- Apr 19, 2012
- 12,062 (2.75/day)
- Gypsyland, UK
System Name | HP Omen 17 |
Processor | i7 7700HQ |
Memory | 16GB 2400Mhz DDR4 |
Video Card(s) | GTX 1060 |
Storage | Samsung SM961 256GB + HGST 1TB |
Display(s) | 1080p IPS G-SYNC 75Hz |
Audio Device(s) | Bang & Olufsen |
Power Supply | 230W |
Mouse | Roccat Kone XTD+ |
Software | Win 10 Pro |
Mine doesnt have either audio jacks or a USB port. Its the entry level Razer Blackwidow. No fancy backlighting or extra ports.
The USB 2.0 on the frontpanel would work, but then again I'm really paranoia when it comes to cablemanaging. I dont really like have 2 peripherals stick out of the top of my case 24/7
I would disable it if I knew where, I'm probably not looking good enough to find all these options I'm sure. But without any changes it seems to work just fine aswell. (Maybe its disabled by default)
Then just go and buy a USB hub or USB PCI card. There is little else you can do if you dont want to plug your peripherals into the case.
