water cooling advice
Discussion in 'System Builder's Advice' started by coleman, Feb 28, 2009.
  1. coleman New Member
    Feb 7, 2009
    4 (0.00/day)
    0
    Many of you may have seen my worklog where i have started to mod my case for water cooloing.http://www.watercoolinguk.co.uk/foru...ead.php?t=6936. I am now at the stage when i am going to start buying the componants.
    I am looking for your opinion of what parts work well together or any suggestions that you have on componants to buy
    what's needed
    - cpu block
    - Pump
    - Radiator (240mm)
    - reservoir (small, not much space in the antec 300)
    - tubing (solid white if possible)
    - water/coolant
    - fittings (not sure weather you buy all these separate or whats compatible, lots of help needed here.
    Questions
    - positioning of componants- i here a lot of people saying different componants should be place higher than others for different reasons, let me know if there is anything i should knoe
    - Are there any other componants that can be included to the loop to improve efficency ect.
    considerations
    - i am willing to fork out for good componants, i dont like to cut corners.
    - i am only cooling the cpu
    - this is my first water cooled rig so any links and addvice will be much appreciated.
    thanks to all replies in advance
    coeman
Share This Page
