What made you go Water Cooling?
Discussion in 'Overclocking & Cooling' started by MxPhenom 216, Oct 8, 2012.
I went to water cooling because....
  1. of its cooling capabilities
    54.8%
  2. it is quieter
    20.4%
  3. it looks BAD ASS
    17.2%
  4. Money isn't an issue for me. Disposable income FTW
    7.5%
  1. cdawall
    cdawall where the hell are my stars
    Jul 23, 2006
    21,710 (6.22/day)
    3,564
    Houston
    Those aren't even loud or 50w fans for that matter 12v*1.9A=22.8w. Get into the 67dBa 255CFM models they pull 3.9A each. You only have the weaker 180CFM models.
  2. Sadasius
    Sadasius New Member
    Apr 6, 2009
    263 (0.11/day)
    140
    Ottawa, Ontario
    cdawall says thanks.
  3. cdawall
    Jul 23, 2006
    21,710 (6.22/day)
    3,564
    Houston
    My mistake I only watched the second video clicked on the link and only saw the smaller one. From the video I assumed especially since it barely gets the rad off of the ground.
    I still find it to be odd that those only push 2.9 inH2O. Must be the design. Makes sense why it doesn't pick the rad all the way off the table and the 3.3A nidec's I have do with the the X-flow version of your rad. (nidec's are 3.5 inH2O static pressure, my delta's are even higher)
  4. Spaceman Spiff
    Spaceman Spiff
    Mar 6, 2007
    644 (0.20/day)
    137
    Oh my. :roll:
    Yes they are loud and definitely push some air, but doesn't all that noise drive you nuts?? Even at low speeds?
  5. cdawall
    Jul 23, 2006
    21,710 (6.22/day)
    3,564
    Houston
    At 5v my Nidecs are silent at 7v they sound like an ultra Kaze at full, at 12v the knock stuff over and echo, at 15.5v they sound like a jet motor.
  6. brandonwh64
    brandonwh64 Addicted to Bacon and StarCrunches!!!
    Sep 6, 2009
    19,227 (8.19/day)
    6,678
    Chatsworth, GA
    LOL nothing like the fan I sent to Dave :)
    [YT]927TEqvthFY#t=24s[/YT]
    vawrvawerawe says thanks.
    Crunching for Team TPU
  7. cdawall
    Jul 23, 2006
    21,710 (6.22/day)
    3,564
    Houston
    I will toss my nidecs at a couple different speeds here in a second 5v, 7v, 12v, and 15.5v
  8. Sadasius
    Sadasius New Member
    Apr 6, 2009
    263 (0.11/day)
    140
    Ottawa, Ontario
    Not really.
    Basically this!
    My fans are PWN fans BUT you cannot simply plug these into your motherboard headers. You have to use the signal wire and RPM wire in the header and the power wires directly to the PSU as there is simply too much power draw and will fry your MoBo.
  9. phanbuey
    phanbuey
    Nov 13, 2007
    5,240 (1.74/day)
    1,002
    Miami
    there is a category that is missing - I did it mostly for space - you can fit a waterblock into any build, and then move the rad somewhere else.
    My itx rig would not be able to be overclocked without a watercooler.
  10. Hood
    Hood
    Sep 25, 2012
    965 (0.78/day)
    321
    Let's not forget the most prevalent reason to water cool - because you cross the invisible line from wannabe to certified 'Enthusiast', and you can go on from there to become an overclocker, a gamer, a modder, or whatever blows your dress up. But until you take that first step, and risk shorting out your whole rig by introducing liquid to sensitive electronics, you are a nobody in the artificial universe of PC hobbyists. Hey, I don't make the rules, I'm just sayin'!
    (Disclaimer: this is an attempt at humor; any similarity to actual reality is purely coincidental)
  11. Orthello77 New Member
    Nov 5, 2012
    4 (0.00/day)
    2
    The ability to carry heat. In my case outside the house from inside.
    Silence.
    Better Overclocking potential.
    I bought two 7970 lightnings and i had them air cooled for less than 2 hrs .. the noise and high temperatures up to 95c with moderate overclocking mean't i couldn't stand them air cooled for long. I put ek lightning waterblocks on them , then max core temp was 53c with 32c liquid - that was good to about 1250-1275mhz. Now in the chilled rig with -30c liquid and core temps won't display as they are below zero , at 1400mhz now. So yeah i love H20 - with methanol and antifreeze ;-)
  12. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    Well so far im loving water cooling! After a few days, realized made a bad move on rad, buying a thicker double pass 240 in a few weeks. Most likely the Alphacool UT60 240.
  13. cdawall
    Jul 23, 2006
    21,710 (6.22/day)
    3,564
    Houston
    Get actual high static pressure fans and it will work great.
    MT Alex says thanks.
  14. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    My Black Ice rad?
    No, I already dont like it because its loud. A lot of air noise.
  15. cdawall
    Jul 23, 2006
    21,710 (6.22/day)
    3,564
    Houston
    Massive 3K ultra kaze fans :laugh: and heaphones. If you have some crappy fans and room look into making a shroud it will improve performance and drop the noise a little.
  16. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    I don't even have room for that. And Ultra Kaze fans suck TBH. And I have San Ace 120x38mm fans, but they won't fit, and I dont like them. Corsair SP fans are fine.
  17. Orthello77 New Member
    Nov 5, 2012
    4 (0.00/day)
    2
    Personally the Scyth slipstream 1900s push a lot of air for moderate / low noise. If you are after fans that can really ramp up if needed , hard to go past them.
    I have used scyth ultra kazes , great pressure fans for extreme perfomance but yeah .. at 37 db .. they are not at all quiet , 130 cfm though with static pressure. The Slipstreams are rated 110 cfm at 31 db i think ...
  18. cdawall
    Jul 23, 2006
    21,710 (6.22/day)
    3,564
    Houston
    Out of curiosity whats wrong with the ultra kaze fans? I have used them in a couple of builds now only issue I have had with them is they tick undervolted. Good CFM/static pressure (8.2mmH2O vs the 1.29 or 3.1mmH2O depending on the Corsair SP model)
  19. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    I wont buy Scythe Slipstream or Ultra Kazes. My friends have had them, and they undervolt horribly, and really aren't built well, and run Sleeve bearings. No thanks.
  20. cdawall
    Jul 23, 2006
    21,710 (6.22/day)
    3,564
    Houston
    They are nidec built fans same as the Gentle Typhoons. Not poorly built just don't like undervolting as is the normal with a lot of those fans. Heck my Nidec's barely run at 5v the Delta's wont even start until 7v.
  21. MT Alex
    MT Alex
    Aug 2, 2009
    3,979 (1.67/day)
    1,789
    Yup, 38mm fans are the way to go. All the hype over 25mm "specialized" fans is just that, hype. That being said, I got rid of 3 Ultra Kaze fans because they were too damn loud;):laugh:
    High quality 38mms will beat a 25mm every time, in both noise and pressure. Perhaps a lot of that is because they were engineered for REAL industrial purposes, with enthusiast cooling just being an afterthought.
    MxPhenom 216 says thanks.
  22. radrok
    radrok
    Oct 26, 2011
    3,098 (1.97/day)
    850
    I honestly can't bear more noise than what a Nidec 1850 RPM produces, they are outright perfect in balance between noise/performance, I've tried lots of other fans but they are too much noisy for my taste and quieter fans don't perform as well.
    I'd love to try some San Ace / Delta fans for the lulz tho, can't find em here in Europe btw
  23. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    I would probably slap these San Ace fans on, but my CPU heatsink is in the way. Can only fit the Corsairs for now.
    Yeah Nidec, but sleeve bearings, and click when undervolting, and I HATE THAT SHIT. Clicking fans get thrown out the window.
  24. cdawall
    Jul 23, 2006
    21,710 (6.22/day)
    3,564
    Houston
    I think you sent me those Ultra Kaze's :laugh: Even at full tilt they are quieter than my Nidec's at 7v (as could be seen in the above video)
    They don't click until you break under 7v and I can live with that. As for the sleeve bearing part MTBF is still 30K hours.
  25. vawrvawerawe
    Nov 11, 2012
    619 (0.52/day)
    34
    Thanks for the thread. This resolves my wondering.
