Which power supply, best for 8800ultra?
Discussion in 'Graphics Cards' started by mrsemi, Oct 28, 2007.
  1. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    My power supply on my 2nd machine which I'll be putting brand new components into is dying. I can put my power supply in the 2nd machine or chose another supply for the 2nd machine only which will be almost identical to my current specs with a 2600pro instead.
    I'm using this currently and it's getting the job done just fine.
    http://www.newegg.com/product/product.asp?item=N82E16817182030
    I can get this for $50 free shipping and it's 650 w but wondering if it'd be better.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817171014&Tpk=N82E16817171014
    If you have some recommendations on good other supplies I'd be open to hear them. The problem I have is the only real reason to upgrade is if I chose to sli, which will require me to purchase 1000w plus power supply and I just can't justify it right now so I really only need a psu good enough to handle a 650i ultra, 2600pro 2 gig ram, and e4300.
    You guys rock.
  2. Namslas90 New Member
    Aug 27, 2006
    4,851 (1.54/day)
    555
    Earth
    Some things to keep in mind;
    Electronics are not "IDEAL". IF you get a PSU with the exact wattage you "need" then you will probably end up having to replace more than just the PSU, soon.
    PSU's are the heart of your system, if your heart is always beating as fast as possable (to keep up with the demand) it won't last very long. The harder the PSU works the more heat it generates.
    A PSU that supplies more power than you need works less hard and last longer.
    Always pay attention to the power requirements of the GPU (in amps).
    When Buying a NEW PSU, get the BEST, QUALITY PSU you can afford with MORE power than you "need". This allows room for future upgrades, and will give you better overclocks, smoother operation, and the PSU will last longer because it's not working so hard to supply the draw of your system.
    :toast:
    mrsemi says thanks.
  3. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    I'm hearing you but psu's are always a gamble, some have a better grasp on their internal workings than others but I do not, so while I'm confident my psu will run my 2nd machine fine, what I'm not sure of is if the antec link I posted would be a better psu than the rosewill I'm using.
  4. panchoman
    panchoman Sold my stars!
    Jul 16, 2007
    9,595 (3.38/day)
    1,200
    see the psu guide in my sig if you want some good psu brands. i'd say a 750 should be good for an ultra and a quad core.
    mrsemi says thanks.
  5. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    I've seen your guide before, may I have your opinion on the two?
  6. niko084
    niko084
    Dec 5, 2006
    7,636 (2.50/day)
    729
    That cooler master may run the system, but I wouldn't dream of trying it...
    And honestly your current psu doesn't look great either, but if its working, I would save the money and get something bigger later because odds are you are pushing that one pretty well, especially with the overclock.
    mrsemi says thanks.
  7. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    Hmm. Ok, bang for buck psu that would protect my system?
  8. newconroer
    newconroer
    Jun 20, 2007
    3,344 (1.17/day)
    396
    mrsemi says thanks.
  9. Dia01
    Dia01
    Sep 14, 2006
    517 (0.16/day)
    63
    QLD, Australia
    If you're considering spending your money on an 8800 Ultra why wouldn'y provide your system with a decent PSU?
    mrsemi says thanks.
  10. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.79/day)
    3,778
    Those actually get great reviews from JonnyGuru. Seem to be quality psus.
    Might I also suggest looking a Seasonic, Corsair, and PCP&C psus.
  11. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    I own an 8800 ultra, but i'm considering another psu.
  12. niko084
    niko084
    Dec 5, 2006
    7,636 (2.50/day)
    729
    Welcome to Corsair made by Seasonic...
    Those rails are already combined inside that psu, so it may as well be a single rail :)
  13. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    Alright alright, I did own a better psu and I did own a gtx, but shit blew up and I'm just trying to get back right. Any other suggestions?
  14. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.79/day)
    3,778
  15. keakar
    keakar
    Mar 27, 2007
    2,523 (0.86/day)
    346
    just outside of new orleans
  16. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
  17. panchoman
    Jul 16, 2007
    9,595 (3.38/day)
    1,200
    mrsemi says thanks.
  18. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    It's red... Lol. Yick, I'd be forced to buy a 2900xt.
  19. keakar
    keakar
    Mar 27, 2007
    2,523 (0.86/day)
    346
    nice choice, and yes its a little big for your system as it is now so ask yourself this...
    i assume you were thinking of getting it as a starting point to upgrade your whole system, so ask yourself, by the time you finish will you have enough leftover parts to build another computer? if your answer is yes then just go for a decent psu around 600 watts to get you going now. then plan to sell your whole system as is and use that money to pay for your new system and start planning a whole new system from scratch.
    mrsemi says thanks.
  20. panchoman
    Jul 16, 2007
    9,595 (3.38/day)
    1,200
    but keaker, the less of the psu's capacity that you use, the cooler the psu will run,
    (meaning the more watts it can do as well) so if he wants to get a nice big psu, i dont mind, it'll keep his system cool and upgrade ready.
  21. Chewy
    Chewy New Member
    Jul 9, 2006
    3,289 (1.03/day)
    148
    Halifax, Canada
    you can get it in black too.. thats the one I would like :).
  22. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    Yeah, I have enough parts for a 2nd system now, considering selling it and investing in an sli mobo and using some of my current parts for another build later on. No rush right now though, just want some rock solid parts. I picked up a q6600 today and the only thing I can think of wanting at this point is water cooling.
  23. keakar
    keakar
    Mar 27, 2007
    2,523 (0.86/day)
    346
    yes that is totally correct if he was keeping this computer, but he will be replacing his system in the near future so my thinking was "if" he had a major upgrade in mind in the near future then dont look to "spend" on the old system he will be getting rid of and instead invest the money into the "new" build.
    it was to buy only for the necessary cost of getting his system running and not thinking of keeping it long term. so thats where i was coming from with the thinking of just getting an exact replacement for the dead psu.
  24. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
    Thanks again oh wise posters, I initially asked for input and then ignored the input I requested. The above psu is the one I just ordered as my failed logic got me a dud psu.
    Newegg is starting to get on the suspicious side imo. The supply I bought (900w itz abs) had almost all bad reviews and they yanked it off newegg. So I was watching the reviews on their other products and the bad remarks are mysteriously vanishing, almost all their products have straight 5 eggs. So much for trusting customer feedback there.
  25. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.79/day)
    3,778
    You should never trust Newegg reviews anyway. Whether or not they pull the bad ones. 90% of the people that post a review are morons.
Share This Page
