and is no doubt around the same price. :)
    Also, for you Canadians, check out www.directcanada.com & NCIX (they price match)...often the best deals there. :toast:
    Edit: Some choices:
    Non-modular.
    http://www.directcanada.com/products/?sku=11180AC2550&vpn=CMPSU-650TX&manufacture=CORSAIR
    http://www.directcanada.com/products/?sku=11180AC8887&vpn=CMPSU-750TX&manufacture=CORSAIR
    Modular.
    http://www.directcanada.com/products/?sku=11180AC9616&vpn=CMPSU-650HX&manufacture=CORSAIR
    Achilles1600 says thanks.
  3. Achilles1600
    Jul 5, 2009
    276 (0.11/day)
    13
    What about a powercolor extreme series 1000 watt psu.?
  4. NdMk2o1o
    NdMk2o1o
    Apr 21, 2010
    3,763 (1.77/day)
    1,152
    Redditch, Worcestershire, England
    For your rig? totally overkill, grab a corsair 620w and be done with it, even that is plenty PSU for your needs.
  5. Achilles1600
    Jul 5, 2009
    276 (0.11/day)
    13
    dang it, ill just have to get the corsair HX 850 watt, and they have a deal going on at memory express, for $139.99 cnd with 10 dollar rebate and $40 dollar instant off. but the deal ends october 28 i dont get paid till october 29 shet :banghead: then it will be $179.99. oo well ill guess i just have to get it.
  6. NdMk2o1o
    NdMk2o1o
    Apr 21, 2010
    3,763 (1.77/day)
    1,152
    Why exactly do you think you need 850w? is this for your current rig?
  7. Achilles1600
    Jul 5, 2009
    276 (0.11/day)
    13
    No, im also buying the core i7 870, and also getting two 6970's when they come out.
  8. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,482 (5.99/day)
    4,522
    Youngstown, OH
  9. Achilles1600
    Jul 5, 2009
    276 (0.11/day)
    13
    Is it modular.?
  10. JrRacinFan
    Mar 17, 2007
    19,482 (5.99/day)
    4,522
    Youngstown, OH
  11. Athlonite
    Athlonite
    Jan 31, 2010
    2,158 (0.98/day)
    596
    JrRacinFan says thanks.
  12. Achilles1600
    Jul 5, 2009
    276 (0.11/day)
    13
    i think im going just going to get the corsair HX 850, tomorrow.
    Thank's for the help guy's
  13. keakar
    keakar
    Mar 27, 2007
    2,526 (0.78/day)
    351
    just outside of new orleans
    great choice but i wouldnt suggest more then a 750watt for you but if they dont have the corsair 750 then i would agree with you getting the 850
    one thing to remember is that corsair IMO is hands down the best, most reliable, top quality power supply sold today so you cant go wrong buying one.
