Watercooling and lowering my 4770k Temps
1,104 (0.18/day)
Florida
System Name Blackwidow/
Processor Ryzen 5950x / Threadripper 3960x
Motherboard Asus x570 Crosshair viii impact/ Asus Zenith ii Extreme
Cooling Ek 240Aio/Custom watercooling
Memory 32gb ddr4 3600MHZ Crucial Ballistix / 32gb ddr4 3600MHZ G.Skill TridentZ Royal
Video Card(s) MSI RX 6900xt/ XFX 6800xt
Storage WD SN850 1TB boot / Samsung 970 evo+ 1tb boot, 6tb WD SN750
Display(s) Sony A80J / Dual LG 27gl850
Case Cooler Master NR200P/ 011 Dynamic XL
Audio Device(s) On board/ Soundblaster ZXR
Power Supply Corsair SF750w/ Seasonic Prime Titanium 1000w
Mouse Razer Viper Ultimate wireless/ Logitech G Pro X Superlight
Keyboard Logitech G915 TKL/ Logitech G915 Wireless
eagle eye
i didnt noticed
@springs113
check your gpu connection before
and new photos few post above
I agree. looks like its in and out without going through it... usually in is on one side, and out is on the other.
I didn't even realized that I did that omfg now I gotta go pull that ish up.
43,586 (6.72/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
You're welcome. :)
1,104 (0.18/day)
Florida
this baby took my attention off of it for one sec and bam...omg
1,104 (0.18/day)
Florida
Ok fellas, time to put it to the test.AGAIN
GPU is Normal. And so far my PC has been idling at the previous temps before splitting the AIO...with the case open max temp on the gpu is 40 and cpu is 50. Going to close everything up now and see the results.
1,104 (0.18/day)
Florida
can I run this res like this?
4,013 (0.75/day)
Sure, but it will be hard to fill the loop with the fill port being unreachable that way, unless you put in one of these like I did:
But even then it would be hard to plumb one of those in in that location.
43,586 (6.72/day)
Storage WD m.2
Keyboard Tester84
I think you could just unclip the reservoir and get a funnel in there without too much issue. The mount isn't permanent... Which makes me think I should probably go with the clips instead of the bottom mount on mine when I get them.
1,104 (0.18/day)
Florida
I can get to it fine. in fact I have already poured in the amount that was in there before.
It sure as hell is to fill the top rad. I kind of wish I had bought a swiftech 320 rad w/a fill port like what comes with the h220.
1,104 (0.18/day)
Florida
Well I took out the entire loop, now that i have done that it seems to me that the noise in the loop is now gone, the air seems to have disappeared and now my rig seems like it is running the way it was meant to. Not only that my gpu idles around 25 degrees now and my cpu maxes around 55.
453 (0.11/day)
St. Louis MO
System Name Devil Red
Processor Intel i7 3820 @ 4.7GHz
Motherboard ASUS Rampage IV Formula x79
Cooling Water cooling CPU, MOSFET,SLI GTX 690
Memory Corsair 32GB DDR3 1866 MHz
Video Card(s) (SLI) ASUS GTX 690
Storage 120GB Corsair SSD/WD 300GB VRaptor
Display(s) HP ZR30w Pro 30" LCD
Case Corsair 900d Modded
Audio Device(s) X-FI
Power Supply Corsair AX1200i
Software 3DsMax, Maya, ZBrush, Photoshop Master Collection, and some more software
How you like the case? I been busy with work and life so have not been on here much and posted pics of my computer yet. I can post this one...me just having fun in the new Apache flight helmet. After I had it on I learned it is worth 500K USD because it is a prototype......:)
1,104 (0.18/day)
Florida
[url]http://i188.photobucket.com/albums/z220/Hunter_May09/IMG_2785_zps15754a75.jpg[/URL]
Cool, I need a suggestion on lighting, help? I still need 2 more fans for my top rad and gonna get me a fan switch preferably the swiftech pwm fan controller like the ones that c.ome with the h220/320
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
