Using 2 pin fans on a PWM port?
Discussion in 'AMD / ATI' started by TRWOV, Jun 12, 2012.
  1. TRWOV
    TRWOV
    Aug 11, 2011
    4,065 (2.94/day)
    2,762
    Mexico
    I came across a cheap 6950 with broken fans. I found cheap replacements on eBay but they are 2 pin fans. I think adapting the plug wouldn't be a problem (1 minute of sanding should do the job) but is there any drawback to this? apart from not being able to control them, that is.
    The replacement fans use less current than the originals so I don't think I'll overload the VRMs or anything.
    Crunching for Team TPU
  2. Techtu
    Techtu
    Mar 6, 2010
    2,143 (1.13/day)
    499
    In the night garden
    Sounds like your good to go. :toast:
  3. natr0n
    natr0n
    Jan 29, 2012
    2,413 (1.99/day)
    1,334
    FL.
    the fan will run full speed but will work
Share This Page
