What Can Thermaltake Do For You?
Discussion in 'Thermaltake' started by Tt Enthusiasts, Aug 2, 2011.
  1. dank1983man420
    dank1983man420
    Apr 22, 2008
    515 (0.20/day)
    200
    Near Chicago, IL
    Hi
    I have a VF7001BNS htpc case and was wondering if there was anyway to have the lcd power off when the computer goes off. I can control the lcd fine when the computer is on, but the light always turns on when i shut down the pc. It does say the time which is cool, but it is too bright.
    If it is not possible to do this, then I was wondering what is the life of the lcd screen if it is on 24/7. I tried to google this and got nothing good. Thanks in advance
  2. Tt Enthusiasts
    Tt Enthusiasts Thermaltake Rep
    Jul 13, 2011
    284 (0.21/day)
    263
    Lemme look into this... im not 100% sure if it can be or not.
    dank1983man420 says thanks.
  3. Tt Enthusiasts
    Jul 13, 2011
    284 (0.21/day)
    263
    The functional lifespan of the LCD is stated to be in excess of 100,000 hrs
    so I would say you should have a good life out of it as the LCD should far exceed the warranty or life of the case :toast:
    sorry for the delay in response it took some digging to find.
  4. dank1983man420
    dank1983man420
    Apr 22, 2008
    515 (0.20/day)
    200
    Near Chicago, IL
    Awesome, thanks a bunch for finding that out for me!! Love the case other than the lcd being too bright when the computer is off but I think I can get used to it. The only other thing I can think of would be including a memory card reader, but I did a 5 minute mod of buying a cheap one on ebay and sticky taping it under the case so it blends right in.
  5. Tt Enthusiasts
    Jul 13, 2011
    284 (0.21/day)
    263
    lol, were always looking to change things but the design of the case was to mimic other home theater appliances which have active display when powered down.
    I will look into option for manually disabling display as an option in future designs though. Thank you for that idea.
  6. m4gicfour
    m4gicfour
    May 21, 2008
    871 (0.34/day)
    328
    One thing I thought of:
    How plausible would it be to produce a fan controller with a programmable fan curve? Let me explain:
    Most fan controllers are either: 1. Manual, rheobus type or 2. Auto/Manual - where a RPM is set, and a temperature is set. Fan runs at manual settings or if on auto mode, runs at set RPM until tempurature exceeds set threshold, at which point, fan runs at 100%.
    What I'm thinking of is a multi-channel fan controller which behaves like the fan controller in a graphics card, whereby fan speed is gradually increased in proportion to temperature rather than an all or nothing approach.
    Ideally such a device would be a 5.25" bay-mounted device, with temperature probes for each channel, and connected to an internal motherboard USB header for programming functions, with fan control knobs which are retractable (Such as Scythe Kama Panel 3 knobs). Ideally, again, when a given fan knob is retracted, that channel follows the programmed curve, and when extended, that channel is in manual control via the knob. Or, same thing having retractable knobs , however the manual/auto mode being controlled by a seperate button per channel rather than the knob's retraction state. (knob for manual setting, and button to switch between manual/auto per channel) It should be a high-wattage device capable of supplying at least 30W per channel simultaneously on at least two out of the total number of channels, the remainder being 5-10W or better.
    The software for such a device should function similar to BAGZZlash's excellent RBE (Radeon BIOS Editor)'s own fan control interface.
    [​IMG]
    The software should be neccesary only for adjusting settings and programming the device, the device should otherwise be completly stand-alone (software, or indeed the computer itself apart from power supply does not need to be running for device to function completely)
    Such a device would be the ultimate fan controller. It would obviously be expensive, but fan controllers in excess of $100 are already produced and sold. I currently have a Lamptron Touch, and for such a high-end device it still uses the all-or-nothing approach, resulting in a leafblower sounding computer every so often. The main issue there is the sharp change in volume from the set default fan speed and 100% is very noticeable, where as on a fan curve, it may have never needed to get to 100% to keep the device cool.
    What do you think? Is it plausible, and do you think it would be saleable at the price that Tt would need to charge for it?
  7. Tt Enthusiasts
    Jul 13, 2011
    284 (0.21/day)
    263
    This is a cool idea. Thank you very much for offering it. Let me see what I can come up with.
  8. m4gicfour
    m4gicfour
    May 21, 2008
    871 (0.34/day)
    328
    It would definitely be my next Tt purchase if you can make it happen :toast:
  9. Tt Enthusiasts
    Jul 13, 2011
    284 (0.21/day)
    263
    haha, well I will do what I can ;)
  10. FreedomEclipse
    FreedomEclipse ~Technological Technocrat~
    Apr 20, 2007
    14,393 (4.91/day)
    2,618
    As an Enthusiast. One thing i would like more of is self contained watercooling loops/units but for GPU's
    ATi experimented in the earlier days with the exact thing on their X1900XTX toxic edition cards. but my understanding is that idea was scrapped due to the 'development' or further development of vapour chamber and heatpipe cooling.
    COOLIT came out with a product called the O.M.N.I but they only support a very select few of older generation highend cards. There has been no news if COOLIT are going to release a new more universal cooler which could possibly well mean that the O.M.N.I series has been benched so they can focus more on the CPU side of the market.
    Had they made the O.M.N.I more Universal instead of making it for highend cards only, then maybe the unit might have gotten a better reception and still be popular even now.
    Obviously, a self contained waterloop for GPUs would still be no match for a fully customisable water loop. but given the price, and if it cools decently. Im sure there will be huge revenue to be made.
    I run a dual 6970 setup, the cards are still running with the stock coolers and i have refrained from overclocking as not only do these cards sound like a boeing 747 on takeoff but they also run tremendously hot for my liking.
    In Badcompany 2, Playing 1 round of Atacama Desert can see temps hit as high as 88'c
    If you would be able to offer a self contained waterloop that cools better and a lot more quieter, then stock cooling, then I will start saving my pennies and wait eagerly for its release.
    In short....
    carry on when COOLIT left off.
  11. _JP_
    _JP_
    Apr 16, 2010
    2,684 (1.46/day)
    740
    Portugal
    Thermaltake already did that. See this.
    But I think a newer model for recent cards is a good idea too.
  12. FreedomEclipse
    Apr 20, 2007
    14,393 (4.91/day)
    2,618
    that might have been good in 2005, but this is 2011. graphics cards run a lot lot hotter and secondly I dont even think that tidewater fits many 'recent' and cool them competantly let alone be available to purchase.
    I would think you'd be pretty lucky to find one for second hand even.
    Im talking about a cooler that can cool todays graphics cards. not Legacy cards.
  13. _JP_
    _JP_
    Apr 16, 2010
    2,684 (1.46/day)
    740
    Portugal
    I listed an example of what Themaltake had already done. Of course that won't cool recent cards, didn't I made that clear in my reply? :confused:
    I can find one new for 81€. :laugh:
    Not worth it, I think, because I don't have a card to go with it, but that's why I said, a new model for recent cards is a good idea.
  14. Tt Enthusiasts
    Jul 13, 2011
    284 (0.21/day)
    263
    wow thats a lil blast from the past there.
    could be an interesting concept and could be an option let me see what I can do.
  15. FreedomEclipse
    Apr 20, 2007
    14,393 (4.91/day)
    2,618
    I was gonna suggest making it customisable. so we can add something like an Aquabay M1 to the mix but then i remembered that, that would defeat the whole idea of making it 'self-contained'
  16. Bo$$
    Bo$$ Lab Extraordinaire
    May 7, 2009
    5,400 (2.47/day)
    885
    London, UK
    well if they used standard hose and parts, more advanced users would have the option of expanding their cooling system.
  17. AsRock
    AsRock TPU addict
    Jun 23, 2007
    11,675 (4.07/day)
    2,016
    US
    Thanks i got the part 2 days ago..
    Just a thought i would like to see a more advanced fan controller kinda like what Zalman do but if it could have ways to check the power usage of not just the whole system.
  18. FreedomEclipse
    Apr 20, 2007
    14,393 (4.91/day)
    2,618
    then you might as well go build your own waterloop.
    Id build a dedicated 240mm loop for my 6970s but the problem is. blocks for those cards cost £80 EACH as much as i strive for high performance and low tempertures £160 just for blocks is a little excessive. throw in the rest of the other gear, piping, rad, pump, fans & other attachments/fixings and reservoir as optional and youre looking at at least £300 for a kit
    you could just buy a cheap 240mm kit then just add waterblocks to that i guess but it would still work out around the same price.
    If TT were to come out with a closed water loop to cool 6970s around 70'c load thats still quite a big improvement. and depending on the RRP, it could well be worth buying
    actually here we go....
    XSPC Rasa 750 RS240 = £130
    2x 6970 waterblocks = £160
    Fittings = £10
    Total = £299
  19. m4gicfour
    m4gicfour
    May 21, 2008
    871 (0.34/day)
    328
    That kind of defeats the purpose of self-contained systems. What they could do, is use compression fittings which are fused to the componant (res, block, rad) and have some tamper seal, that way it's essentially leak proof like self contained units, and users can still expand, albeit being limited to the tubing size that Tt uses, and with a modified warranty. That way Tt can still warrant the self contained kit with some certainty, and can warrant an "opened" loop in the same way the components of a custom loop are. That is, provided they don't use any hazardous chemicals in their coolant.
  20. stinger608
    stinger608 Dedicated TPU Cruncher & Folder
    Nov 11, 2008
    7,807 (3.31/day)
    4,815
    Wyoming
    Well I have a ton of Thermaltake products, due to doing reviews for Tt :D Most of them are from several years ago as I have not been doing computer product reviews for about four years now.
    However I have recently purchased a couple of newer Tt products and one is the Armor A30 modular small form factor case. Very awesome case to be honest!! For being a "cube" style gaming case it has tons of features and is very easy to work in/with. Awesome job on designing the enclosure.
    Now the next recent Tt purchase was the e-Sports Challenger Pro keyboard. All in all a very nice keyboard...........However, I feel that the driver has a lot to be desired. It is handy that one can shut the large Tt emblem light off and adjust the light intensity but it is a little annoying that when a person reboots a computer and enters the main GUI all lights go of and it takes 30 seconds or so to load the driver information. Granted the keyboard has onboard memory that has to load (or boot) however that should happen once the computer is booted up. Other than this one minor issue I love the keyboard and how it feels and looks.
    Thermaltake has come a long way in recent years and I for one will be a faithful consumer for as long as I purchase computer products. :toast:
    Crunching for Team TPU 10 Million points folded for TPU
  21. Iceni
    Apr 16, 2011
    510 (0.35/day)
    149
    coventry UK
    One thing I would love to see a company do for the community is a proper heat solution for modern graphics cards.
    Not just a wrap heatsink with modular fans, that can be mounted either side. But also a PCIe extender ribbon cable, And a block to spacer your card away from the motherboard. This would allow someone using crossfire or sli to increase the gap between the cards without having to mod there case too much, and allow a user the space between the cards to boost airflow.
    I'm not suggesting this design. Far from it. I would like heat pipes and fins on the back side, with fan mountings. So heat can be blown upwards away from the card in a tower.
    [​IMG]
    Pcie extenders are cheap but look cheap as well.... there's space for branding and colour on there....
    [​IMG]
    And the last part would be a riser block to get the card away from the motherboard so you can mount the cards above the PCI slots. The block for the backplate is pretty easy, But the support for the weight of the card would require some thinking about.
    [​IMG]
    This image shows the standard motherboard screw layout... between points E and K there is an opportunity to make a screw in bar with a modular plastic design that would hold the weight of the cards, and could probably hold a patent...
    scaminatrix says thanks.
  22. scaminatrix
    scaminatrix
    Mar 1, 2010
    3,579 (1.90/day)
    794
    By the Channel Tunnel, Kent, England
    Someone give this man a cookie!
    I think there's a big market for the PCI-Ex16 extenders , especially if a company started making them look nice (red and black please :p).
    The only thing to worry about with the riser idea is losing output connections on the GPU. The ideal scenario would be someone with a mATX mobo in an ATX case.
    Unless you could fashion a contraption that allows you to fit a GPU into a 5.25" bay...
  23. INSTG8R
    INSTG8R
    Nov 26, 2004
    3,159 (0.83/day)
    631
    Lost in Norway
    I would just like Thermaltake to put out a little bit stronger pump. I am still using my Kandalf L.C.S case because you just cant beat the design that has a 3x120 Rad built into the case.
    I have recently gone Sandy Bridge and while I found a new mounting bracket to continue to use the included block it was not very P67 friendly(H-bracket interfering with the backplate of the CPU) I found the block wasn't that efficient(well I was asking a 3-4 yr. old block to do the job) So I have replaced the block with an AC Kryos(sorry TT you just didn't have anything I was sure would work) I kept the rest of the loop fully intact. But I think the real shortcoming is the pump(honestly the temps between the stock block and the new Kryos are pretty negligible)
    So I have no way to upgrade the loop any further without starting from scratch(again would be an issue with the L.C.S. design) I know you are still using the same pump as far as I can tell. Give it some more horsepower and I would happily buy a new one.
  24. FreedomEclipse
    Apr 20, 2007
    14,393 (4.91/day)
    2,618
    like an Asus XG station but for a 5.25" bay
  25. AlienIsGOD
    AlienIsGOD
    Aug 9, 2008
    3,609 (1.47/day)
    1,679
    Kingston, Ontario Canada
    Just dropped by to say that im very happy with my Tt Black Gaming mouse, it replaced a logitech G5 that was on RMA and i havent stopped using it since. Love the way it handles and all the features, the only thing i could ask for is a forward button on the side to compliment the back button that already exsists. Kudos Tt :D
Share This Page
