Water Cooling Or Good Fan Heat Sink
sinister_steve
475 (0.08/day)
canada kamloops
System Name fun box
Processor PHENOM 9850 BE
Motherboard M3A32-MVP DELUXE WIFI
Cooling ANTEC 900
Memory 4 GIG DDR2+
Video Card(s) 2X ASUS 4850
Storage 160GIG
Case ANTEC 900
Audio Device(s) MAKES MUSIC AND THINGS PLAY
Power Supply 650 ANTEC
Software WIN XP
Benchmark Scores 15239
Hi all im not overly wanting to get watercooling but I do want to overclock my 9850 phenom..So is there any good hs fans out there that would bring temps down enouph to do a good overclocking ? my phenom idles at 52c and load gets up to eround 64c..and yes ive used different greece and whats on there now is arctic something er other..Ok can some one help me out here..Thanks/;'';Steve:roll:
sneekypeet
Retired Super Moderator
29,409 (4.47/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
What cooler are you using now, stock?
3,288 (0.51/day)
Halifax, Canada
Processor Q6600 G0 @ 3.2Ghz
Motherboard Asus p5k-Premium/Black Pearl
Cooling Luna Block, 240mm rad
Memory Patriot Extreme PC2-6400 2x2GB
Video Card(s) Saphire 5850 1GB
Storage 60GB SSD + 2x500GB/1TB/2TB
Display(s) Samsung 226BW and 50" Panasonic S2
Case Silverstone TJ-09
Audio Device(s) X-fi Prelude
Power Supply Enermax Galaxy Dxx 850watt
Software Windows7 32Bit
Benchmark Scores Super Pi 1M 14.333
17,794 (2.66/day)
sinister_steve
475 (0.08/day)
canada kamloops
System Name fun box
Cooling ANTEC 900
Memory 4 GIG DDR2+
Storage 160GIG
Case ANTEC 900
Software WIN XP
43,587 (6.72/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
I like either the Xigmatek r1283 with the retention bracket, or a Zalmann 9700. Both work wonderfully on my M3a32mvp.
sinister_steve
475 (0.08/day)
canada kamloops
System Name fun box
Cooling ANTEC 900
Memory 4 GIG DDR2+
Storage 160GIG
Case ANTEC 900
Software WIN XP
ok so will they bring temps down enouph to oc even with it beeing so damn hopt in my house?
K
kyle2020
i wouldnt recommend watercooling unless you have a decent ammount of money and space - i purchased a cheap kit known as the thermaltake bigwater 735, absolute waste of time. It cooled fine, dont get me wrong, but i hated the looks of it because i couldnt mount the radiator internally (damn antec) so i had tubes everywhere. It just looked . . . well, messy. I dont discourage watercooling, but i just think that money wise your better off buying an air cooler, like a xigmatek or something.
Just my two cents haha.
sinister_steve
475 (0.08/day)
canada kamloops
System Name fun box
Cooling ANTEC 900
Memory 4 GIG DDR2+
Storage 160GIG
Case ANTEC 900
Software WIN XP
I cant get the xig here but I can get the Zalmann 9700...so I think I will get it if it will cool temps in a 40c temp in my house..Steve:roll:
43,587 (6.72/day)
Storage WD m.2
Keyboard Tester84
Good choice!:)
K
kyle2020
the 9700 is a good looking cooler - i was originally going to get one but i have too much blue going on in my case. Have you seen the Nvidia limited edition one? its silver with green LED's *ooooohhhhh!* haha. Looks nice too.
3,288 (0.51/day)
Halifax, Canada
sinister_steve
475 (0.08/day)
canada kamloops
System Name fun box
Cooling ANTEC 900
Memory 4 GIG DDR2+
Storage 160GIG
Case ANTEC 900
Software WIN XP
sneekypeet
29,409 (4.47/day)
System Name EVA-01
Any air cooler will not cool below ambient temps, so if the room is 40*C, that is the lowest the CPU would idle at!
sinister_steve
475 (0.08/day)
canada kamloops
System Name fun box
Cooling ANTEC 900
Memory 4 GIG DDR2+
Storage 160GIG
Case ANTEC 900
Software WIN XP
hmmm thats no good..damn it...
sneekypeet
29,409 (4.47/day)
System Name EVA-01
sinister_steve
475 (0.08/day)
canada kamloops
System Name fun box
Cooling ANTEC 900
Memory 4 GIG DDR2+
Storage 160GIG
Case ANTEC 900
Software WIN XP
Yeah you may want to take the cooler funds and put it into a used Aircondioner for the room!
Ya im starting to think so hahahahaha..Thanks guys...Steve
EastCoasthandle
6,885 (0.99/day)
System Name MY PC
Processor E8400 @ 3.80Ghz > Q9650 3.60Ghz
Motherboard Maximus Formula
Cooling D5, 7/16" ID Tubing, Maze4 with Fuzion CPU WB
Memory XMS 8500C5D @ 1066MHz
Video Card(s) HD 2900 XT 858/900 to 4870 to 5870 (Keep Vreg area clean)
Storage 2
Display(s) 24"
Case P180
Audio Device(s) X-fi Plantinum
Power Supply Silencer 750
Software XP Pro SP3 to Windows 7
Benchmark Scores This varies from one driver to another.
One thing you need to do is control ambient temps in the room where your PC resides in. When you figure out a way to lower ambient temps in that room you have some control over your CPU temps.
When obtaining a better HSF and decent thermal compound you can further reduce CPU temps if the OEM HSF and thermal compound isn't effective. But the 1st thing IMO are ambient temps. I have found that an ideal room temp of 25C or lower is ideal. If you are not able to lower ambient temps a new HSF & thermal compound may decrease temps from an inefficient setup but it will never be lower then ambient temps.
sinister_steve
475 (0.08/day)
canada kamloops
System Name fun box
Cooling ANTEC 900
Memory 4 GIG DDR2+
Storage 160GIG
Case ANTEC 900
Software WIN XP
ok cool..will try and lower temps in my house first ahhaha...and then go with the zalman hsf..Thanks..Steve:pimp:
