- Apr 19, 2012
- 12,062 (2.75/day)
- Gypsyland, UK
System Name | HP Omen 17 |
Processor | i7 7700HQ |
Memory | 16GB 2400Mhz DDR4 |
Video Card(s) | GTX 1060 |
Storage | Samsung SM961 256GB + HGST 1TB |
Display(s) | 1080p IPS G-SYNC 75Hz |
Audio Device(s) | Bang & Olufsen |
Power Supply | 230W |
Mouse | Roccat Kone XTD+ |
Software | Win 10 Pro |
Now, I've found a way to lower the price to £200 by getting a kit from XSPC, https://www.overclockers.co.uk/showproduct.php?prodid=WC-156-XS, what I'm going to do is buy a couple of Rotary Fitting, Compression Fitting and pipes that fit the Compressions. I'm also thinking about getting some Mayhems Pastel - Red Coolant 1L, has anyone used this stuff?
I've got mayhems pastel white coolant, works fine, no sedement like crap within the piping, bit overpriced, but worth it for my colour theme, all comes pre-biocided too. The OCUK Raystorm 240kit is good value for money. I used it as a baseline and added to it. Pump/Res combo units are a great idea for cases with too many 5.25" bays like mine.
I'm going to replace most of my radiator fans with the 2.64 static pressure Bitfenix Spectres, so it goes with my case theme more. Current fans are just over 3.0 static pressure, though I have no issues with heat dissipation, so I'll +1 the bitfenix fans, they'll work just fine, just not as well as the higher SP fans out there like the stock H100 ones (I'm currently using).
