Weird TASK Manager Problem, help pls
Discussion in 'General Hardware' started by jonathan1107, Feb 15, 2013.
  1. jonathan1107
    jonathan1107
    Dec 30, 2010
    1,129 (0.66/day)
    41
    Canada
    Hi, I just started playing Far Cry 3 today, and noticed that I have a Weird issue since I installed Assassin's creed 3...
    When I installed AC3 and started playing I was having FPS drops to 30fps (from 60fps), and so the only I could get rid of those "hiccups" was to set AC3 to run with "real time priority" in the task manager (in windows 7)...
    Now I'm playing Far Cry 3, and I also have to set it to "real time" priority, otherwise I get the choppiness again... wtf ?!
    I've never had to do this before with other game titles... I also noticed my CPU temps are a tad bit higher than before (idling at 44-46c, used to idle at 35-39)
  2. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    21,596 (6.05/day)
    7,496
    Sounds like something in the background is sucking up your CPU power. You can try using Process Explorer to try and pinpoint it.
  3. jonathan1107
    jonathan1107
    Dec 30, 2010
    1,129 (0.66/day)
    41
    Canada
    I installed Process Explorer, what must I look for ??? (within the Process Explorer program)
  4. pdimar1
    pdimar1
    Jan 12, 2013
    80 (0.08/day)
    38
    you could check the process tab (ctrl,alt,del) and see what programs are using up memory, that usually slows stuff down if i have a problem like this
  5. jonathan1107
    jonathan1107
    Dec 30, 2010
    1,129 (0.66/day)
    41
    Canada
    I don't have programs eatin my memory up... my system just becomes annoyingly Choppy when I run games (since Assassin's creed 3)
    I can fix this by setting the game's process to High or Real time priority in the task manager... But it's weird that with a beast PC like mine I need to do this ...
  6. TRWOV
    TRWOV
    Aug 11, 2011
    4,113 (2.78/day)
    2,843
    Mexico
    Crunching for Team TPU
  7. jonathan1107
    jonathan1107
    Dec 30, 2010
    1,129 (0.66/day)
    41
    Canada
    That still doesn't explain why every other game I'm playin lately get choppy like crazy to the point I have to raise the Game's Process Priority in task manager to get it to be fluid again...
    something's off... wish I knew what is
Share This Page
