- Oct 9, 2007
- 46,383 (7.68/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Tuniq today announced its newest CPU cooler, the Tower 120 Extreme. With this release Tuniq introduced what it calls a radical design change, that increases heat dissipation surface area, and brings about turbulence that helps cooling. To do so, each aluminum fin has "wave-design" edges on two sides. Every neighbouring fin has an alternating wave-pattern, that helps provide turbulence. A 120 mm, PWM-controlled, LED-lit fan is nested inside the fin block, that circulates air. Five nickel-plated copper heatpipes convey heat to the fins, which make direct contact to the CPU at the block.
The cooler measures 131(L) x 112.31(W) x 150.7(H), and weighs in at 775 g without the fan (around 850 g with it). The fan spins at speeds between 1000~2000 rpm, pushing up to 90.65 CFM of air, with a maximum noise output of 20 dBA. Out of the five heatpipes, three are 8 mm in thickness, and two 6 mm ones. The package includes a 1g tube of Tuniq's recently announced TX-3 thermal compound. In Tuniq's own tests, the Tower 120 Extreme emerged at least 10% more efficient at cooling than its predecessor, the Tower 120. It is compatible with most current CPU sockets, including LGA-1366, LGA-775, and AM3/AM2+/AM2. Expect it to be priced close to that of the Tower 120 when it hits stores soon.
