water cooling loop
onepost
158 (0.03/day)
san diego
System Name theshizzle | thepizzle
Processor i7 930 @ 4.1 | 1055t @ 3.6
Motherboard p6x58d premium | gbyte 785m ud2sh
Cooling custom h20 | h50
Memory corsair xms3 8-8-8-24 | corsair 5-5-5-15
Video Card(s) 5870 @ 1000core/1250mem | onboard 4200
Storage ocz vertex 60 ssd / 1tb 7200.11 | 600gb
Display(s) asus 23 1080p | samsung un40b6000
Case haf932 | lian li
Audio Device(s) onboard | onboard
Power Supply corsair 950tx | bfg mx680
you have two rads? i'd say pump -> rad1 -> cpu -> rad2 -> gpu -> (res)pump
2,894 (0.50/day)
South Carolina
System Name KILLER
Processor Intel Core i7 4790K
Motherboard MSI Z87 G45 Gaming
Cooling Water Cooling
Memory 2x8GB Gskill 2400mhz
Video Card(s) EVGA GTX 980
Storage SSD Samsung 500GB
Display(s) 24" Asus 144hz
Case Cooler Master HAF
Audio Device(s) X-Fi Platinum
Power Supply Antec 1200 Watt Modular
Software Windows 10 64 Bit
Benchmark Scores 3DMark Vantage 51342
43,587 (6.71/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
what would be the best order for the loop i have to radiators cpu and gpu on the loop ?
What cpu and gpu are you using? Also, what radiators, pump and block are you using? Really the best order is pump-rads-blocks-reservoir-pump.
Naekuh
503 (0.09/day)
Miko Fox? Fire Miko? Its FireFox-Tan!
System Name Nadeshiko
Processor i7 980X @ 4.2ghz /w HT ON 24/7
Motherboard eVGA Classified E759
Cooling Custom H2o
Memory Corsair Dominators 6 x 2GB
Video Card(s) 2 x HD4870X2 in Xfire
Storage 3 x X-25V in Raid 0 (OS) + 3 x Raptors in Raid 0 (Game)
Display(s) Dual Gateway 2485
Case MM U2
Power Supply Ultra 1.6KW
Software Win7
the shortest route is always the best route.
Unless your applying it to a res.
Then its always res before pump.
Other then that, flow is uniform, temperature should also be @ equalibium throughout your loop unless you have very very poor flow, so u go for the shortest loop.
