Water cooled system overheating?!
Discussion in 'Overclocking & Cooling' started by ManillaForce, Dec 21, 2012.
  1. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    10,894 (6.05/day)
    2,867
    Seattle, WA
    Nice to see you figured it out...........now go start overclocking!
  2. m1dg3t
    m1dg3t
    May 22, 2010
    2,255 (1.19/day)
    518
    Canada
    Pumping into your res is a bad idea. Changing the loop order should yield better performance:eek:
  3. OneMoar
    OneMoar There is Always Moar
    Apr 9, 2010
    5,217 (2.68/day)
    2,116
    Rochester area
    make sure you heed t he extra advice anyway fix the direction and and bleed it properly
    that loop should keep things under 65c @ oc'd loads
  4. SirKeldon
    SirKeldon
    Feb 7, 2008
    654 (0.24/day)
    475
    Barcelona, Catalonia, Spain
    Didn't notice about the 5,25" reservoir, thanks for pointing it out, if it's that way, maybe aligning the pump with that one (if there's room) and going res->pump->double rad->cpu->gpu->simple rad->res or not moving anything and just changing loop direction.
    Aquinus says thanks.
    Crunching for Team TPU
Share This Page
