Water Cooling Question
Discussion in 'Overclocking & Cooling' started by Eroticus, Mar 17, 2014.
  1. Eroticus
    Eroticus
    Apr 5, 2010
    273 (0.14/day)
    74
    Israel
    How to connect tubbing to this one :p
    http://www.frozencpu.com/products/1...ck_BP-MBDR-C.html?id=tjUKqrHk&mv_pc=153#blank
    or this one
    http://www.frozencpu.com/products/1...te_Black_BP-MB90R2.html?id=X6DzDffC&mv_pc=267
    D:
    [​IMG]
    Or i should by this ones ?
    http://www.frozencpu.com/products/1..._Black_BHF-G14-14.html?id=tjUKqrHk&mv_pc=5652
    I just bought everything that frozen-cpu guy said :p
    but i think he missed something..
    Thanks ...
    Part #Product DescriptionQtyPriceTotal
    ex-tub-747Bitspower G1/4 Anti-Twist Rotary Extender / Adapter - Matte Black (BP-MBDR-C)8$9.99$79.92
    ex-blc-1224EK Supremacy ELITE CPU Liquid Cooling Block - Full Nickel - Socket 2011 w/ Indigo Xtreme (EK-Supremacy Elite - Intel 2011)1$121.99$121.99
    ex-res-433EK-MultiOption RES X3 400 - Liquid Cooling Reservoir (6 Total Ports)1$64.99$64.99
    ex-pmp-261EK DDC X-Top w/ 3.2 PWM DDC Pump - Acetal (EK-DDC 3.2 PWM X-TOP CSQ - Acetal)1$104.99$104.99
    ele-11974-Pin Molex / SATA Power Distribution PCB 8x PWM + 2x 4-pin Block (MMT-PCB-4-8P2M1S)1$9.99$9.99
    ex-tub-743Bitspower G1/4 Thread 90-Degree Dual Rotary Adapter - Matte Black (BP-MB90R2)2$14.99$29.98
    ex-rad-677XSPC RX480 Quad 120mm Radiator V3 - Matte Black1$122.99$122.99
    ex-tub-1602PrimoChill PrimoFlex Advanced LRT Tubing 1/2"ID x 3/4" OD - Brilliant UV Blue (PFLEXA-34-B)15$2.75$41.25
    ex-liq-203Ice Dragon Cooling Nanofluid Coolant White Color - 32oz3$29.99$89.97
    ex-tub-743Bitspower G1/4 Thread 90-Degree Dual Rotary Adapter - Matte Black (BP-MB90R2)6$14.99$89.94
  2. Breew New Member
    Mar 17, 2014
    22 (0.04/day)
    5
    Eroticus says thanks.
  3. Eroticus
    Eroticus
    Apr 5, 2010
    273 (0.14/day)
    74
    Israel
  4. Breew New Member
    Mar 17, 2014
    22 (0.04/day)
    5
  5. Henkenator68NL
    Henkenator68NL
    Nov 10, 2013
    40 (0.06/day)
    29
    Near the waddensee in the Netherlands
    Did you make a drawing of the setup you are aiming for ?
    That always helps me plan loops and what parts to order. See attachment.
    night.fox says thanks.
  6. night.fox
    night.fox
    Dec 23, 2012
    1,112 (1.13/day)
    656
    south korea
    hmmm it helps alot thanks.
  7. the54thvoid
    the54thvoid
    Dec 14, 2009
    4,202 (2.01/day)
    2,651
    I approve of those Noctua fans, I have 6 on two 360 Watercool HTSF2 rads. :rockout:
  8. Henkenator68NL
    Henkenator68NL
    Nov 10, 2013
    40 (0.06/day)
    29
  9. the54thvoid
    the54thvoid
    Dec 14, 2009
    4,202 (2.01/day)
    2,651
    Well, I run a i7 3930k at 4.4GHz and about 1.39v (it needs it) and my Titan at 1.21v for 1.136GHz core and 6.7GHz memory. The profile is through the cpu fan header and runs at about 600-800rpm (40-60%). Temp on cpu max at about 60-65 after 2-3 hours of BF4 and 45 degrees on graphics.
    Yup, German radiators and Austrian fans = very cool and very quiet. :clap:
Share This Page
