Water Block with Air Cooling Fan Support...
Discussion in 'General Hardware' started by KH0UJ, Aug 23, 2009.
  1. KH0UJ
    KH0UJ New Member
    Feb 22, 2009
    363 (0.14/day)
    32
    Cebu City Philippines
    Hi guys, is there a CPU waterblock with heatsink and fan support?:laugh:
    i know it sounds silly but im just curious:laugh:
    I was looking at cooler master hydra for GPU, I wonder if there is a hydra for CPU:ohwell:
  2. MRCL
    MRCL
    May 31, 2008
    5,795 (2.06/day)
    862
    Switzerland, Heart of Europe
    The CPU block from Gigabyte's Galaxy set offers that option. I think you can buy it seperately without the whole set, but I may be wrong.
    Edit: See here for TPUs review of the set and the fan that clips onto the block.
    KH0UJ says thanks.
  3. hat
    hat Enthusiast
    Nov 20, 2006
    17,699 (5.25/day)
    2,516
    Ohio
    Why would you want to use a water block as an air cooler? Water blocks are supposed to be used with water, not fans.
    Crunching for Team TPU
  4. KH0UJ
    KH0UJ New Member
    Feb 22, 2009
    363 (0.14/day)
    32
    :laugh: ya cause i was always thinking of the back-up option, if the water pump fails it can still ventilate the CPU without over heating, or one of the other:laugh: specially cause im using a sealed external case, I was planning to try Hybrid WC to add to my back-up cooling:)
  5. MRCL
    MRCL
    May 31, 2008
    5,795 (2.06/day)
    862
    Well... it might work if you let the fan spin with 90000rpm, otherwise please bury that thought deep enough so you will newer come across it again:)
  6. KH0UJ
    KH0UJ New Member
    Feb 22, 2009
    363 (0.14/day)
    32
    :laugh: so that I have 3 back-up options bro, active cooling+water cooling+air cooling:laugh:
    just for fun, im bored already on active, and until now i never tried setting up WC, that`s why i wanna try it for my additional experience:laugh:
  7. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,482 (5.99/day)
    4,522
    Youngstown, OH
    KH0UJ says thanks.
  8. MRCL
    MRCL
    May 31, 2008
    5,795 (2.06/day)
    862
    If you go water, then go WATER, not air. BUT: Instead of focusing on pushing air towards the CPU, focus on a well ventilated case that directs airflow over the parts that now are missing fresh air due to the missing CPU fan.
  9. KH0UJ
    KH0UJ New Member
    Feb 22, 2009
    363 (0.14/day)
    32
  10. wahdangun
    wahdangun New Member
    Oct 2, 2008
    1,512 (0.56/day)
    114
    indonesia ku tercinta
    hey bro KH0UJ, can you teach me how to build that refrigirated gaming PC, it's totaly cool man
  11. KH0UJ
    KH0UJ New Member
    Feb 22, 2009
    363 (0.14/day)
    32
    ya sure:laugh: start a new thread then we`ll go from there;) but im telling you active cooling has a drawback man:( it can cool your entire system depending on what you set (5c-15c) but you may experience higher electricity bill:laugh: (150W-200W) 110 VAC @ 1.5 amps or 0.75 Amps. on 220VAC just for the cooling itself:ohwell:
    that`s why im gonna try water cooling+air cooling so that if the weather is cold, i can switch to it, and if the weather is hot, i can turn on the refrigerated:eek:
  12. KH0UJ
    KH0UJ New Member
    Feb 22, 2009
    363 (0.14/day)
    32
    I wish they can make like this:eek:
    [​IMG]
  13. wahdangun
    Oct 2, 2008
    1,512 (0.56/day)
    114
    i don't give a damm about electricity bill, i'm just want to learn something new, and i'm tired about water/air cooling,
    bro why don't you make your own custom Water block, and glue a TRUE on top of that
