OnBoard
- Sep 16, 2006
- 3,033 (0.47/day)
- Finland
Processor | Core i5-750 @ 3.6GHz 1.136V 24/7 |
Motherboard | Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby! |
Cooling | Alpenföhn Brocken HeatpipeDirectTouch |
Memory | Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24 |
Video Card(s) | Gigabyte GTX 460 1GB OC (mostly stock speeds) |
Storage | OS: Samsung F3 500GB Games: Samsung F1 640GB |
Display(s) | new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD |
Case | new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans |
Audio Device(s) | new! ASUS Xonar DG & JVC HA-RX700 headphones |
Power Supply | Cougar CM 700W Modular |
Software | Windows 7 Home Premium x64 |
Benchmark Scores | Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging |
Heh, I went from 2x2GB 800MHz kit to 2x2GB 1066MHz, even when I knew there is hardly any difference
Well there is a point to all this madness. it gives me options in the future with CPU upgrade. No need to worry about processor multiplier, as I know these have enough (FSB) in them. 800MHz kit maxed out at about 940MHz 5-5-5-15 with 2volts and I run these 1066MHz 5-5-5-15 with just 1.9v.
Oh and they look way sexier shining all gold, than my cheapo a-data stock red spreaders did
Don't know how AMD system is, but in Intel you max out the bus bandwidth, hence faster memory doesn't give you benefits, unless you OC. 667MHz memory would be enough to any non extreme processor with stock clocks.
