Water cooling an Antec 300
Discussion in 'Project Logs' started by p_o_s_pc, Feb 25, 2010.
  1. DTV DRAGON
    DTV DRAGON New Member
    Jun 3, 2008
    877 (0.35/day)
    64
    canada
    LOOKS great..Iam so close to haveing my stuff all here, just waiting on my red tubeing and some 1/2 compressions, I like to see how others go about projects as well
    p_o_s_pc says thanks.
  2. p_o_s_pc
    p_o_s_pc F@H&WCG addict
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    good luck with your project DVT :toast:
    DTV DRAGON says thanks.
  3. [Ion]
    [Ion] WCG Team Assistant
    Sep 15, 2009
    12,728 (6.21/day)
    12,858
    Raleigh, North Carolina, United States
    If you don't mind, could you get me a pic of the top so I can see how you mounted that 140mm rad?
    Crunching for Team TPU
  4. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    right now it is with Zipties i haven't had a chance to get to the store to buy screws but sure.give me awhile i got to charge the batts. left my cam on overnight :banghead:
    [Ion] says thanks.
  5. ToB1
    ToB1 New Member
    May 27, 2010
    44 (0.02/day)
    9
    Norway
    p_o_s_pc, nice build! Love the red and black theme! :)
  6. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    here you go Ion
    As you can see i have zipties holding it for now and i stuck some foam between the case and fan to seal it better and have less noise. Like i said it isn't done yet i still have to go alittle more cutting and get some screws and a 140mm fan grill.(PS the side isn't normally like that.)
    [​IMG]
    [​IMG]
    [Ion] says thanks.
  7. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    i found i way to clean up some wires.. more the HDD to the other side of the case.
  8. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    lets bump this thread up alittle.
    Here is the reason why you DON'T use dye
    [​IMG]
    Also i did alittle work on WM and mounted the rad the right way now.I still am trying to get WM done better it is slowly coming along. I think some holes need to be cut before things can look much better
    [​IMG]
    Chicken Patty says thanks.
  9. Chicken Patty
    Chicken Patty WCG Moderator Staff Member
    Nov 27, 2007
    28,341 (10.46/day)
    12,227
    Miami, Florida
    That first pic of the tubing looks crazy :eek:
    The WM looks much better, however I think if you cut a hole or two by the rad in the bottom you can pass some wires through there and connect them behind the tray. What do you think?
  10. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    i plan to do that and cut a hole in the bottom so i can flip the PSU over. Those 2 things would make a great difference... atleast i think they would..
  11. Chicken Patty
    Nov 27, 2007
    28,341 (10.46/day)
    12,227
    Miami, Florida
    They should! Question: How much space do you have between the radiator and the back tray?
  12. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    less then an inch.
  13. Chicken Patty
    Nov 27, 2007
    28,341 (10.46/day)
    12,227
    Miami, Florida
    damn I was thinking if you had more room, you can cut out a panel and put it flush against the rad. once you did that you can then hide your clutter behind it and just have the wires only showing when entering and exiting the panel. It would have looked great. However, with that much room don't think that is possible.
  14. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    thanks for an idea. I am thinking about getting some of the small hole modders mesh and putting it along the side of it there. I don't want a solid sheet of steel because its harder to work with and i think the mesh would look kinda cool and would help hide the mess. What do you think?
  15. Chicken Patty
    Nov 27, 2007
    28,341 (10.46/day)
    12,227
    Miami, Florida
    If you get mesh get one with very tiny holes. Why? one with bigger holes will show more. I had that issue once when using mesh. it was something I overlooked when buying.
  16. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    ahh yes the time has come again to update.
    Be nice.I ran out of paint before i could get another coat on the rads but i couldn't go a few days without crunching. on the note of crunching my chipset is running hot as hell i need to get a NBMax for it soon.
    [​IMG]
    [​IMG]
    [Ion] says thanks.
  17. looks nice, but don't ever consider being a professional spray painter or anything, lol.
  18. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    you saying my work sucks?
  19. i'm saying don't spray paint for a living lol.
  20. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    :nutkick:
    i don't plan to. just remember i know where you live :p you need to see it in person the pics can only tell so much
  21. i will, lol. My WM Is Ridiculous. I Just Redid It And Its Still Shit.
  22. DonInKansas
    DonInKansas
    Jun 2, 2007
    5,111 (1.77/day)
    1,294
    Kansas
    You registered specifically to talk smack here? Um, welcome to TPU or something........:shadedshu
  23. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    he is a local friend from around here. He is just messing around relax me and him are cool.
    thanks for having my back :toast:
    you need to let me get ahold of it sometime or we need to put our brains together to get something to look decent.
  24. Haha, I Wish It Was That Easy, With A $30 mATX Rosewill Case, Jesus Couldn't Do A Decent WM, But Maybe Your OCD Can, Maybe....
  25. p_o_s_pc
    May 2, 2007
    13,009 (4.46/day)
    2,183
    Newark ohio
    maybe it can. I about go crazy looking at my case because it looks like shit compared to what i am used to.
Share This Page
