VGA fan making noise, what to do?
Discussion in 'Overclocking & Cooling' started by hat, Apr 22, 2012.
  1. hat
    hat Enthusiast
    Nov 20, 2006
    17,203 (5.46/day)
    2,198
    Ohio
    Lately the fan on my 5870 (this model to be specific) has been making rattling noises at higher speeds. Very annoying during games... what can I do to solve this problem? I can't afford a new cooler, so the only solution is to fix it the hard way.
    Crunching for Team TPU
  2. stinger608
    stinger608 Dedicated TPU Cruncher & Folder
    Nov 11, 2008
    7,878 (3.24/day)
    4,953
    Wyoming
    First your link doesn't work Hat.
    You can try a bit of light oil. Something like 3 in 1 or sewing machine oil. Don't recommend using vegetable oil as it seems to gum up after a couple of weeks.
    hat says thanks.
  3. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    21,320 (6.07/day)
    7,250
    Yep, just what I was going to suggest. Pull it apart and oil the fan, I prefer 3in1 oil myself.:toast:
    hat says thanks.
  4. Radical_Edward
    Radical_Edward
    Jan 24, 2010
    3,586 (1.80/day)
    1,927
    Oregon, USA
    I use white lithium grease, works great for me.
    Also I'm sure you can purchase a new fan for it on eBay or something, just look around a bit.
    hat says thanks.
  5. eidairaman1
    Jul 2, 2007
    14,184 (4.85/day)
    2,060
    sounds to me dust is getting in the bearing area
    hat says thanks.
Share This Page
