Water Cooling loop for my 470
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
So i think im going to start saving for a water cooling loop for my 470 or 470 sli. however i think water cooling my 470 now would be better then when i get another i can just add that into the loop.
Heres what im looking at.
EK FC 470 Acetal block
Swiftech MCP355 w/ XSPC res combo
XSPC 360 rad
Compression fittings(if i feel like spending that money)
Distilled water and PT nuke
not sure what color tubing. Definitely dont want red. I was thinking White or black. Take a look at the picture of my computer here and tell which color you think would look the nicest.
NOTE: this picture is when i had a HD5870
43,587 (6.72/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Sounds like a perfect loop for two cards. I'd go with white or black tubing. :)
4,013 (0.75/day)
I think it would look very sharp if you could match your tubing to the color that shows through from your back panel. Or else paint the back panel so it is the same color as your tubing.
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
wait what?? im painting my backside panel black at some point
43,587 (6.72/day)
Storage WD m.2
Keyboard Tester84
Painting the back panel white (inside) with white tubing would look very nice.
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
i cant honestly picture that though looking good
43,587 (6.72/day)
Storage WD m.2
Keyboard Tester84
Just go with what you would think would look good. You're the artist in this situation and a case mod is a reflection of yourself in many respects. Do it how you would like it since you're the one looking at it everyday. ;)
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
yeah. i would like the contrast of the white though. if i put black in for the tubing it would be to much black
what about fittings. if compression fittings go over my budget what should i get??
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
This part. No matter what color you decide, it would look neat to match that part that shows through with the tube color.
http://img.techpowerup.org/100904/DSCN2454.jpg
yeah i guess. im kind of starting to see it now
whats the benefits of having a res pump combo instead of them separate? less restriction??
would i need a mcp655 pump if i added another block for a 2nd gtx470??
1,364 (0.26/day)
TX
System Name Beast
Processor Core i7 10700K 4.5GHZ 24/7
Motherboard MSI MPG Z490 Gaming Plus
Cooling Master Liquid 240
Memory 32 gigs DDR4 3600Mhz Gskill RipJaws
Video Card(s) AMD Raedon 5700XT
Storage 1TB Samsung NVME, Western Digital 4TB storage
Display(s) Dell UltraSharp 34" HD
Case Cooler Master HAF XB EVO
Power Supply EVGA 1000 Watt full modular
Software Win10 ENT 64Bit
I would just to be safe with the flow....
I have a swiftech micro res plus a mcp655 variable pump and a DD actel block (gtx470), plus a heatkiller cu on my i7 rig. It keeps everything below 50c NP running folding@home 24/7, with the pump on about 4 on the dial. But I have a XPSC extreme dual flow quad rad with 4 120mm fans also that cools the whole thing.
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
well ill look and see what hte price difference is
1,364 (0.26/day)
TX
System Name Beast
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
http://www.frozencpu.com/products/6...ered_Pump_-_DD-CPX1.html?tl=g30c107s155#blank
I got this one as my backup pump, only had to use it once but it works great and it has a nice price...:)
http://www.sidewindercomputers.com/swmc12vdcpuw.html
Great prices here also....
just how much better is the MCp655 compared to the MCP355 with res top?? will the flow really be that bad if i decide to go gtx470 sli?? because i dont really have $100+ just for a pump and res since if i got the mcp655 and put a res top on that it would be like $110
Bo$$
Lab Extraordinaire
5,656 (1.03/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
you need some ORANGE TUBING!
43,587 (6.72/day)
Storage WD m.2
Keyboard Tester84
A MCP355 will handle two GPU blocks and then some easily.
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
3,014 (0.54/day)
Northampton,UK
System Name Jaffakeik
Processor I9 12900K
Motherboard MSI Pro B660M-A WIFI DDR4
Cooling Arctic Liquid Freezer II High Performance CPU Water cooler- 240mm
Memory Corsair Vengeance LPX Black 32GB (2x16GB) 3600
Video Card(s) 7900XTX gigabyte OC edition
Storage WD Black SN770 1TB SSD M.2 2280 NVME x2
Display(s) TV LG C2
Case Phanteks Enthoo Pro 2 Full Tower Case Tempered
Audio Device(s) Mother board + Sennhiser HD650+ Elgato wave xlr + shure SM7B
Power Supply EVGA 1600w G+
Mouse Glorious Model 0
Keyboard Corsair RBG mini K65 + Steelseries Apex150
Benchmark Scores over 9000
i dont get people why put on some waterblocks on cpu or gpu when PC runs ok with air fans.Maybe less dust on hardware but I can do cleanings 1nc a month.its good only for OCers and a good air fan can do good OC aswell.So my conclusins are would never buy water cooling system for my PC.It taks time to set up it takse more space because of radiator who mostlly doesnt fit in case.so no
But your cooling loop looks cool. :)
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
okay well if you have been paying attention at all look at my system. i have a HAF 932. it can fit a 360 rad on the top internally. oh and mainly because my 470 has more room to go but temps are stopping it on air so id like to get some more overclock out of it and get it to run at 60c load which is what water cooling can do to a fermi card. obviously your living under a rock or you would know that.:rolleyes: (that sounded harsh but honestly)
i also dont mind it takes a long time to set up. its fun to do it
3,014 (0.54/day)
Northampton,UK
Processor I9 12900K
Display(s) TV LG C2
my 5850 cards dont step over 60 on load aswell and my cpu dont get over 46C aswell in games(what is pretty good i dont ned to be 30 or 22C it doesnt give a thing to performance) with air cooling so tell me whats better about your watercolling than my air cooling?And using air cooling it doesnt mean i live under rock.i got OC cpu to 4ghz and its more than enought,and for cards i dont need OC it doesnt give much effect anyways.if i run all games on max with my monitor.
43,587 (6.72/day)
Storage WD m.2
Keyboard Tester84
okay good! i like the size of it to. so small!
Yeah, I use a 355 with a XSPC res. top. I'm using 8 90 degree bends, two 120 rads, a 3x120 rad, a CPU block and a full coverage mobo block. Plenty of flow left! :D
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
my 5850 cards dont step over 60 on load aswell and my cpu dont get over 46C aswell in games with air cooling so tell me whats better about your watercolling than my air cooling?And using air cooling it doesnt mean i live under rock.i got OC cpu to 4ghz and its more than enought,and for cards i dont need OC it doesnt give much effect anyways.if i run all games on max with my monitor.
im not even on water yet. and you have 5850s those run cool already. seriously you dont pay attention to nvidia stuff apparently their fermi chips run pretty hot but not as hot as what it was made out to be at first but they still do run pretty high up there. and then you stick them on water and they will never break 50c at 850mhz which still pisses all over your 5850s. and overclock a GPUU actually does do a lot, but more with fermi cards because the scaling is a lot better.
thats pretty sweet dude. thats a crazy little pump
3,014 (0.54/day)
Northampton,UK
Processor I9 12900K
Display(s) TV LG C2
ok mate no means of arguing about that,I just said my thoughts about watercooling and thats all.no offense to you.
