Tubing and fittings/barbs for my water cooling setup.
J-Man
2,248 (0.36/day)
Oakham, UK
System Name Watercooled beast
Processor Intel Core 2 Quad Q9550 @ 4.02GHz
Motherboard ASUS Rampage Formula X48
Cooling Swiftech Apogee GTZ, Black Ice GTX Xtreme 480, EK 250 Rev 2, EK 4870 X2, MCP655, 1/2" Tygon Tubing
Memory 4GB DDR2 OCZ @ 1066MHz 2.1V
Video Card(s) HIS ATI Radeon HD 4870 X2 800 on core, 1000 on memory (overclocked in CCC)
Storage 500GB Maxtor Diamondmax 22 SATA II 32MB Cache
Display(s) Samsung 24" SM245B
Case SilverStone TJ07 black/windowed version
Audio Device(s) Creative X-Fi Xtreme Gamer Fatal1ty + Logitech Z-5500
Power Supply Thermaltake Toughpower 1200W Modular
Software Windows Vista Ultimate 64-bit Retail
Hi. I wanna list you the parts that I will put together and tell me if everything looks ok. I also want what tubing and barbs to get with it. I'm a little confused on that one. Thanks in advance.
CPU block: http://www.overclockers.co.uk/showproduct.php?prodid=WC-000-DT
Pump: http://www.overclockers.co.uk/showproduct.php?prodid=WC-004-SW
Reservoir: http://www.overclockers.co.uk/showproduct.php?prodid=WC-007-SW
Radiator: http://www.overclockers.co.uk/showproduct.php?prodid=WC-020-SW
Fluids: http://www.overclockers.co.uk/showproduct.php?prodid=WC-000-FO
I need tubing and barbs now right and the quantity. Cheers.
5,147 (0.78/day)
AZ
System Name Thought I'd be done with this by now
Processor i7 11700k 8/16
Motherboard MSI Z590 Pro Wifi
Cooling Be Quiet Dark Rock Pro 4, 9x aigo AR12
Memory 32GB GSkill TridentZ Neo DDR4-4000 CL18-22-22-42
Video Card(s) MSI Ventus 2x Geforce RTX 3070
Storage 1TB MX300 M.2 OS + Games, + cloud mostly
Display(s) Samsung 40" 4k (TV)
Case Lian Li PC-011 Dynamic EVO Black
Audio Device(s) onboard HD -> Yamaha 5.1
Power Supply EVGA 850 GQ
Mouse Logitech wireless
Keyboard same
VR HMD nah
Benchmark Scores no one cares anymore lols
looks good, but I'm a bigger fan of swiftec blocks myself. why only the cpu? that radiotor could handle both cpu/gpu
J-Man
2,248 (0.36/day)
Oakham, UK
I just wanna cool the CPU 'cause I guess it's the main thing inside a PC and it's gotta be kept cool. What tubings and barbs do I need?
Jarman
387 (0.06/day)
Wrexham UK
Processor Opty 165 @ 3011 MHz
Motherboard DFI NF4 SLI-D
Cooling Koolance Exos, DD TDX/Maze4 GPU
Memory 2GB G.Skill HZ DDR 500 Kit
Video Card(s) XFX Geforce 7900GT
Storage > 1.5 TB
Display(s) XEROX 19" TFT
Case Coolermaster ATCS 101
Audio Device(s) Creative X-FI
Power Supply OCZ 850W
Software XP serv pack 2
www.coolercases.co.uk is better for wc stuff than ocuk
Dtek fuzion v2 is a good choice. I would rather a DDC18w than a vario on the pump. The res i would go for is an ek multioption res, with vortex breaker. I would go for a thermochill pa120.2 or greater rad. I would make my own coolant from deionised water and a decent antifreeze (10% antifreeze). i would also choose 3/8" tubing and barbs over 1/2". dangerden clearflex is also better tube than tygon 3603.
cdawall
where the hell are my stars
27,680 (4.29/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
7/16in tubing and 1/2in barbs
Jarman
387 (0.06/day)
Wrexham UK
Storage > 1.5 TB
7/16 tubing isnt widely used in the UK. Plus 1/2" pipe takes up so much space, its so unflexible and gives very little in return over 3/8"
J-Man
2,248 (0.36/day)
Oakham, UK
I'd like to use overclockers, thanks for the link though. Can you please go on overclockers and link me to what YOU would get for me? I want high end stuff.
Jarman
387 (0.06/day)
Wrexham UK
Storage > 1.5 TB
J-Man
2,248 (0.36/day)
Oakham, UK
5,147 (0.78/day)
AZ
Keyboard same
VR HMD nah
I'd recommend forgetting those clips they suck, they'll either break or won't hold tight enough. go to your local auto shop and pick up some of these.
http://www.germes-online.com/direct/dbimage/50309230/Hose_Clamp.jpg
they come in all kinds of sizes are typically sold for a few pennies a piece, will hold nice and tight, won't be a pain in the ass to take off, and won't break.
2,312 (0.36/day)
Norn Iron
Processor Q9550 @3.8
Motherboard Asus Maximus Extreme
Cooling Custom water cooling
Memory 4GB Patriot Viper DDR3 1600MHz
Video Card(s) 2x HD4870 512MB
Storage 2x 500GB
Display(s) 3x LG L226WTQ 22" Widescreen LCD
Case Modded TJ07
Audio Device(s) On board
Power Supply PC P&C Silencer 750
Software Windows 7 Ultimate
I know you like OverClockers...but there are lots more places to buy from and you will save some money by shopping around..here are some more sites to try.
Chilled PC
WaterCooling UK
TheCoolingShop
SpecialTech
Over-Clock UK
Aqua-Pcs
Just a note,if you do go for a triple RAD,just make sure you have room for it in your case if thats where you are mounting it.They can take quite a bit of room up.
For tubing you could try Masterkleer 7/16" ID with 1/2" barbs -its a nice tight fit and helps reduce the chances of leaks.
For the CPU block -I agree go with the new D-Tek FuZion v2
EDIT:Also if you go with the Laing DDC1+ pump you might want to try and get a different top for it to help flow rate.Also the stock top is 3/8" barb size fittings.
Here is one with a Petras Tech top (very good top)
Or you could get the EK-DDC X-Top for it here.
J-Man
2,248 (0.36/day)
Oakham, UK
I plan on getting the latest Lian-Li case at the end of this month and someone on youtube has the case and he has a triple rad in at the front.
PrudentPrincess
669 (0.11/day)
Eugene
System Name Foobox3000
Processor Core 2 Duo 36750@3.46ghz
Motherboard Gigabyte GA-G33M-DS2R
Memory 2gb (2x1gb) Crucial Ballistix Tracer
Video Card(s) EVGA 9800gtx
Storage 500gb 7200prm IDE
Display(s) Sceptre 19"
Case Apevia X-Qpack 2 Red
Power Supply 500w Apevia generic
2,312 (0.36/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
That radiator is overkill for one CPU. I would really recommend throwing a GPU block in or getting a smaller rad. (Unless you plan to get a GPU block later.)
I agree..a double would be suffice but if you can fit the triple in, then it will future proof you for when you add more blocks till your loop(that's if you do...and you probably will, as it is addictive once you start and you always seem to want to try new parts out :) )
J-Man
2,248 (0.36/day)
Oakham, UK
Search up "Maxishine" on youtube and he is using the same case I'm getting at the end of this month and search his video of his new triple rad and he shows what barbs he is using.
2,312 (0.36/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
That's the ARMORSUIT PC-P80,a very nice case.. and he fitted the Thermochill PA120.3 rad into the front ..so you know that it will be able to fit your RAD in there if you want to go that way.
One thing to note if you buy the Thermochill RAD is that the barb threads are a little bit different from most normal barb thread sizes,it uses 'Fitting Thread: 3/8" BSPP' and a lot of barbs are 1/4" BSPP ..if you are using 1/4" BSPP barbs you can get a converter for the RAD here
J-Man
2,248 (0.36/day)
Oakham, UK
2,312 (0.36/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
