Water Cooling Tubing Question......
Discussion in 'Overclocking & Cooling' started by 20mmrain, Dec 31, 2010.
  1. 20mmrain
    20mmrain
    Oct 6, 2009
    2,776 (1.30/day)
    827
    Midwest USA
    Alright guys I got my Water cooling system up and running. It works wonderfully and with no leaks. It dropped my temps by an average 15c to 20c While overclocking and stress testing.
    Heres my Question though..... my Bard Size that came with this water cooler is G1/4" to 1/2" barbs x6. Since my Cooler Came in a Kit it came with 7/16" ID x 3/8" OD Tubing.
    But I would like to switch over to some 1/2" Tubing because of the fact that 7/16" is hard to find locally.
    Would this cause any problems???? If so what would be some other suggestions of sizes that I could use? With out hindering Flow or worries of the tubing slipping off?
    Sorry if this is a noob question but I have always had hard time visualizing sizes. :toast:
  2. 20mmrain
    20mmrain
    Oct 6, 2009
    2,776 (1.30/day)
    827
    Midwest USA
    I after looking around the net it should be fine using 1/2" Tubing but.... I didn't know if there is some cardinal rule of water cooling that I don't know about that say's it is wiser to use a smaller Diameter tubing on a larger barb????
  3. mrsemi
    May 22, 2007
    659 (0.22/day)
    67
  4. oily_17
    oily_17
    Sep 25, 2006
    2,313 (0.71/day)
    670
    Norn Iron
    20mmrain says thanks.
  5. Loosenut
    Loosenut
    Jan 14, 2010
    875 (0.43/day)
    186
    Granby, Qc. Canada
    G1/4" is the thread size on the barb, 1/2" is the barb size in question.
    7/16" is bigger than 3/8"... You may want to remeasure that one. ;)
    I only use 3/8" ID x 1/2" OD tubing and IMHO, the advantage 1/2" would bring over 3/8" is so small, it isn't really worth the extra expense. Also for the looks, in a mid case, your 1/2" tubing would look enormous and end up looking cluttered.
    My 2 cents
  6. 20mmrain
    20mmrain
    Oct 6, 2009
    2,776 (1.30/day)
    827
    Midwest USA
    Thanks for the input bud I appreciate it.... BTW Nice setup if it's yours..... These are the clips I have now.....
    [​IMG]
    Will they do????
    Also here is a new pic of my set up before I rearrange it for one last time :)
    [​IMG]
    and
    [​IMG]
  7. MT Alex
    MT Alex
    Aug 2, 2009
    3,894 (1.78/day)
    1,704
    I love your sleeving.
    Those clips will work fine.
    For form and function, I like these babies:
    [​IMG]
  8. 20mmrain
    20mmrain
    Oct 6, 2009
    2,776 (1.30/day)
    827
    Midwest USA
    Yeah sorry for the double post..... I said 3/8" God I am having a typing problem today.... Sorry I meant 5/8" .... See what I mean though.... I have a hard time picturing Sizes.
    As far as the Mid case though.... while I do have a mid tower case I also have the CM Sniper case. Which should have been really called a full tower.... this thing is huge. But you might be right..... I wonder if anyone here had a Sniper case with 1/2 Tubing in it???
  9. 2wicked
    2wicked
    Jul 13, 2008
    264 (0.10/day)
    95
    Directly above the center of the Earth
    Loosenut says thanks.
Share This Page
