White LED fans. HELP!
690 (0.11/day)
System Name Pegasus
Processor AMD Ryzen Threadripper 1950X @ 4GHz
Motherboard ASUS ROG Zenith Extreme
Cooling Custom 480mm EK Loop
Memory 4 x 8GB G.Skill TridentZ RGB 3000MHz @ 3000MHz
Video Card(s) ASUS ROG Nvidia GTX 1080 Ti
Storage Samsung 960 EVO M.2 500GB / Samsung 850 EVO 500GB / Samsung 840 EVO 250GB
Display(s) 2 x 25" Dell Ultrasharp U2515H / 1 x 15" ASUS MB169+
Case Corsair 900D
Audio Device(s) 2 x Tannoy Reveal 502 / Beyerdynamic DT 990 PRO 250 Ohm / Behringer Xenyx X1204 USB / MXL 770
Power Supply EVGA SuperNova G3 1000W
Keyboard HyperX Alloy FPS / Corsair K95 RGB / Anne Pro 2 / 2 x Elgato Stream Deck
Software Windows 10 Professional 64-Bit
sneekypeet
Retired Super Moderator
29,409 (4.46/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Both fan choices are a bit low on the CFM end of things. What sort of radiator are these fans going onto, and if possible do you know the FPI, if not I can go look it up.
77 (0.02/day)
Its a Black Ice 360 radiator
N-Gen I was looking at those but Ive read some awful reviews about manufacturing flaws. (unbalanced/ clicking motors/ect)
Edit: I think i found a yate loon thats white. D12SL-12
Also, looks like Xigmatek fans are free after rebate at newegg right now.. But the one on my Dark Knight can be louder than my 470 ref. fan =\ and one per person
sneekypeet
29,409 (4.46/day)
System Name EVA-01
That rad is ~20FPI. For good results I would be looking for 80CFM+ fans. The real issue at this point is getting fans with enough static pressure, CFM, and has white LEDs. I am off to look at Frozen to see what they have.
the54thvoid
Intoxicated Moderator
12,458 (2.38/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
What model? Black Ice can be SR or GT Stealth or GTX or whatever, each is different. SR can use lower cfm fans as it has fewer fpi and the others with higher fin density need more oomph.
690 (0.11/day)
System Name Pegasus
Case Corsair 900D
That's the actual only white LED fan I could find from my little search. Maybe buy LED clear Yate Loons and change the LEDs?
77 (0.02/day)
I'm not too sure which model, it should be here soon enough and I'll take some pictures.
I really appreciate the help guys :) This is my 1st venture into water cooling and I'm trying not to muck it up
N-Gen: I found some white led Yate Loons 2 minutes after i posted this. =\
690 (0.11/day)
System Name Pegasus
Case Corsair 900D
I knew I've seen them somewhere, I just thought it was my brain messing up at that moment though. I think the only one that comes in white is the D12SL-12 though? It wouldn't be enough.
de.das.dude
Pro Indian Modder
8,783 (1.73/day)
Stuck in a PC. halp.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
get other color and take out the blue LED and replace with white?
i notice this can be done with the :EF fan on my Corsair GS600.
690 (0.11/day)
System Name Pegasus
Case Corsair 900D
You'd want at least the D12SM-12, preferabbly the D12SH-12 versions.
494 (0.10/day)
Hesperus IV
System Name Salvaged
Processor AMD Phenom II X6, 1055T
Motherboard MSI (cant remember model..)
Cooling Antec Kühler + extra fans (Antec, Zalman, Coolermaster, Generic brand)
Memory 8Gb (2 x 4Gb)
Video Card(s) ATI Radeon HD6870
Storage Samsung 1TB, 320 Seagate, 250 Samsung
Display(s) LG Electronics
Case ANTEC Sonata III 500 (found/salvaged + modified)
Audio Device(s) 8Ch + Harman Kardon 2.1 (modified, electronics in JVC wood speakers)
Power Supply It's made in Denmark, never seen a PSU made there..
Software Win7 X64 Ultimate
Howabout going this way (the hard way?): Get the fan that you want, get a LED list, with flat LED lights on it, drill small holes on the fan 'casing', glue the LED list on to the fan's outer 'casing' - make sure the LED's have their own source of power, power them up - voilà (LED's go on top of the holes - shines thru).
You now have the correct fans, with the lights (LED) that you wanted. I do not know about prices and such, I think it varies from country to country. But at our electrical shop, they can get their hands on most LED lists, ranging from being 12v powered or from the mains.
Athlon2K15
HyperVtX™
7,909 (1.23/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
77 (0.02/day)
By "flat LEDs" Do you mean surface mount? Either way that's probably entirely too much work haha
Yeah I have one of those on my CPU cooler. It looks pretty but its really loud =\
sneekypeet
29,409 (4.46/day)
System Name EVA-01
refer to post #5. 20fpi means you are going to need 2.0 mmH2) or better static pressure and around 80-90 CFM to get good results with that rad.
749 (0.14/day)
Netherlands
System Name gaming system
Processor 2600k @ 4.2 ghz
Motherboard MSI Z77 MPower
Cooling Thermalright ultra extreme 120 rev.C w/noctua NF-S12B push/pull
Memory 16gb corsair vengeance 2400 c11 @1.5 v/
Video Card(s) GB gtx670 WF3x sli @1080/1372/6660(core/boost/mem)
Storage 2x samsung 850evo 250gb raid 0 ,2tb wdblack, 3TB wd purple
Display(s) Samsung Syncmaster P2770FH, asus VH242t/19" lg 1440x900
Case fractal design r4
Power Supply Corsair HX1050
Mouse Razer abyssus
Keyboard corsair k70
Software Windows 10 pro x64
Fan controller mate!
Get a nzxt sentry 2 nice 5channel 10w each fan controller with touchscreen
Maybe some noise blocker fans
494 (0.10/day)
Hesperus IV
Well, yeah.. Something similar to this:
Not as thick, but similar.
3,527 (0.71/day)
Netherlands
System Name desktop | Odroid N2+ |
Processor AMD Ryzen 5 3600 | Amlogic S922X |
Motherboard Gigabyte B550M DS3H |Odroid N2+ |
Cooling Inter-Tech Argus SU-200, 3x Arctic P12 case fans | stock heatsink + fan |
Memory Gskill Aegis DDR4 32GB | 4 GB DDR4 |
Video Card(s) Sapphire Pulse RX 6600 (8GB) | Arm Mali G52 |
Storage SK Hynix SSD 240GB, Samsung 840 EVO 250 GB, Toshiba DT01ACA100 1T | Samsung 850 Evo 500GB |
Display(s) AOC G2260VWQ6 | LG 24MT57D |
Case Asus Prime 201 | Stock case (black version) |
Audio Device(s) integrated
Power Supply BeQuiet! Pure Power 11 400W | 12v barrel jack |
Mouse Logitech G500 |Steelseries Rival 300
Keyboard Qpad MK-50 (Cherry MX brown)| Blaze Keyboard
Software Windows 10, Various Linux distros | Gentoo Linux
Here in the NL they go for like 18-25 EUR per piece, so that is out of range, according to the OP.
77 (0.02/day)
So I;m guessing theres nothing that really fits my "criteria" then?
sneekypeet
29,409 (4.46/day)
System Name EVA-01
Either that or you are going to have a loop that under performs, and whats the point in spending all that money to get the results of a high dollar air cooler?
My suggestion would be to buy fans that fit the air flow and static pressure needs. If you want lights there are CCFLs, and strips of LEDs I'm sure you could mod into the case and get a similar effect.
