VGA to VGA adapter problem
Discussion in 'General Hardware' started by Aleksander, Jun 6, 2011.
  1. Aleksander
    Dec 2, 2009
    3,254 (1.94/day)
    304
    Hi guys!
    I bought a new cable and it seems that the screen has a lot of "motion blur" as seen on
    adobe photoshop from the right side. Also the screen is unstable, meaning it moves a lot.
    Anyone can help me on here?
  2. slyfox2151
    slyfox2151
    Jan 14, 2009
    2,606 (1.30/day)
    524
    Brisbane, Australia
    adapter or cable?
    why would you need VGA to VGA?
    makes sure its plugged in firmly.
  3. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    41,928 (11.76/day)
    9,356
    VGA is like that if the adaptor is bad, the cable is bad, or they're just loose/poorly connected.
    this can also happen if the cable is too long, or if the monitor/cable is getting EMI interference.
    tried degaussing the monitor (if its CRT) or hitting the 'auto' button/menu option if its LCD?
  4. Aleksander
    Dec 2, 2009
    3,254 (1.94/day)
    304
    It is a cable VGA (for the CRT) to VGA (for the graphic card). The cable now is 2 times longer than the last one, which means this can be a part of the problem, but still i have not solved it. Also, when i scroll down the resolution to 800x600 the text (screen) is not blurry anymore
  5. Aleksander
    Dec 2, 2009
    3,254 (1.94/day)
    304
    bump
  6. theonedub
    theonedub habe fidem
    Apr 30, 2009
    7,125 (3.76/day)
    3,656
    I think Mussels has it right here, sounds like EMI. Cables are probably cheap (probably missing ferrite cores on them) and with the length doubled they would be more susceptible to interference.
    When I tried running 2048x1152 through a cheap VGA cable I got the same blurry image, and reducing res made it get better.
    Aleksander says thanks.
    Crunching for Team TPU
  7. yogurt_21
    yogurt_21
    Feb 18, 2006
    4,300 (1.40/day)
    541
    AZ
    what you mean is you bought a vga extender cable, my guess is the quality fo it isn't up to snuff or it's a used cable that's bad.
    in either case just take it back to where you got it from and say it gives blurry picture.
  8. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    19,646 (6.23/day)
    5,830
    Yep, more than likely the case.
    In fact, a lot of times there is fine print on the VGA extenders saying "Not recommended for resolutions greater than 1024x768", sometimes they don't recommend anything above 800x600. Though sometimes they don't have any warning like this. The VGA signal just can't go that far, and the higher the resolution the more EMI will effect the image.
    Crunching for Team TPU 50 Million points folded for TPU
  9. Aleksander
    Dec 2, 2009
    3,254 (1.94/day)
    304
    Yeah!
    The higher the resolution the worse it becomes :((((((((
    The problem is that i bought it from a foreign country, so no chances i take it back there!
    It said i must return it in at least 24 hours :p
  10. whitrzac New Member
    Jan 21, 2011
    366 (0.29/day)
    29
    Baraboo, WI
    its a VGA cable, aren't they $3 a piece?
  11. newtekie1
    Nov 22, 2005
    19,646 (6.23/day)
    5,830
    The ones that cause this problem are, yes.
  12. MN12BIRD
    MN12BIRD
    Mar 9, 2009
    471 (0.24/day)
    78
    LOL yup like with any analog cable the quality of the cable is important. Probably more so than HDMI or DVI cables. Don't use a longer cable than you need to use and cheap cables lack good shielding and like someone mentioned ferrite cores. Interference isn't uncommon on high frequency analog video like VGA. You'll get ghosting and all kinda crappy junk like that! Toss that tosh and get a decent cable at the correct length you need.
  13. Aleksander
    Dec 2, 2009
    3,254 (1.94/day)
    304
    It costed 2.11 euro, so yes you are right!
    Bear in mind that i dont live in US
Share This Page
