water cooling loop
Discussion in 'Overclocking & Cooling' started by vega22, Jan 15, 2008.
  1. vega22
    vega22
    Jul 18, 2007
    2,162 (0.69/day)
    539
    how does this look for a setup?
    Danger Den MC-TDX Intel 775 Block - Barb Size 1/2" Nickel Plated
    Danger Den MPC-Universal Chipset Block - Barb Size 1/2" Nickel Plated
    Danger Den Delrin/Acetal T Fitting - Barb Size 1/2" Nickel Plated
    XSPC Dual 750 Bay Reservoir Pump - Clear - Barb Size 1/2" Nickel Plated
    Black Ice GT Stealth II - Barb Size 1/2" Nickel Plated
    Mikalor Wormdrive Clip 1/2" (10 Pack)
    Mikalor Wormdrive Clip 1/2" (x 5)
    1/2" Blue/UV Blue High Flex Hose (XSPC) - Hose Length 5 Meters
    just for the cpu and nb for now, just under £165 for the lot.
    im thinking about modding the roof of my case, fitting the rad on the top under the grill and the fans on the inside with holes drilled so the loop is all internal.
    parts from http://www.watercoolinguk.co.uk/ so if you know of anywhere better in the uk im interested as i am for better parts for the price.
    all and any imput welcomed :toast:
  2. EnergyFX
    EnergyFX New Member
    Nov 22, 2007
    1,554 (0.52/day)
    340
    Annapolis, MD
    There are better performing CPU Blocks on the market. Look into Swiftech, D-Tek, and EK Waterblocks. Those three are, from what I've read, the best performing.
    vega22 says thanks.
  3. intel igent
    intel igent New Member
    Jun 5, 2005
    4,641 (1.19/day)
    428
    Toronto, Canada
    Looks good I would however go with a triple rad off the bat check out chilledpcs.UK or head over to Xs and have a look @ maxxxracers where to buy guide
    vega22 says thanks.
    10 Year Member at TPU
  4. vega22
    vega22
    Jul 18, 2007
    2,162 (0.69/day)
    539
    i can only fit a double on my case, well im not 100% sure about that but i think i can make one fit with a bit of dremmling.
    i have this
    [​IMG]
    in my roof so i plan to cut away the plastic of the top cover so all thats left is the vent and if pos cut 2 holes to the right on the pic so i can run the tubes into the rad from the inside and keep it all internal. this will give me the option of adding another single rad later to the rear 120mm fan for my gpu if it needs it (read when i can afford it :D )
    reviewfor case
    off looking :D
  5. EnergyFX
    EnergyFX New Member
    Nov 22, 2007
    1,554 (0.52/day)
    340
    Annapolis, MD
    I'm confused about your res/pump choice. I can't find what you are referring to.
