Water cooling in Define R4
Discussion in 'Overclocking & Cooling' started by SamGriffiths, Jul 14, 2013.
  1. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
    Hey, so I'm looking into water cooling in a Fractal Design Define R4, I know I can fit a 240mm Rad in the front, I don't have any free Drive bays to put a Reservoir in so I would have to use an internal one.
    Is this okay for a loop:
    [​IMG]
    Red is the Pump
    Green is the Rad
    Blue is the Reservoir
    I think I'm going to use this as a Reservoir.
    https://www.overclockers.co.uk/showproduct.php?prodid=WC-320-BP&groupid=962&catid=2133
    And this as the Rad.
    https://www.overclockers.co.uk/showproduct.php?prodid=WC-044-BX&groupid=962&catid=1523&subcat=1525
    Or maybe getting this as a pump/reservoir combo:
    https://www.overclockers.co.uk/showproduct.php?prodid=WC-008-TL
    But I don't know about anything else, like the pump, the tubing (I would like so red tubing if possible) or the waterblock (I'm using 1150) I'm going to use, I think I could easily fit a 50mm thick rad due to the massive amount of space, any suggestions would be very helpful.
  2. james888
    james888
    Jun 27, 2011
    5,458 (3.23/day)
    2,828
    It would work. You do want the resiovor above the pump so make sure of that.
    I have rad in the same place and was able to fit a 80mm alphacool.
    SamGriffiths says thanks.
  3. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
  4. tigger
    tigger I'm the only one
    Mar 20, 2006
    10,200 (2.82/day)
    1,416
    I think rad-cpu-pump-res-rad is better, cool water straight from rad goes to cpu, but maybe it does not matter once the water temp reaches equilibrium.
  5. Grnfinger
    Grnfinger New Member
    Apr 20, 2008
    639 (0.22/day)
    214
    Canada
    this...
    loop order has no relevance
  6. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
  7. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
    Okay, I think I've made my mind up. I'm going to set up the loop as it is in the picture in my previous post, I'm going to use a XSPC RayStorm CPU block, XSPC HighFlex Hose 1/2" ID, 3/4" OD, XSPC D5 & XSPC Acrylic Tank Reservoir and 6x XSPC G1/4" to 1/2" ID, 3/4" OD Compression Fitting. Also for fans I'm going with NF-F12s I think, do I need to push/pull since the rad is so thick? Anyone know of some other fans that are as good and not so, erm, brown?:laugh:
  8. MT Alex
    MT Alex
    Aug 2, 2009
    3,980 (1.67/day)
    1,790
  9. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
    What about push/pull with BitFenix Spectre PRO PWM 120mm, I'm also thinking about maybe a 60mm Rad, I've been told there isn't much difference in performance at all.
  10. d1nky
    Jan 21, 2013
    3,803 (3.41/day)
    1,325
    ive got to stop looking at watercooling threads, that alphacool rad looks great. and fairly cheap!
    and that R4 looks a dream to work with, only thing id suggest is getting angled fittings. and make sure the hose doesnt get in the way of components.
    that diagram looks as the hose will run where the card will be and maybe get in the way of ram!
    a slight alteration will allow a cylinder res above the pump
  11. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
    Thanks, I've gone for a pump/res combo so the positioning isn't a problem, and I'm getting Corsair LP Ram so it's not a problem.
  12. MT Alex
    MT Alex
    Aug 2, 2009
    3,980 (1.67/day)
    1,790
    Pretty sure he was talking about the hose being in the way of your GPU, unless you don't have one, in which case I'd ditch the water cooling idea and get one.
  13. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
    Yeah, I'm getting a GPU, a Asus 760, I will just curve the pipe around it =P
  14. d1nky
    Jan 21, 2013
    3,803 (3.41/day)
    1,325
    hose, especially 1/2 inch stuff doesnt bend that easy, and it will want to bend the way its wants.
    thats why i put another route suggestion, plus its looks cleaner.
    the last thing you want is a hose resting against the card.
    and you can still add another res even if ya gone for the combo, more water is better.
  15. 20mmrain
    20mmrain
    Oct 6, 2009
    2,780 (1.20/day)
    828
    Midwest USA
    What I have found is this case fairly good for water cooling. I used an D5 XSPC Bay Reservoir and 2x EK 240XT radiators.... 1 in the top and 1 in the front.
    Here are pictures of my build before I added the second 240Xt rad upfront.
    The 240XT is really the largest rad you want in the case. It will still allow you to mover the HDD bay forward and therefore not have to go through the pain of hiding the HDD behind the Motherboard tray.
    I will try to take pictures of what my build looks like now with my second larger rad up front.
  16. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
    That looks really cool, I plan on mounting the HDD in the Optical Drive tray with a mount made by BitFenix.
    I'm thinking about maybe getting a 90 degree corner fitting and using that to round the GPU.
  17. Norton
    Norton WCG-TPU Team Captain
    Dec 21, 2011
    10,733 (7.09/day)
    28,945
    This is my R4 with a 240 rad up top and an extra 120 in the back just before I finished it up:
    [​IMG]
    *Note- didn't want to give up the front drive bays right now but there is plenty of room for another 240 if you pull them out
    SamGriffiths and Grnfinger say thanks.
    Crunching for Team TPU
  18. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
    Okay, I think what I'm going to do is get the loop I've posted, but with a XSPC RX240 and a single set of fans, then see if it's not preforming well enough, if it isn't I'll add another set of fan, but either way I think I'm going to totally remove my drive cages to make space for the pump. So this is what I'm going to be buying:
  19. Grnfinger
    Apr 20, 2008
    639 (0.22/day)
    214
    Canada
    That looks very nice and tidy, had no idea you could get that much rad in to that case.
    I'm looking for a small case to house my old MV Gene and 3570K, this might be it.
  20. Norton
    Dec 21, 2011
    10,733 (7.09/day)
    28,945
    Thanks! :)
    Wasn't the easiest thing I ever did but I did manage to get the 240 rad in there :eek:
    I like 20mm rain's pic with the extra 120mm in the front too (may be a future upgrade for me)...
  21. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
    Hmm, well, to set up this water cooling rig it would cost £350, right now I'm getting a GTX 760, with the money I would spend on water cooling I could get a GTX 780, or I could get 480GB of super fast SSD, it's a nice idea and it looks fun to do, but it costs to much and the risk of it leaking is there too, I think I'm just going to get a BeQuiet Dark Rock Pro 2 and be done with it.
    Maybe in the future, thanks for all your help though.
  22. Grnfinger
    Apr 20, 2008
    639 (0.22/day)
    214
    Canada
    leaks are nothing to worry about if done correctly.
    Water cooling can be carried from pc to pc so it's a long term investment, but yes it's a costly one.
    The raystorm kit is a good starter and can be added and modded to cool just about anything you can think of.
    The all in one coolers are a ok for medium overclocking or silent HTPC imo.
    Good luck in what ever you choose
  23. d1nky
    Jan 21, 2013
    3,803 (3.41/day)
    1,325
    i done my loop for about £180
    no leaks, no hassle (i lie) and its a great investment!
    but youre right, what ive spent and going to spend on water would get me a 7970 to xfire
    and all that thread and help for nothing, cmon lol
    [​IMG]
  24. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
    Yeah, I'm going to do it later =P, I think I'm just not going to overclock and keep the stock cooler until I can work up the extra money for the loop, thanks again guys.
  25. SamGriffiths New Member
    Jul 10, 2013
    58 (0.06/day)
    6
    Now, I've found a way to lower the price to £200 by getting a kit from XSPC, https://www.overclockers.co.uk/showproduct.php?prodid=WC-156-XS, what I'm going to do is buy a couple of Rotary Fitting, Compression Fitting and pipes that fit the Compressions. I'm also thinking about getting some Mayhems Pastel - Red Coolant 1L, has anyone used this stuff?
