water cooling... coolant choices
2,255 (0.38/day)
System Name HOMECOMPUTER
Processor Intel i9 - 9900k @ 5.1Ghz - 1.31v
Motherboard Asux ROG Maximus XI Hero Wifi
Cooling ek supremacy evo full nickle, 2xEK 360 Radiators, ek d5 pump/res combo, ek full cover 2080ti block
Memory 16GB DDR 3600 Trident Z RGB
Video Card(s) Gigabyte RTX 2080TI
Storage 1xWD black NVME 500GB, 1xSamsung 970 Evo Plus NVME 1TB
Display(s) 2 Dell Gaming 27" 1440P Gsync
Case Lian LI PC-011 Dynamic
Power Supply Evga P2 1200Watt
Mouse Zowie FK1+
Keyboard Corsair Strafe rgb silent
Benchmark Scores i'm working on that
so i put together my water cooling loop last night.. d-tek db1 pump, fuzion v2 block, 1/2"id-5/8"od hosing, swiftec quiet power 120.2 rad and a microres from swiftec.
so far everything is going fine... but i'm gonna have to choose a coolant as i'm sure just pure distilled water with no additives is going be be problematic as time goes on..
no i'm using a copper block and brass... i believe radiator(correct me if i'm wrong, it looks like brass). so i'm not worried about galvanic corrossion but i do need to find a proper coolant solution to minimize maintence and maximize cooling...
i'm at 28idle and 47 load during prime95 quad stress test.
tell me what coolants work for you and what i should be doing.. if you can suggest things taht can be bought at my local hardware/auto parts store that would be great. thanx a lot.
Yin
540 (0.08/day)
Processor Intel i7 920
Motherboard ASUS RAMPAGE II Extreme
Cooling CM v10
Memory Corsair 3 x 2GB TR3X6G1866C9DF
Video Card(s) Nvidia XFX 8800GT Stock
Storage Seagate ST3500320AS, 2 x Samsung HD103UJ
Display(s) 2408WFP
Case Corsair 800D
Power Supply Corsair HX750W
I'm pretty sure it isn't brass. (I could be wrong)
Don't they use aluminium and copper?
10,232 (1.70/day)
Austin Texas
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case SLIGER S620
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard RoyalAxe
prestone 50/50 pre-mixed antifreeze - been running it for years same pump, block, tubing... never had an issue. Never leaves residue either... just dont spill it... stuff never dries.
cdawall
where the hell are my stars
27,680 (4.27/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
i'm running pure water since the summer with PT nuke+green food coloring no issues at all
43,587 (6.72/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
You will rarely find water cooling products made from aluminum unless it's sold as a complete system using all aluminum. Aluminum and copper do not mix.
  • Like
Reactions: Yin
HammerON
The Watchful Moderator
8,397 (1.52/day)
Up North
System Name Threadripper
Processor 3960X
Motherboard ASUS ROG Strix TRX40-XE
Cooling XSPC Raystorm Neo (sTR4) Water Block
Memory G. Skill Trident Z Neo 64 GB 3600
Video Card(s) PNY RTX 4090
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard Corsair K70
For my system I use Koolance's "High Performance Coolant". Since I use Koolance blocks and the EXOS2 I decided to stick with their coolant.
Here is what they have in their coolant:
• Distilled Water: 70 wt%
• Propylene Glycol: 27 wt% (CAS #:57-55-6)
• Additives: 3 wt%
Here is some more useless mumbojumbo (at least to me):
• Boiling Point: 103ºC
• Vapor Pressure: 17 mmHg (20ºC)
• Volatility: not determined
• Specific Gravity: 1.03 (20/20ºC)
• pH: 7.3
• Solubility in water: Soluble in water at room temperature
Hope this helps:)
freaksavior
To infinity ... and beyond!
8,095 (1.28/day)
System Name ZeroUptime | M.A.S.S / MM1
Processor Xeon 2659 v3 / Xeon 2683 v4 / ARM A14
Motherboard Asus X99-E-10G WS / ASRock x99 usb 3.1 / Apple
Cooling NZXT Kraken / Noctua NH-L12 / Apple
Memory 16Gb DDR4 / 32Gb DDR4 / 16GB HBLM
Video Card(s) Powercooler ATI vega 64 / GT 7300 / ARM
Storage Samsung 970 512 Evo NVMe / A lot. / 256 + 512 External TB3
Display(s) Acer Predator X34 / Headless / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MMM1
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corais HX850 | Corsair TX750 / Internal 250w
Mouse g502 proteus core / Headless / g502 proteus core
Keyboard Corsair K95 Cherry Blue / Headless / K65 Cherry Red
Software Windows 10 / ESXI / Big Sur 11.2.2
i Do as well since we built are water cooling together. im using red die though :D
2,255 (0.38/day)
Mouse Zowie FK1+
thanx.. yeah i heard a lot of people speak out against using antifreeze because it's normally thicker then water and could kill a pump... apparently the m3n-ht does not have anything in the way of a cpu threshold shutoff but idk... i want safe because if the pump stops.. well i might be in trouble lol
2,255 (0.38/day)
Mouse Zowie FK1+
speaking of food coloring.. does it stain the res's and stuff??
freaksavior
8,095 (1.28/day)
spearman914
3,338 (0.57/day)
Brooklyn, New York 11223
System Name Mine | Dad + Mom
Processor E8500 E0 Wolfdale @ 4.6GHz 1.5V | E2180 M0 Allendale @ 3.0GHz 1.3V
Motherboard Asus Maximus Formula (X48) w/ Rampage BIOS | Asus P5Q Pro (P45)
Cooling Xigmatek Rifle HDT-S1283 w/ SFF21F Fan | Arctic Cooling Freezer 7 Pro
Memory G.Skill Pi Black 2x2GB 1.02GHz CL5 | OCZ Reaper 2x2GB 1.05GHz CL5
Video Card(s) Sapphire 4870X2 2GB 820/1020MHz | Sapphire 4850 1GB 700/1100MHz
Storage WD VR 150GB 10K RPM + WD 500GB 7.2K RPM | WD 200GB 7.2K RPM
Display(s) Acer P243WAID 24" 1920x1200 LCD | Acer V193W 19" 1440x900 LCD
Case Cooler Master HAF 932 Full-Tower | Antec Twelve Hundred Mid-Tower
Audio Device(s) Fatal1ty Xtreme Gamer w/ Z-5500 5.1 | On-Board Audio w/ S-220 2.1
Power Supply PC Power and Cooling 750W Non-Modular | Corsair HX-520W Modular
Software Windows Vista Home Premium X64 | Windows Vista Home Premium X64
Benchmark Scores Not Wasting Time!
2,255 (0.38/day)
Mouse Zowie FK1+
is it worth it.. cause some red food coloring would be badass..
freaksavior
8,095 (1.28/day)
Fitseries3
Eleet Hardware Junkie
15,508 (2.57/day)
Republic of Texas
distilled water is best possible coolant. adding anything to it just lowers its cooling ability.
freaksavior
8,095 (1.28/day)
how would food dye lower it?
2,686 (0.48/day)
Ohio
System Name JIM LAHEY
Processor CORE I9 9900K
Motherboard ASROCK Z390 TAICHI
Cooling COUGAR HELOR 360 AIO
Memory 32GB TRIDENT Z RGB DDR4-3200
Video Card(s) EVGA 3080Ti FTW3 ULTRA
Storage SAMSUNG EVO 1TB
Display(s) ASUS ROG STRIX 4K UG27UQR
Case THERMALTAKE VIEW 37
Audio Device(s) STEELSERIES ARCTIS 7 WIRELESS
Power Supply EVGA SUPERNOVA G+ 1000
Mouse STEELSERIES RIVAL 600
Keyboard STEELSERIES APEX 7 TKL
Software WINDOWS 10 ENTERPRISE
Benchmark Scores WUT
Agreed Im new to watercooling and was told By PaulieG to use Distilled water With Nuke :toast:
Fitseries3
15,508 (2.57/day)
Republic of Texas
yes. food dye stains really bad too. and it gums up in the fins of the blocks and in the pump
HammerON
8,397 (1.52/day)
Up North
Processor 3960X
I have replaced the coolant in my system several times because of hardware additions and subtractions (replacing E6600 with E8500, then adding two water cooled 4870's, and finally replacing with a GTX 295 (not water cooled)) and have not had a problem with staining. I find that the price for a bottle of coolant from a manufacture for $15.00 to be within reason and affordability.
Fitseries3
15,508 (2.57/day)
Republic of Texas
take apart your cpu block. i bet something will be in there depending on how long you've run the loop.
here is 1 month of UV blue feser dye in a GTZ...
i used about 10 drops in straight distilled water. nothing else.
HammerON
8,397 (1.52/day)
Up North
Processor 3960X
I really do not want to take my system apart to check! I guess I will have to take your word for it:toast:
DOM
7,628 (1.17/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
HammerON
8,397 (1.52/day)
Up North
Processor 3960X
Binge
Overclocking Surrealism
6,979 (1.23/day)
PA, USA
System Name Molly
Processor i5 3570K
Motherboard Z77 ASRock
Cooling CooliT Eco
Memory 2x4GB Mushkin Redline Ridgebacks
Video Card(s) Gigabyte GTX 680
Case Coolermaster CM690 II Advanced
Power Supply Corsair HX-1000
Silver "kill coils" are a method of treating your water through silver filtration. Silver has been a long time "biocide" and TBH I use it topically when I have stuff like pinkeye. It works. Right now I'm running silver water in my rig that I ionized myself. Silver Ionized water is just as good as silver biocidal tubing, or kill coils.
