Water cooling guide
Discussion in 'Overclocking & Cooling' started by Juggalo23451, Jul 14, 2011.
  1. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    Water Cooling Guide
    By Juggalo23451
    Video explanation link as well as where to get wc parts below the tutorial
    [​IMG]
    Well I have been water cooling for a lil over 2 yrs now so I would figure I would help and make a guide. So let's get started
    What is water cooling. More or less it is the same way how your car's radiator works to cool your engine except on a smaller scale .
    How much is it going to cost me- Depends on what you want to cool. The average coast for a cpu only loop is generally around 200-$$$. It will cost more if you want to add graphics cards, mosfets and etc. there is no real reason to water cool your ram,hdd. I don't see the point of water cooling your north bridge/south bridge either all it does is add restriction to your loop.If you want better temps on your chipset remove the old thermal paste with 90% Isopropyl alcohol or higher. Use a q-tip for this or a micro fiber cloth. Then put on new thermal paste like the ones listed below. but if you are going for insane overclocks go for it:)
    What parts are needed? I will tell you the parts and suggest some parts as well.
    Tubing and lingo you may see(get 10ft for cpu only,15ft or more if adding more rads blocks and etc:)
    [​IMG]
    The most common sizes for tubing for water cooling are
    3/8 inch
    7/16 inch-people use this size tubing on 1/2 barbs for a tighter fit/seal
    1/2 inch
    Lingo
    ID= Inner diameter
    OD= Outer diameter
    Primochill,tygon, masterkleer (budget)
    Use tub cutters, razor or scissors to cut the tubing.
    Dyes
    Do not use any dyes or additives. If you want color get colored tubing
    Reservoir ( always higher then the pump)- holds water
    [​IMG]
    For reses it is all about preference really, You have the Swiftech Micro revision res for like 20 bucks or you could spend up to 200 bucks on a res to.
    Pump(always below the res)
    [​IMG]
    check instructions to make sure you know where the inlet is and outlet- This is the whole heart of you water cooling loop. Pushes the water in you loop around. Getting the right pump is critical don't get the right pump may get poor flow in your loop/poor temps to. They are usually measured by gph(gallons per hour) The more gph the better.
    MCP355,MCP655, OCZ hydro flow(budget),jingway,
    Note: The mcp355(has 3/8 barbs) is slightly better than the mcp655(1/2 barbs)
    Pump top
    [​IMG]
    Dont want to use 3/8 barbs on a mcp355 get a top:) and choose what ever barb or compression fitting you like. Getting a op will help maximize the efficiency of the pump.
    (XSPC,EK)
    Water Blocks(center is always the inlet)
    [​IMG]
    There are great water blocks out there for the CPU and Gpus. If you are going for the absolute best one out there. Then the EK HF is the king right now. Ek is also the best for gpus as well.
    XSPC raystorm water block(budget) this block is behind the ek hf XSPC for gpus as well.
    Thermal Paste-
    [​IMG]
    MX3, MX4, OCZ Freeze, Shin Etsu, Indigo Extreme(the best but really expensive)
    Barbs-
    [​IMG]
    you will see g1/4 and g3/8. That is simply the thread size. What size barbs you get will depict on what size tubing you would want.
    bitspower, enzotech,koolance
    Compression fittings- Makes you loop look cleaner.
    [​IMG]
    Has two parts the barb and a collar. The collar goes on the tubing first. Then mount the tubing on the barb. Screw down collar all the way.(video below) make sure to get the same id and od fittings as your tubing
    Radiators(removes heat from you loop)-
    [​IMG]
    inlet/outlet does not mater
    Depending on what you want to cool will depend on the size of rad you want
    Example a 240 radiators can cool most cpus., 360 rad for cpu and a gpu
    Best rad right now is the GTX series radiators by Hw labs(loud setup)
    Best rad(low noise) RX series rads by XSPC or SR-1 rad by HW labs
    Budget rad Xspc ex
    P.s You can use a 77 Bonneville rad I believe if you wanted to.
    Fans(removes heat from the rad) and static pressure
    [​IMG]
    What is static pressure. It is the measurement of air to be push through a restrictive object. So the better the static pressure the better the fan for your radiator.
    Panaflo,delata, Kazes 120x120x38 are great for rads like the GTX
    Gentle typhoons (AP-15) are great for rad like the Sr-1 and RX series rads. Why you ask the noise to cfm is great and it has good static pressure as well.
    Yate Loons are a great budget fan a step up from yates will be the XSPC 1650rpm fans
    Fan Controller
    (controls the rpms of a fan)
    [​IMG]
    Want to quiet down your set up getting a fan controller can help with that:)
    Clamps (secure them in the center of the barb)-
    [​IMG]
    use clamps, zips, or worm clamps to secure your tubing
    Coolant- Distilled water is all you need.
    Pt nuke as well to prevent growth in your loop
    [​IMG]
    / or just get a
    silver coil.
    [​IMG]
    I have all the parts now what?
    1. Loop order, I usually do res-pump-rad-cpu-res for example, but you do not have to do that order just make sure you have the res before the pump
    2. Bust out a scratch piece of paper and pen. Draw a rectangle representing you case then. Draw another rectangle representing your mb. Location is key for a water cooling loop.
    Draw some sketches on how you want your loop to go.
    3. Mount everything up.
    4. Start from one point in your wc loop.with the tubing attached to a barb,
    take the excess and move it to the next point to your loop then cut.(Attach tubing)Repeat the process until you are done.
    5. Take out loop of you case(up to you)
    6. Hook the pump to your power supply(make sure nothing else is
    hooked up to the psu)
    7. Take a paper clip and put it in the green wire and connect any black wire. this will create a load to turn on your psu. Make sure the psu unplugged before doing this.
    8. Fill up the res with distilled water all the way to the top with a funnel
    9. Turn on the psu let the water go to about have way then refill the res.
    10. repeat the process again until you do not need to fill the res up any more
    Bubbles- To get rid of bubbles tilt your case side to side, back and forward
    Leak testing- I say a good 8-12hrs should be enough. You can do more if you would like.
    Hook up everything/install wc loop if outside of case and enjoy your temps
    Vids
    Water cooling basics
    http://www.youtube.com/watch?v=Xklgv4W9gFU
    How to set up and install a water cooling loop 4 parts
    http://www.youtube.com/watch?v=8qUqkX-3ut4
    Compression fitting
    http://www.youtube.com/watch?v=ZMg8Nqb0gc8
    Water Cooling Cases
    http://www.youtube.com/watch?v=Ciepz2O3QkA
    Where to get wc parts
    http://www.overclock.net/water-cooling/7848-stores-buy-watercooling-gear.html
    Dont feel like going custom get a XSPC Rasa Kit
    http://www.overclock.net/water-cooling/882408-official-xspc-rasa-750-rs-rx120.html
    If any additional help is need please feel free to pm me or ask a question here:)
    [​IMG]
  2. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    Pls feel free to suggest what you want me to add.
    Here is some info that you guys/gals may find help full on your water cooling adventure. Credit goes to skinnieelabs,Martin120, and bundymania
    rad comparison
    The Higher the Better the rad is.
    [​IMG]
    Pump comparison
    The higher the better
    [​IMG]
    Mcp355 top comparison
    [​IMG]
    Cpu blocks, The lower the better
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  3. Sinzia
    Oct 5, 2010
    861 (0.44/day)
    217
    I'll be watercooling my CPU soon, just need to get a rad, going with a single 120 for now, so that I can use it again in a later bigger build. I'll take some step-by-step pics and post them for you.
  4. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    Depending on your CPU a single 120 rad won't do. I also fixed the links/pics too
  5. Law-II
    Law-II
    May 9, 2011
    1,850 (1.07/day)
    859
    Mainland Britain
    Hi
    I do not see T line in your guide, very useful for draining a system or using as a "T Line reservoir" great if you do not have a lot of space in your case or are on a tight budget
    A section on what to do if things go wrong; if you spill distilled water on your components how to clean off the distilled water and dry the components would be helpful
    Using 90% Isopropyl alcohol to remove old TIM nothing wrong with this; however may be worth mentioning that you need to keep Isopropyl alcohol away from acetal which is used in the manufacture of some water blocks (it can on occasions cause the acetal to fail)
    hope this helps
    atb
    Law-II
  6. Law-II
    Law-II
    May 9, 2011
    1,850 (1.07/day)
    859
    Mainland Britain
    Hi
    If you attach a Delta PFC1212DE-PWM to the 120 rad, "anything is possible" as long as you have ear defenders ;) 66.5 dB(A)
    atb
    Law-II
  7. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    LOL that is true but I go for silence and performance.
  8. Law-II
    Law-II
    May 9, 2011
    1,850 (1.07/day)
    859
    Mainland Britain
    Hi
    I do too, could not resist a little tongue in cheek answer
    atb
    Law-II
  9. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    I do mention not to mix metals if you do that it will cause galvic corrosion. Also it does not warranties such as evga products.
  10. Law-II
    Law-II
    May 9, 2011
    1,850 (1.07/day)
    859
    Mainland Britain
    Hi
    noted; my bad on corrosion; Thanks for the info re: evga, I will edit my original post
    atb
    Law-II
  11. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    Crap I forgot about mentioning ek and the nickel plating issue.
    Here is the deal
    since then ek has halted all production of nickel plated products. I do not agree pt nuke or silver coil did this, plain and simple it is a poor plating job. There is a lot of proof out there.
  12. Sinzia
    Oct 5, 2010
    861 (0.44/day)
    217
    Way to only half read what I posted, The 120 is an interim step until I can get a larger case to hold everything.
    Besides, what about all those H50/60/70/90 users? Those are only 120's and hold thier own, and coming from an H50, I garantee that I'll be getting better temps than the H50.
    Also, the EK plating issue is (hopefully) a temporary thing, it might be beyond the scope of this guide.
  13. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    A venemous x can beat the h50. Also why would you get a a set up then te buy parts again that is just wasting money. Just get every thing you need first then get wc parts you need.
  14. Sinzia
    Oct 5, 2010
    861 (0.44/day)
    217
    because its a hobby, and I like to try new things.
    Besides, its not like I have a spare $500 to buy everything at once, and I have a planned use for the 120 after I'm done with the current case.
  15. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    Update on the EK nickel plating issue. The solution is Electroless Nickelplating.
  16. Hayder_Master
    Hayder_Master
    Apr 21, 2008
    5,204 (1.83/day)
    663
    IRAQ-Baghdad
    Nice work mate
  17. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    Thank you:)
  18. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    updated suggestions on cpu blocks and rads
  19. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    delete sorry for the double post
  20. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    more info added
  21. happy New Member
    Jun 22, 2011
    638 (0.38/day)
    25
    Nice thread, was looking for a thread like this or would have started a new one. :toast:
  22. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    No problem, I try to keep it up dated as often as I can
  23. Juggalo23451 New Member
    Jul 14, 2011
    78 (0.05/day)
    16
    Aurora,Co
    more info added all credit goes to martin
