Water cooling loop < $200
Discussion in 'Overclocking & Cooling' started by MxPhenom 216, Aug 12, 2011.
  1. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    11,423 (5.73/day)
    3,254
    Seattle, WA
    I am just wondering if its possible to do a custom CPU water cooling loop under $200 For AMD or Intel.
  2. brandonwh64
    brandonwh64 Addicted to Bacon and StarCrunches!!!
    Sep 6, 2009
    19,229 (8.18/day)
    6,681
    Chatsworth, GA
    I would do a XSPC Rasa 120 Kit and be done with it. its technically a custom loop just all in one package that you put together. a friend has it on a X3430 and it cools great!
    Crunching for Team TPU
  3. sneekypeet
    Apr 12, 2006
    22,841 (6.35/day)
    7,402
    Are we looking retail or used....Used you can get one helluva kit for $200
  4. MT Alex
    MT Alex
    Aug 2, 2009
    3,980 (1.67/day)
    1,790
  5. MxPhenom 216
    Aug 31, 2010
    11,423 (5.73/day)
    3,254
    Seattle, WA
    well now that i know for used, lets go new what about the Rasa RX240?
    Would that be better then the Corsair H100
  6. sneekypeet
    Apr 12, 2006
    22,841 (6.35/day)
    7,402
    I just tested the H100 and its within a couple degrees of the Swifty H20 320 kit. Of course there is much less noise with the swifty kit than the H100 needs to get that sort of result.
  7. xbonez New Member
    Nov 29, 2010
    1,182 (0.62/day)
    315
    Philly, PA (US)
    I've personally used the XSPC Rasa RS240 on my Sandy Bridge build and had nice results with it. I had the 240mm radiator coupled with 4 really high CFM fans...i believe they were about 150CFM.
  8. sy5tem
    Nov 13, 2004
    449 (0.11/day)
    48
    Canada/quebec/Montreal
    its a better pump but not by much ...
    rasa 120 can cool 2600k with top end gpu in sli ..
    i changed pump from xspc to lang D5 vario .. and at dial speed of 4 .. temp stayed the same..
    full kits 240 360 or ticker rad ... in the ends doesn't really change temperature by much
    buy kit that fit in PC now and add rad later if needed..
    XSPC kits are ez to install
    EDIT: im using 240 rad with a 200mm fan and temp stablilize at 52 GPU and 70 for 2600k@4400mhz F@h 24/24
    10 Year Member at TPU
