ultru chilltec cpu cooler and cooler master stacker case
Discussion in 'General Hardware' started by skellattarr, Feb 28, 2009.
  1. skellattarr
    skellattarr
    Jul 22, 2008
    656 (0.24/day)
    78
    midway city ca
  2. MikeJeng
    MikeJeng New Member
    Jan 12, 2008
    551 (0.19/day)
    23
    United States - CA
    Yes. In fact, there will be extra space left over.
  3. Jeffredo
    Jeffredo
    Nov 30, 2006
    890 (0.26/day)
    152
    It will fit, but you probably won't be able to use the fan bracket that fits on the side panel (the one that holds four 120mm fans). Its too thick and the cooler is too tall (most likely). I have a Xigmatek S1283 and its just too tall to all the bracket to close and I have a Coolermaster Stacker Evolution 830.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
    Its O.K.. The case is roomy and I was able to install a "porthole" fan on the top bracket in addition to the one in the front and the one in the rear. Still stays very cool, even with a 125W Athlon X2 6400+ and an 8800 GTX. The top, bottom, front and both sides are a mesh material that allows air to easily circulate.
    Edit: Just checked the dimensions on mine vs. the one you are looking at. Its seems to be a lot more "squat", so you probably will be O.K.. Mine is just about an inch too tall (6 3/4). The one you are looking at is just 3.6 inches.
  4. skellattarr
    skellattarr
    Jul 22, 2008
    656 (0.24/day)
    78
    midway city ca
    ok thanks for the responce i have a new problem now lol i want to get that case but i want to get windows 7 when it comes out to i only have the money for one
  5. HolyCow02
    HolyCow02 New Member
    Jun 8, 2008
    1,638 (0.58/day)
    111
    New York
    damn that cooler is massive! But that's a full tower case so you should be alright.
  6. RevengE
    RevengE
    Dec 31, 2008
    2,663 (1.02/day)
    214
    Ohio
    What about a cosmos S?
