Water Cooling Kits/Systems
Discussion in 'Overclocking & Cooling' started by boecke, Jan 21, 2007.
  1. boecke
    boecke New Member
    Jan 8, 2007
    95 (0.03/day)
    0
    Well basically my system gets way too hot and the video card reaches around 70 degrees celcius under load (I'm getting a CrossFire card too so :Z), I want an effective and cheap cooling system (who doesn't?)
    It has to be a kit though, something like the ZALMAN ones but something a bit nicer.
    What do you guys think is the best system?
    Thanks guys,
    boecke
  2. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.83/day)
    3,778
    Dangerden
  3. Jimmy 2004
    Jimmy 2004 New Member
    Jan 15, 2005
    5,491 (1.47/day)
    267
    England
    I've heard dangerden is quite good too, but one quick thing: you do realise it's completely normal for a graphics card to get above 70C? Mine gets hotter than that, GPUs can run fine over 80C in most cases.
  4. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.83/day)
    3,778
    Yep, my X1800XT hits 74C with an Accelero X2 on it. Btw, if you have the money, I suggest Dangerden's full coverage gpu water block(s). Cools the gpu, ram and vregs.
Share This Page
