Water cooling advice ...
Wrigleyvillain
PTFO or GTFO
7,702 (1.28/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
only got corrosion on multi metal ... since my EK is acetal+nickel and cpu seem's to be copper based i think i made the right choise with the anti corrosion additive !
Probably, yes.
455 (0.06/day)
Canada/quebec/Montreal
System Name Custom DIY
Processor Intel i7 2600K @ 4.8 Turbo 1.4v
Motherboard Asus P8Z68-V Pro 8801
Cooling XSPC RS240 + 120mm Rad/fan
Memory Corsair 1866 Vangence 9-10-9-27-2T
Video Card(s) 2X EVGA GTX570 SLI
Storage OCZ Revodrive 110GB + 2x1TB seagate
Display(s) ASUS MT276HE
Case CoolerMaster Sniper
Audio Device(s) X-Fi Titanium Fatal1ty Professional Series
Power Supply ANTEC TP-750 Blue 750Watts
Software win7 64
Benchmark Scores http://3dmark.com/3dm11/1347866
that top rad is not getting airflow across the entire face of the rad... this concerns me
yeah but inside there is a 2cm space betwen the plastic and rad, and with the cm sniper fan controller fan at maximum i get GPU and CPU load at 50C no more!
so it still does the job, and i don't have the proper tools to cut plastic i used a meat knife lol
13 (0.00/day)
Midwest
you should go to harbor freight and get a cheap dremel like tool
455 (0.06/day)
Software win7 64
humm ya but im a lazy ass father :p so ATM load temp is 50C , if i want to go lower i can replace the 200MM with high speed 2X120 fan! and then if not satisfied i can go and knife the top out but only if i required..
to tell you the truth i am waiting on stock for 200MM RADS so i can install 2 in my case , one at the bottom and one at the front, that will do the trick im shure :p
455 (0.06/day)
Software win7 64
wow seem's my system is really nice atm , i get temp 48C maximum CPU/GPU while playing rift for about 8 hours! with my cm sniper fan dial to max speed! still very silent!
since i changed the PSU for a antec tp-750 , all i can hear now is the pump because the CM Sniper is "tool less" mean that i can't screw the pump/reservoir , so i hear it vibrate! dammit LOL i want perfection! not half perferct !
now im wondering what could i do to fix the reservoir on some kind of bushing .. or i am gona go and buy a liang DDC pump i think its called , and its gona be screwed somewhere in the bottom near PSU ..
should i buy this pump or anybody as an idea on how to fix the reservoir in the front and solidifies it somehow?
thank you
sneekypeet
Retired Super Moderator
29,409 (4.46/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
remove the tool-free plastic from where the screws go, then just use screws in the holes where the plastic used to be?
455 (0.06/day)
Software win7 64
the way the CM sniper is made on the 5 1/4 bay there is normaly 4 screw for lets say a cdrom drive, the sniper as a tool free device that use the top 2 hole, 1 left one right , and there is a space to ad a screw on the 2 bottom hole, left and right, the problem is that the reservoir as 2 hole BUT the hole are placed so that it use the top most hole, and the top hole from other bay. same thing on other side,
to fix this i would need to hole in the "bottom" part ....
reservoir:
tool free:
double sticky tape for the pump, works like a charm
what do you mean? double sticky tape around the reservoir?
455 (0.06/day)
Software win7 64
Wow just found something hilarious in my quest for silence my wife left the PS3 open "its just beside my computer" and the PS3 IS SO LOUD! its like 2x louder then my computer running 50% fan speed. never noticed how "noisy" was the ps3 when my computer was on air cooling omg
just ad to say it because i am so happy :p
455 (0.06/day)
Software win7 64
in the past if my pump made vibronoise I just used double sticky tape on the bottom to insulate it
i see! .. well i will be ordering more feser aqua and im gona try this after i've emptied the system! ty
sneekypeet
29,409 (4.46/day)
System Name EVA-01
I say measure it off and drill your own holes;)
