weird problem...need help!!!
Discussion in 'General Hardware' started by nolifer112, Feb 1, 2010.
  1. nolifer112
    Aug 27, 2008
    183 (0.05/day)
    2
    so...the problem ocured when I turned on my pc today. Everything seemed fine, windows finished loading, but then BLACK SCREEN and no movement. When I turned on my speakers I could hear programs starting (skype). Right now Im using ASUS Express Gate to get advice from you guys :)
  2. erocker
    erocker Senior Moderator Staff Member
    Jul 19, 2006
    42,315 (10.29/day)
    18,374
    Not having video only in Windows means it's probablly a driver problem. During startup, hit F8 and boot into safemode. Uninstall your drivers, run driver sweeper, etc.
    nolifer112 says thanks.
    10 Year Member at TPU
  3. nolifer112
    Aug 27, 2008
    183 (0.05/day)
    2
    yeah, when I wrote this thread I thought of safemode coz it cant be caused by hardware when Im running Express Gate with no problems ;) ...good advice btw. sounds reasonable in theory, but lets see if it helps!
  4. nolifer112
    Aug 27, 2008
    183 (0.05/day)
    2
    unfortunately the problem isn\t over jet. In safe mode I uninstalled ati display drivers and finnaly got in to windows, but when I downloaded and installed newest drivers, restarted my pc...and then it started loading win xp, but after that black screen again.
    Options...
    1.my computer saves ccc settings that new installation uses. for example my display outputs are swapped maybe...
    2.broken videocard...
  5. Thrackan
    Thrackan
    Oct 10, 2008
    3,471 (1.05/day)
    656
    Uninstall ATI drivers
    Run drivercleaner, driversweeper or whatever to get all the schmuck off
    Reinstall drivers
  6. r9
    r9
    Jul 28, 2008
    2,522 (0.75/day)
    514
    Do you have connected anything else besides the monitor ? It is possible that when the driver load the display output is transfered to second display port.
  7. nolifer112
    Aug 27, 2008
    183 (0.05/day)
    2
    no...only one display connected and I tried both DVIs...same thing with both of them!
  8. Indra EMC
    Indra EMC
    Feb 2, 2010
    170 (0.06/day)
    20
    Nagoya Hills
    Your Videocard wasn't broken, it's because you can still using Express Gate from your Post Screen (If your VGA are broken, it will not even post)
    Try to use Safe Mode first, or using "Enable 640 x 480 Resolution" option.
    if that's doesn't work, try to safe mode, uninstall your Videocard driver, try to boot normally and install latest driver for your videocard.
  9. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    46,046 (9.67/day)
    13,702
    Australalalalalaia.
    i've seen this problem before.
    For whatever reason, the drivers are defaulting to a refresh rate the monitor cant handle.
  10. nolifer112
    Aug 27, 2008
    183 (0.05/day)
    2
    so I removed ATI display driver in safemode, then entered windows normally. I could see my desktop alltough the resolutin was too small (witch is because I had no driver, right). Then used driver cleaner to get rid of all ATI drivers,logfiles etc. Installed latest drivers again and after rebooting it did the same thing again. Could it be somekind of virus that takes control over display driver.
  11. Thrackan
    Thrackan
    Oct 10, 2008
    3,471 (1.05/day)
    656
    You could try Mussels' hunch: with the drivers installed, go to safe mode and check the settings in CCC. Adjust anything that looks weird, especially refresh rates and stuff.
  12. heky
    heky
    Sep 9, 2009
    968 (0.33/day)
    173
    Slovenia, Europe
    If the above doesnt work I suggest you save your documents and stuff to a different drive, and re-install the OS. If possible with Win 7.
  13. nolifer112
    Aug 27, 2008
    183 (0.05/day)
    2
    in my experience you cant start catalyst control center in safe mode, so there is no way to change the refresh rate.
  14. Mussels
    Oct 6, 2004
    46,046 (9.67/day)
    13,702
    Australalalalalaia.
    you can change it through windows settings, and it tends to stick when you reboot.
  15. nolifer112
    Aug 27, 2008
    183 (0.05/day)
    2
    so far none of the above has worked, so I was thinking of installing xp and leaving my filesystem. That way I can copy my files to external hdd and afterwards I\ll maybe even get myself win7.:)
  16. heky
    heky
    Sep 9, 2009
    968 (0.33/day)
    173
    Slovenia, Europe
    You can copy your files to an external hdd in safe mode now, and format the drive and do a clean install.
  17. nolifer112
    Aug 27, 2008
    183 (0.05/day)
    2
    didn\t think of that..thanks. saves me some time .
  18. heky
    heky
    Sep 9, 2009
    968 (0.33/day)
    173
    Slovenia, Europe
    Glad i can help.:toast:
