USB 3.0 Header 20-pin problems
Discussion in 'General Hardware' started by hooj, Oct 8, 2012.
  1. hooj
    hooj New Member
    Jan 4, 2008
    398 (0.13/day)
    18
    Londinius
    Hello i have a problem. I can't use my front USB 3.0 port because i have not 20-pin on my motherboard. so the 20-pin is left hanging but i want to put it to good use so what adapter (cable or pci) would i need?
    I presume the pci option so i can slot it in, plug the 20-pin into it to power the front 3.0 and have some extra 3.0's at the back?
    [​IMG]
    Or maybe this?
    Lian Li PW-IO2AH100 USB 3.0 (20pin) Header to USB 2.0 Header
  2. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    44,586 (10.54/day)
    11,734
    Australalalalalaia.
    that one in the image doesnt seem to have the USB 3.0 header.
    the link you gave will let you use the ports as USB 2.0
    hooj says thanks.
    10 Year Member at TPU
  3. hooj
    hooj New Member
    Jan 4, 2008
    398 (0.13/day)
    18
    Londinius
    Got any links to what would work for me then?
  4. Mussels
    Oct 6, 2004
    44,586 (10.54/day)
    11,734
    Australalalalalaia.
    a USB 3.0 PCI/PCI-E addin card with a 30 pin connector. you can tell by looking at an image of it.
    hooj says thanks.
  5. Kantastic
    Kantastic
    May 12, 2009
    5,180 (2.03/day)
    997
    hooj says thanks.
