Tiny ITX Build Problem
233 (0.04/day)
Australia, SA
System Name Computer MkVIII
Processor 2500K @ 4.5ghz
Motherboard ASUS Sabertooth P67
Cooling CPU: 212+ EVO GPU: Stock
Memory 16gb G.Skill Ares @2133mhz
Video Card(s) EVGA GTX 980 SC
Storage 1x Samsung 840 EVO 1TB
Display(s) 24" Asus VE248
Case Corsair Carbide 300R
Power Supply Corsair HX-650
Software Windows 7 Home Premium 64bit
Well like I said i grabbed a new cheap cpu and ram (i3 550, PQI 2gb stick)... Same damn problem... Perhaps i have a motherboard that creates killer CPU's that kill other motherboards (because like i said my DFI board does the same thing) *sigh* Well there goes all my computer budget :(
1,226 (0.22/day)
The Netherlands
System Name Silent allround
Processor i5 750 @ 3,0Ghz 1.04v / 3.4Ghz 1.11v/ 3,6Ghz 1.15v
Motherboard Gigabyte P55-USB3
Cooling Thermalright IFX-14 + Scythe Slip Stream 140mm @ 600RPM
Memory 2 x 4GB Samsung M378B5273DH0-CH9 @ 2000 MHz 9-10-10-27 T1
Video Card(s) Sapphire HD 5870 Vapor-X @ 940/1270
Storage Intel Postville 80GB SSD & Western Digital Green 2TB
Display(s) Dell Ultrasharp U2412M
Case Bitfenix Merc Alpha
Audio Device(s) Asus Xonar D2 with Unified Drivers
Power Supply Nexus NX-5000 R3 530W
Benchmark Scores Super pi 1M : 8,549s @ 4,7Ghz (Core i7 920)
Hmm.I have a similar setup and i've no problems whatsoever.
Which BIOS do you use?
I'd recommend you to try the following things:
-disable EIST / C1E / all energy saving features in your BIOS and disable Gigabyte apps like Dynamic Energy Saver.
-disable your IGP.
-try a different videocard.
-try different (older) GPU drivers like 10.7, 10.6 etc.
-Install all drivers for your motherboard like intel chipset driver etc , you can find these on the gigabyte website.
233 (0.04/day)
Australia, SA
-disable your IGP.
-Done, but no different :(
-How? There's no option, there's just the option to look for the pcie card first
-I've tried a little 8400GS, the 5770 and recently my 5870 now that i have an SG07
-Tried 10.3, but i'll have a go at some others
-Also did that :(
Oh also I'm using the latest bios F5
Thanks for the ideas though, I'll keep trying everything I can.
1,226 (0.22/day)
The Netherlands
-Also did that :(
latest bios is F6A, http://www.fileden.com/files/2009/12/20/2696817/h55nusb3.f6a.zip . Give it a try.
can't you disable it here? internal graphics clock ->disable?
233 (0.04/day)
Australia, SA
Oh sweet, I'll give it a go :D. what type of bios flash do you recommend Qflash or just a simple bootable usb? I used a bootable usb last time.
Edit: I don't wanna sound like an ass, but how did you find that bios? Can't seen to locate it on Gigabytes website, I'm a little cautious about bios's that i can't find on the official site.
Edit2: Also in the current bios that Internal Graphics Clock doesn't show up when i have a pcie gpu installed
1,226 (0.22/day)
The Netherlands
Qflash , the bios comes from the official tweaktown gigabyte support forum http://forums.tweaktown.com/gigabyte/28441-gigabyte-latest-bios-345.html. I'm using the F6A bios since my install and it runs 100% stable. Let me know if it works out for ya or if you need any help.
good luck mate
233 (0.04/day)
Australia, SA
Well, I've narrowed down the problem, It's to do with the network. Either the Realtek onboard is messed up/my drivers suck (They're the latest 7.23 from realteks site)/or it doesn't like my router. I have 2 other computers on this network and they're doing just fine, they also use the inbuilt Realtek network (Ones a gigabyte p35 mobo and the other is a gigabyte p45). Hope that adds something that'll help you super awesome dudes think of something, I'm stumped. I thought it happend offline because of Starcraft 2, but i see that Starcraft 2 actually goes online if you do the VS AI's, kinda strange really.
Edit: Bios update was fine btw mudkip, didn't help the problem sadly, but now that i know its something specific it should be easier to think about.
3,471 (0.61/day)
System Name Acer Aspire V3-771G-53218G75Maii
Processor Core i5 3210M (2,5-3,1Ghz)
Memory 8GB DDR3 SODIMM
Video Card(s) Geforce GT650M
Storage Samsung 830 256GB - 750GB Toshiba drive
Software Windows 7 x64 Home Premium (non-acer-bloatware)
Are the other two PC's on the same OS? I know the Realtek chips can cause problems sometimes. Anything on Windows Update for Realtek drivers?
233 (0.04/day)
Australia, SA
Yeah, they're actually all running Windows 7 Home Premium 64bit (Should've mentioned that sorry). Also nah, no updates on Windows Update :( (I have every windows update installed, but i do know none of them actually cause it because the same happens with a fresh install immediately)
1,226 (0.22/day)
The Netherlands
what if you format your computer and install windows without realtek drivers?
233 (0.04/day)
Australia, SA
That would get rid of the problem, but also get rid of my internet access :p
I went ahead and tried out my old copy of windows xp pro, same type of problem, except it has long pauses instead of constant lag during TF2 matches :(
Any idea where i could get older realtek drivers? I'd love to give a few different variants a go :)
1,226 (0.22/day)
The Netherlands
Hmm? Try wireless internet?
233 (0.04/day)
Australia, SA
I'll see if i can dig an adapter up from a friend, don't really use wireless due to the router being connected to just about every room
