Whereabouts do we order NZXT parts?
Discussion in 'NZXT' started by FordGT90Concept, Oct 7, 2013.
  1. FordGT90Concept
    FordGT90Concept "I go fast!1!11!1!"
    Oct 13, 2008
    17,989 (6.39/day)
    7,264
    IA, USA
    I think the power switch on my Zero 2 case is shorting, getting stuck, or just plain failing (open case ID: LOY-213-85168). Where/how can I order a replacement part for it?
    Also NZXT Support is having major technical difficulties.
    Crunching for Team TPU
  2. xD3aDPooLx
    xD3aDPooLx NZXT Rep
    May 18, 2012
    192 (0.13/day)
    77
    So Cal
    Yes we are having some Technical issues right now. How ever I will with you VIA PM about your issue.
    FordGT90Concept says thanks.
  3. FordGT90Concept
    Oct 13, 2008
    17,989 (6.39/day)
    7,264
    IA, USA
    Just wanted to say the replacement power and reset switches appears to have did the charm. The problem was that the computer would restart itself after being shutdown and it hasn't exhibited that behavior since I replaced the switches.
  4. xD3aDPooLx
    xD3aDPooLx NZXT Rep
    May 18, 2012
    192 (0.13/day)
    77
    So Cal
    Im glad it worked for you. Thanks for the update.
