Watercooling parts help
Discussion in 'Overclocking & Cooling' started by springs113, Aug 15, 2014.
  1. Shambles1980
    May 3, 2014
    558 (0.85/day)
    106
    you can do it the easy and messy way. of just having a 24v dc adapter. or you can do it by making a simple 12v-24v dc-dc converter. for a few £ or you can pay silly money and buy one.
    i think the ddc is a better option than the mcp50x but the mcp50x is a good pump so probably a matter of cost/mounting options.
  2. MT Alex
    MT Alex
    Aug 2, 2009
    3,980 (1.67/day)
    1,790
    http://www.xtremesystems.org/forums/showthread.php?170217-Some-Laing-D5-Testing-13-1-24V-is-the-same
  3. springs113
    May 24, 2007
    735 (0.23/day)
    164
    I would just be using the block from the AIO...after all it is also a standalone from swiftech, not to mention it is their top of the line block now.
  4. Shambles1980
    May 3, 2014
    558 (0.85/day)
    106
    strange these results are different
    [​IMG]
    with up to 16feet at 24v
    aio blocks are probably the weakest part of the link IMO. you will probably upgrade the block after a while though.
  5. MT Alex
    MT Alex
    Aug 2, 2009
    3,980 (1.67/day)
    1,790
    Even if those numbers are accurate, although I would tend to gravitate towards Martin's findings, a stock 35X has a head of 14.7', and the new 50X squirts 15.8. Both of these would make running a D5 at higher voltages pointless.
    MxPhenom 216 says thanks.
  6. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    11,424 (5.73/day)
    3,254
    Seattle, WA
    Pretty sure he is talking about the h220x swiftech aio that just released that comes with Apogee XL block.
    springs113 says thanks.
  7. Shambles1980
    May 3, 2014
    558 (0.85/day)
    106
    i shall consed to that then. so i guess that makes the mcp50x the best pump :)
    i guess thats one way to find the correct answer :)
    oh well that may be different then. but i have not checked out any specs for that.
  8. MxPhenom 216
    Aug 31, 2010
    11,424 (5.73/day)
    3,254
    Seattle, WA
    Uh what? MCP50X is part of Swiftech's DDC pump line up.
    You've made that pretty obvious.
  9. springs113
    May 24, 2007
    735 (0.23/day)
    164
    Not pertaining to the topic...but what kind of paint should i use to paint this thing?
  10. MxPhenom 216
    Aug 31, 2010
    11,424 (5.73/day)
    3,254
    Seattle, WA
    What exactly are you painting and why?
  11. springs113
    May 24, 2007
    735 (0.23/day)
    164
    I want to paint the 750D
  12. MxPhenom 216
    Aug 31, 2010
    11,424 (5.73/day)
    3,254
    Seattle, WA
    That sounds a bit pointless, but id find some place that can powder coat it.
    n0tiert says thanks.
  13. springs113
    May 24, 2007
    735 (0.23/day)
    164
    I like being different
  14. MxPhenom 216
    Aug 31, 2010
    11,424 (5.73/day)
    3,254
    Seattle, WA
    Or at least a place to sand blast the original powder coat off so that whatever primer/paint you decide to use goes on with ease, instead of having to sand and shit. I like starting with bare metal. Pretty much what I did when I tore down the entire interior of a HAF 932 I had, to paint it black.
  15. n0tiert
    n0tiert
    May 1, 2008
    1,000 (0.35/day)
    529
    Frankfurt/Main - Germany
    +1 on Powder coating, you´ll bite ya butt if u mess up the paint job :roll:
    i´ve powder coated my coolermaster cosmos, drilled out all rivets cleaned all parts, drop´d it at the powder coater, paid about 50 bucks and had a kickass result
    just calc the prices for the stuff you need (primer, paint, sanding paper) to get a nice result.
    i cannot tell how this block performs or the quality of the block or the top line block atm, like i said, i always used EK.
    but choosing a block from a 100$ Set if a single block already cost 70$+ with multiple tops, colors, jetplates to choose from....... to build ya rig like u want it too.... :ohwell:
    we can only talk about the experience we made in our projects and just can give guidance..... the willing to take em is up to you.
    :toast:
  16. springs113
    May 24, 2007
    735 (0.23/day)
    164
    Double checking on all the top end blocks, the Swiftech Apogee XL actually beats the Raystorm and EKWB Supremacy by a degree. So the block is definitely no slouch.
  17. MxPhenom 216
    Aug 31, 2010
    11,424 (5.73/day)
    3,254
    Seattle, WA
    That is also within margin of error though too. Tim application/ mounting not consistent or slight change to ambient temps. You can't go wrong with either of the top blocks these days.
  18. springs113
    May 24, 2007
    735 (0.23/day)
    164
    I know and since i already have the Apogee XL i will keep that. I picked up 2 rads today the pump, res some fittings and tubing...I think I am going to keep a single system and return the Gigabyte wifi bk edition mobo. I am going to unscrew the heatsinks colored portion off of my Mpower mobo and paint them white to go with the black and white theme. I don't know If I am going to keep the Seasonic 1200w PSU either. My V1000 is efficient enough to add at least one more oc 780 GTX. I am just worried about my next dual gpu upgrade.
  19. springs113
    May 24, 2007
    735 (0.23/day)
    164
    [​IMG]
    [​IMG]
