Water cooling sprung a leak, need help!
Discussion in 'General Hardware' started by ChizzY, Apr 29, 2014.
  1. Nabarun
    Nabarun
    May 25, 2013
    455 (0.41/day)
    108
    Kolkata, India
    I seriously think he shouldn't put ANY water or alcohol or even try to dry the parts. He's highly likely to do more damage.
    @ChizzY did you do the swap-and-revert bit with the CMOS_clr jumper after taking out the battery? And check the front panel headers? If that didn't work, then you should really get someone more experienced to do the cleaning and drying bit, before contacting Asus for repair.
  2. fullinfusion
    fullinfusion 1.21 Gigawatts
    Jan 11, 2008
    8,817 (2.88/day)
    2,535
    After reading this thread I think chizzy is trolling ya all hmm?
    Would make a good April fools joke for sure ;)
    But if....... Nah :lovetpu:
    d1nky and ThE_MaD_ShOt say thanks.
  3. Nabarun
    Nabarun
    May 25, 2013
    455 (0.41/day)
    108
    Kolkata, India
    It's almost May. So I don't think he's kidding. He may be a real kid imho.
  4. 9700 Pro
    9700 Pro
    Dec 16, 2012
    675 (0.54/day)
    408
    Jyväskylä, Finland
    I'd also think that custom watercooling isn't what I would recommend to a beginner.
    I've built PC's over 10 years and I still haven't built a custom loop, and if I would build one, I would read some really good instructions and other kind of stuff.
  5. eidairaman1
    Jul 2, 2007
    14,544 (4.47/day)
    2,182
    he needs to bench run the system, possibly dip them in rice then blow off all dust
  6. d1nky
    Jan 21, 2013
    3,803 (3.11/day)
    1,325
    lol i meant tap water in the loop, i would use some kind of alchohol to wash the mobo.
    but thats as a last resort!
    fullinfusion says thanks.
  7. fullinfusion
    Jan 11, 2008
    8,817 (2.88/day)
    2,535
    Ok I'll give him the benefit of of doubt and suggest a proven way to have a possible fix. Go buy a few gallons of distilled water and fill the kitchen sink with it. Soak the board and gently agitate the board to loosen any crusty shit hiding in the slots then remove. Wave the board around to rid all the water you can and get a big ass box of rice, yes I said rice and dump it in a big bag then place the mono inside the bag and tie it up and let it sit for 2-3 days and I garrentee the board will be not only clean but totally dry, inside and out.
    Also works magic on cell phones when your sitting on the shitter checking out you face book and the second thing going ploOp into the water is your phone ;)
    Solaris17 says thanks.
  8. Solaris17
    Solaris17 Creator Solaris Utility DVD
    Aug 16, 2005
    18,223 (4.63/day)
    4,492
    Florida
    He could use sensor cleaner. I used some 3 days ago on a 2011 board that came in with thermal paste all inside the socket. Iv used that trick for a few years to get harder stuff contact cleaner or sensor cleaner like for car MAF sensors is super easy and cheap to get at any auto parts store its safe on plastics it dries almost immediately and it doesn't leave residue. Not top mention it melts away all our little sins. like the coolant that is currently corroding his pci-e pins.
    http://www.autozone.com/autozone/ac...-sensor-cleaner/_/N-255s?itemIdentifier=36011
    ^ veteran to water cooling leaks (dont put alcohol in acrylic loops)
    this too. I actually have pictures of me washing a macbook pro mobo that had coffee spilled on it. I used dawn dish soap hot water (from a coffee maker) and a tub (I also for good sport put a rubber duck in it) used a tooth brush and cleaned it. done that with 3 or so boards all worked.
    10 Year Member at TPU More than 25k PPD
  9. Sasqui
    Sasqui
    Dec 6, 2005
    8,642 (2.26/day)
    2,638
    Manchester, NH
    I would completely stay away from Alcohol. There are too many things on a motherboard that could possibly be dissolved by such a strong solvent, I've ruined one or two things using it (non computer related items). Water is gentle and what the Feser 1 uses as a base (AFAIK).
    10 Year Member at TPU Crunching for Team TPU
  10. eidairaman1
    Jul 2, 2007
    14,544 (4.47/day)
    2,182
    Contact cleaner id say. I wonder if the compounds of map/maf sensor and contact cleaner are the same...
  11. Solaris17
    Aug 16, 2005
    18,223 (4.63/day)
    4,492
    Florida
    Not sure I literally used MAF cleaner a few days ago and iv used it before it will work fine contact the cleaner can be harder to find
  12. Ferrum Master
    Ferrum Master
    Nov 18, 2010
    2,516 (1.25/day)
    1,217
    Rīga, Latvia
    Not at all, any electronics ware store. Or farnell/mauser/digikey etc
    http://uk.farnell.com/cleaners
  13. erocker
    Jul 19, 2006
    41,205 (11.44/day)
    16,396
    I've never had an issue using alcohol on a computer. Yes, Feser 1 uses water as a base, but that's all supposed to stay inside the tubing.
    I use electronics cleaner at work and the main ingredient in all of them is alcohol.
  14. Solaris17
    Aug 16, 2005
    18,223 (4.63/day)
    4,492
    Florida
    in latvia? Im not sure id really wait to ship a can across the ocean.
