Water cooling advice ...
Discussion in 'General Hardware' started by sy5tem, Apr 19, 2011.
  1. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    Canada/quebec/Montreal
    Hello!
    i jsut received my tax return woohoo! free candy for me. so now i just ordered this from dazmode.com
    4x 1/2" ID Tubing - Long Barb - BLACK NICKEL
    4x 1/2"ID Tubing Hose Clamp
    4x Barb Clamp for OD: 16mm (5/8") 'did not know if i should use 1/2 or 5/8)
    1x EK-FC6970 Full Cover Block for HD6970 - Acetal-Nickel
    1x Feser Aqua - Bi-Distilled Uber Pure Water
    1x Feser Base - Corrosion Blocker & Biocide
    1x Rasa 750 RS240 Complete CPU WaterCooling Kit
    1x Slim Single 120mm Radiator XSPC RS120
    My plan is to have this installed this way.
    Pump-->CPU-->120mm rad-->GPU-->dual rad-->pump
    and i was wondering if this setup looks okay to anybody with experience. i am going to miss any part once i receive this? should i get supplemental hardware?
    thank you for you input !
    here is how i want to set it up:
    [​IMG]
    Yes there is a lost of dust :p
    10 Year Member at TPU
  2. MT Alex
    MT Alex
    Aug 2, 2009
    4,014 (1.34/day)
    1,857
    Looks nice. I would have went with the RS360, but maybe you don't have the room for a tripple rad. Anyhow, you're going to have some fun.
  3. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    exactly i have a cm sniper, and up top i only have room for dual, and i can have anything outside the case as i have kids :p
  4. Wrigleyvillain
    Wrigleyvillain PTFO or GTFO
    Oct 13, 2007
    7,693 (2.10/day)
    1,788
    Chicago
    Well I don't know if I'd call your money returned to you "free" but that's another story for another forum.
    Looks good offhand except I'm not sure about your clamps as also not sure what tubing size (ID and OD) comes in that kit? Smart move getting the Rasa kit until you have more experience with what's what. And a great example of this is your present barb clamp size confusion.
    digibucc says thanks.
  5. Loosenut
    Loosenut
    Jan 14, 2010
    943 (0.33/day)
    242
    Granby, Qc. Canada
    Sounds like it's going to be a nice setup. I have a mid tower also and had 1/2" tubing but after seeing how huge the tubing looked in the case, decided to try 3/8" ID tubing instead. Looks much better to me and no difference in cooling really.
    Good luck with your build and don't forget to let us know how it turns out :toast:
  6. Bjorn_Of_Iceland
    Bjorn_Of_Iceland
    Jan 2, 2008
    3,247 (0.91/day)
    397
    Was wondering why not RX120 instead.. looks like it would fit. Other than that, youl need a fast fan to dissipate heat quickly if youl overclock.
  7. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    XSPC raza is :Tubing Size: 7/16" ID x 5/8" OD which mean nothing to me first i use Centimeter and milimeter :p all i can see is that this is 7/15 inside diameter and 5/8 outside diameter ... and the barb is 1/4 to 1/2 ....
    of course i will make use of my wife brand new olympus 7040 camera :p
  8. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    was not in stock, and i wanted full part now :p but of course once build , i will see cooling performance and upgrade rad if needed , i think upgrading rad is fairly easy once you get a basic setup going. also i will try installing the dual rad on top of the casing making 2 hole for the hose , and i will try to use the 200mm fan to see if this setup would work first , of not then il upgrade
  9. Wrigleyvillain
    Oct 13, 2007
    7,693 (2.10/day)
    1,788
    Chicago
    Yeah the fact it's inches as opposed to metric system doesn't matter; the actual numbers are what's important e.g. outer diameter is "5/8". Though at this point just wait until everything is there and you'll figure out pretty quick if you have everything you need.
  10. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    hehe yeah that what i taught , but right now im like a kid the morning of xmas lol and once i receive everything i will probable cry if i am missing something it will be already hard that i will have to wait after the i get the setup running with computer off for 24 hours for leak test , ... lol
  11. cheesy999
    Jul 2, 2010
    4,012 (1.50/day)
    635
    UK
    one piece of advice i always give to anyone with a watercooling set up is
    Any watercooling set-up can be improved by drilling holes in the radiator, as this lets the heat escape:rolleyes:
    On a more serious note always do the water cooling tests by jump starting the psu - if you do it with any components in the case its a waste of time as everything gonna get wet anyway
    And if you do get water on anything - things can normally be fixed by resetting the psu and letting the water evaporate off for a few days
    sy5tem says thanks.
  12. Bjorn_Of_Iceland
    Bjorn_Of_Iceland
    Jan 2, 2008
    3,247 (0.91/day)
    397
    With just the GPU and CPU, i go hardcore and install everything all at once lol. Overclock it, then play games later on even if their are still micro bubbles present. Finished in an hour :D. Never received any leaks during my whole 3 times of replacing water.
  13. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    hehe you like to play with fire :p since this is my very first install i will try thing outside case for at least 24 hours.. i don't want to finally have a decent water cooling but no computer :p LOL
    now i just hope i have enough tubing from the xspc kit to install the gpu cooler too and the extra rad...!
  14. MT Alex
    MT Alex
    Aug 2, 2009
    4,014 (1.34/day)
    1,857
    Outside of the case isnt' the best plan, because when you put it back in the case you will stress connections, no matter how careful you try to be, which actually increases your chances of a leak.
    sy5tem says thanks.
  15. Wrigleyvillain
    Oct 13, 2007
    7,693 (2.10/day)
    1,788
    Chicago
    I know. That seriously blows. That's another main advantage to a kit--taking the guesswork out of choosing all the parts. But you just had to go ahead and add a GPU block now! :laugh:
  16. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    damit now i just found that my XFX 695A-cnfc might not be a reference board ohhhh i cry i cry! gona open my computer right now and check it ....
    not even received items and already having problem lol
  17. Loosenut
    Loosenut
    Jan 14, 2010
    943 (0.33/day)
    242
    Granby, Qc. Canada
    I totally agree with MT Alex on this part, I test for leaks with everything installed and leak test for only 3-4 hours though.
    The only things plugged in for this test is the pump and a couple of odd fans(just to put some load to the power supply) usually through the fan controller. Just make sure all HDD's, optical drives and MB remain UNplugged during the test and you'll be fine. Or you can do like like me, grab a small cheap power supply to power the pump and odd fans only and jump start it with the green and black wires. Easy.
    sy5tem says thanks.
  18. Wrigleyvillain
    Oct 13, 2007
    7,693 (2.10/day)
    1,788
    Chicago
    Yeah dude you may have jumped the gun a bit on adding GPU to loop, I'm sorry to say...
  19. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    Got it! moving it aint a good idea :p so i will do it full install with p/s jumped so the rest of component won't have juice so if i have a leak i will not short circuit anything! ty
    hehe i just removed my card and checked trough the fan fins and i can see the white sticker on vrm i think they are called , so i do have a reference and my EK block will fit fiew! i can sleep tonight so i can go outside in the morning and sit on the balcony waiting for mailman LOL
  20. trickson
    trickson OH, I have such a headache
    Dec 5, 2004
    6,486 (1.38/day)
    955
    Planet Earth.
    Looks really nice . one thing to add is water wetter this stuff is really good , I use it and it works !
  21. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    water "wetter" ? what is that?
  22. Loosenut
    Loosenut
    Jan 14, 2010
    943 (0.33/day)
    242
    Granby, Qc. Canada
    Water wetter is an additive used in vehicles, usually high performance engines and what it does nicely is it breaks down the water surface tension allowing the water to get into all the nooks and crannies to help cool the engine. I use it too in my loop with regular distilled water. You can get it at Canadian Tire. All you need is a small capful for a whole loop so your bottle will last a long time.
    EDIT: Water wetter is also anti-fungal and anti-corrosive. You wouldn't need the Fesser base.
  23. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    intriguing ! is that product conductive? or will it make the distilled water conductive?
  24. Loosenut
    Loosenut
    Jan 14, 2010
    943 (0.33/day)
    242
    Granby, Qc. Canada
    Not sure, everytime I had a leak was only during leak testing with only the pump and fans running
  25. sy5tem
    Nov 13, 2004
    454 (0.10/day)
    48
    humm i will look into that once I've got system running leak less for a week or two :) ty
