water cooling question
Discussion in 'Overclocking & Cooling' started by AthlonX2, Nov 18, 2006.
  1. AthlonX2
    AthlonX2 HyperVtX™
    Sep 27, 2006
    7,135 (2.51/day)
    1,642
    ok i was wondering if it makes a difference in temps on the way you run your tubing when setting up water cooling for example right now i have it setup to go from the reservoir to the pump the the cpu block to the radiator and back,would it make a difference if i ran it from the pump to the radiator then to the block and back? im not sure how much heat the pump creates but im trying to get the coolest possible liquid to the block and i figured if i cooled it through the radiator just before it went to the block it might help,any cooment or helpful tips?
  2. beachbum86
    beachbum86 New Member
    Sep 29, 2006
    102 (0.04/day)
    0
    Oh no, last time i listed this a dude showed up at
    After a while, the full loops temp evens out... there MIGHT be a 0.5 degree difference after the radiator...
    But to answer your question..it doesnt realy matter.
  3. AthlonX2
    AthlonX2 HyperVtX™
    Sep 27, 2006
    7,135 (2.51/day)
    1,642
    ok then i think i will same myself sometime and leave it as is
  4. gR3iF
    gR3iF New Member
    Mar 26, 2005
    1,807 (0.53/day)
    35
    Hamburg
Share This Page
