Thinking about going to water cooling. What is a good kit?
Discussion in 'Overclocking & Cooling' started by JC316, May 30, 2007.
  1. JC316
    JC316 Knows what makes you tick
    Jan 24, 2006
    9,365 (2.67/day)
    914
    I am thinking about going to water cooling for my CPU. I would like suggestions for a good kit in the sub $200 range.
    My temps right now are 34*C Idle and 47*C load, so it would have to cool better than that.
  2. trip l g
    trip l g New Member
    May 30, 2007
    4 (0.00/day)
    0
    The Thermaltake symphony mini droped my cpu idle temp 25 deg!
    It's silent and works like a champ. My intel C2D E6700 rated 2.66Ghz when oc'd to 3.3 Ghz ran over 60* idle, now at 3.5Ghz runs 40* load. It was a little over $200 but i can push push push and everything runs super stable w/ no problems. :)
  3. freaksavior
    freaksavior To infinity ... and beyond!
    Dec 11, 2006
    8,086 (2.54/day)
    913
    stay away form the TT big water 745, had lots of bad luck........thats all i can say!
    good luck btw
  4. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.47/day)
    3,778
  5. DanTheBanjoman SeƱor Moderator
    May 20, 2004
    10,553 (2.56/day)
    1,383
    Symphony mini isn't exactly mini though, takes up a lot of space. Plus it does make a buzzing sound from the pump. Having the cooling external isn't ideal when moving the computer around either.
  6. Oliver New Member
    Apr 7, 2007
    196 (0.06/day)
    11
    Paris
    How High
    How high have you gone........stable? I hit a wall on air with my e6700 and pc6400c4 Corsair at
    410-420 fsb *9 or 370*10 where evrything just becomes unglued:banghead: and am thinking about running water or phase..........and what volts are u running???
  7. Garb3
    Garb3 New Member
    Dec 5, 2006
    398 (0.12/day)
    6
    Hartlepool, England
  8. Oliver New Member
    Apr 7, 2007
    196 (0.06/day)
    11
    Paris
  9. Garb3
    Garb3 New Member
    Dec 5, 2006
    398 (0.12/day)
    6
    Hartlepool, England
  10. d44ve New Member
    Apr 16, 2007
    2,521 (0.82/day)
    309
    I would suggest building your own kit by piecing it together.
    Buy the best that you can at that time.... even if you cant build the whole kit at first, just save more money and later get another quality part
    Although with 200 bucks you should be able to get pretty close.
    I have found that most "all in one" kits lack something here or there.
    You can build your own and avoid all that
  11. Garb3
    Garb3 New Member
    Dec 5, 2006
    398 (0.12/day)
    6
    Hartlepool, England
    i only got that cause it's my first time with water cooling and i ready reviews and i said it was easy to set up and the price was not bad either:D
  12. Oliver New Member
    Apr 7, 2007
    196 (0.06/day)
    11
    Paris
    Nice looks
    Looks really nice...........have fun with it.
  13. d44ve New Member
    Apr 16, 2007
    2,521 (0.82/day)
    309
    If it is your first time going water... using a prebuilt setup is not a horrible idea.
    At least at that point you will get the idea of what happens and what needs to be done first hand.
    THe only problem is.... you will want to upgrade and build you own after a short while (IMO) and you will just end up spending more money.
  14. Garb3
    Garb3 New Member
    Dec 5, 2006
    398 (0.12/day)
    6
    Hartlepool, England
    well isnt that what this forum is here for to make us want the best system then we go out and try to buy it lol:roll:. i think by the time i get bored of it i will build 1 with all induvidual parts:rockout:
  15. d44ve New Member
    Apr 16, 2007
    2,521 (0.82/day)
    309
    Very true! lol
    Good luck either way.
    :toast:
  16. Alcpone
    Oct 15, 2006
    2,339 (0.72/day)
    96
    Tyne & Wear, UK
    Ive got the XSPC kit Garb :toast:
    Its reliable as hell and works a treat, I aint had 1 leak ever and it takes very little maintenance! The 10/8mm compression fittings are the best and I find skinnier tubing is easier to manipulate :)
    Garb3 says thanks.
  17. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.47/day)
    3,778
    On the other hand, if you go with something like the Swiftech kit I mentioned, you can upgrade as you go. I already added a chipset block (but had to take it out because it doesn't fit with the new gfx card), and I will be getting a 3x120 rad and maze5 for my 2900 in the coming weeks. With the kit and chipset block, my total came to $180. I couldn't piece together anything cheaper, that had equivalent performance, for that price.
    The swiftech blocks surprised me with their performance. Great bang for the buck. Once I get the new rad and maze5, I plan on lapping everything, and popping the IHS off my chip. I can't wait to see the results.
  18. Garb3
    Garb3 New Member
    Dec 5, 2006
    398 (0.12/day)
    6
    Hartlepool, England
    mini hijack sorry:eek:
    do u think if i get a vga water block for my x1950pro it will help me oc more out of my core cause it wont go any higher than 621 at the min like:eek:
  19. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.47/day)
    3,778
    I wouldn't recommend it on a single 120mm crossflow rad. It will likely be beyond the system's thermal capacity. It may make it so you have to downclock your cpu.
  20. Garb3
    Garb3 New Member
    Dec 5, 2006
    398 (0.12/day)
    6
    Hartlepool, England
    so if i get a 360x120 or 140x120 rad i will be better off
  21. JousteR
    JousteR
    May 2, 2007
    168 (0.06/day)
    35
    I got this one from my local shop/store,It has a super finish all in aluminium(solid)It's got 2
    120mm fans inset behind a mesh intake and quick relese pipe fasteners for if it needs to be moved/Drained.
    Right now cpu sat at 31c after a couple of hours gaming
    And gpu at 32c..
    Highly recomended by me but might not be every mans/womans taste.
    http://www.thermaltake.com/product/Liguid/DIY/cl-w0042/cl-w0042.asp
  22. Garb3
    Garb3 New Member
    Dec 5, 2006
    398 (0.12/day)
    6
    Hartlepool, England
    thats sweet :D might get that once i get a bit more experience with what i'm gettin. hope i can get it in black tho cause it might look a tad out of place with me black case:)
  23. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.47/day)
    3,778
    Most definitely. That's actually my plan when I get my gfx block.
    Garb3 says thanks.
  24. Garb3
    Garb3 New Member
    Dec 5, 2006
    398 (0.12/day)
    6
    Hartlepool, England
    as i said like i wont be gettin one for a while like but ithink that i will got for a 360x120 cuase once i start adding things i wont stop lol
  25. D_o_S
    D_o_S Moderator
    Aug 27, 2005
    979 (0.27/day)
    38
    Methinks:
    Swiftech Apogee GT
    Laing DDC+
    Swiftech MCR 220
    GPU block if you want...
    Tubing, barbs, etc...
    That should be ~$200
Share This Page
