Will running my Corsair dominators without the cooling fans be dangerous???
Discussion in 'Motherboards & Memory' started by ChaoticAtmosphere, Apr 6, 2009.
  1. ChaoticAtmosphere
    ChaoticAtmosphere
    Oct 27, 2008
    2,215 (0.96/day)
    1,606
    Look up. Look way up.
    I Have a paired set of 2x2Gb Corsair Dominators DDR2 PC2-8500 running in my rig at 480Mhz 5-5-5-18-2T unganged each.
    They came with active cooling fans and I recently got an RMA for the fans because they make noise in colder temperatures, an annoying buzzing sound.
    I was just wondering if it would be safe to run them with my games at their current clock speeds (no stress testing) while I await the new set of fans??
    Any opinions? :)
  2. crtecha
    crtecha New Member
    Dec 8, 2008
    2,407 (1.06/day)
    207
    ipsay meechigan
    get a cheapo thermometer and see what the temps are at idle
    ChaoticAtmosphere says thanks.
  3. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.22/day)
    1,748
    Nevada
    as long as you dont overvolt the memory a lot it will be fine.
  4. nafets New Member
    Jul 26, 2008
    611 (0.25/day)
    133
    Obviously they're designed to operate just fine without the fans.
    When you're going for very tight timings or very high frequencies (or both), that's when the lower temps the fans provide, will come into play.
  5. Wrigleyvillain
    Wrigleyvillain PTFO or GTFO
    Oct 13, 2007
    7,684 (2.85/day)
    1,779
    Chicago
    Yeah you'll be fine. How high can you get them? Still testing but just got a pair of those and so far running at 564 (1128) 5-5-5-18 PL6 with only 2.2v. Average 9600 read. Not bad sticks.
  6. h3llb3nd4
    h3llb3nd4 New Member
    Feb 15, 2009
    3,323 (1.50/day)
    307
    Durban, South Africa
    it would be fine... I'm running mine @ 500mhz and without any fans cooling them. though they are @ 1.8v
  7. ChaoticAtmosphere
    ChaoticAtmosphere
    Oct 27, 2008
    2,215 (0.96/day)
    1,606
    Yeah, for some reason I can only get them to 480 (960) @ 5-5-5-18. Any higher I become unstable but I think that is more due to my Mobo or CPU. My CPU won't allow me past 260fsb or 14.5x multi. But at the current settings they're still good sticks!!
  8. ChaoticAtmosphere
    ChaoticAtmosphere
    Oct 27, 2008
    2,215 (0.96/day)
    1,606
    I think I got mine @ 1.9 or 2....I'd have to check my bios to be sure! Thanks bud!
  9. mlee49
    mlee49
    Dec 27, 2007
    8,499 (3.24/day)
    2,107
    Now their fine, they have decent heatspreders on them anyway you'll be golden.
    The fan is nice but a bit loud as 3x5krpm fans whirl up quickly, I about lost a finger once!
  10. ChaoticAtmosphere
    ChaoticAtmosphere
    Oct 27, 2008
    2,215 (0.96/day)
    1,606
    :roll:
  11. TricksterMatt
    TricksterMatt
    Mar 21, 2009
    262 (0.12/day)
    3
    Dominators FTW, and running without the cooling fans are fine just as long as you dont go berserk with them and start modding them to a bitch
  12. ChaoticAtmosphere
    ChaoticAtmosphere
    Oct 27, 2008
    2,215 (0.96/day)
    1,606
    Yeah, I'm really happy with them....they are the first paired hi performance sticks I've owned so I don't have any experience with any other brands. So far i'd go corsair again because RMA for the fans was a breeze and their customer service is the bomb!! :rockout:
  13. 3dsage
    3dsage New Member
    Nov 8, 2008
    1,797 (0.78/day)
    330
    NW Burbs of Chicago
    Those heatsinks are solid on these sticks man:D
    I picked some Dominators over the weekend 2x1GB 1066, this sticks running @800 4-4-4-10-11 1T 2.2V havent tweaked them much but they are running tight timings ATM:toast:
    SonDa5 says thanks.
  14. ChaoticAtmosphere
    ChaoticAtmosphere
    Oct 27, 2008
    2,215 (0.96/day)
    1,606
    Nice!! And if you run into any problems with them you can count on awesome customer service from them...at least IMO and from my experience. :)
  15. mlee49
    mlee49
    Dec 27, 2007
    8,499 (3.24/day)
    2,107
  16. SonDa5
    SonDa5
    Aug 3, 2008
    1,645 (0.68/day)
    344
    The Dominator PC8500 2x2GB sticks were unstable in my MB. DFI P45 JR T2RS
    I think the fan is there because of how hot they get. Might be safe to under clock your RAM some while you wait for the fan replacement.
  17. hat
    hat Enthusiast
    Nov 20, 2006
    17,159 (5.67/day)
    2,180
    Ohio
    you'll be fine, I run my memory at 2.2v with no cooling at all. no heatsinks, no fans, nada.
  18. SonDa5
    SonDa5
    Aug 3, 2008
    1,645 (0.68/day)
    344
    What ratio and FSB speed?
    You shouldn't have to run these sticks@ 2.2v @ stock FSB speeds.
    2.2 volts will generate heat and if you can run your RAM at lower voltage your system will be more stable. Unless of course your RAM will not boot up at your FSB speed settings.
  19. SonDa5
    SonDa5
    Aug 3, 2008
    1,645 (0.68/day)
    344
    I'll add that your system specs board shows that you are running Geil RAM.
    I'm running Patriot Vipers right now because I couldn't get my Dominator PC8500 2x2GB sticks from crashing when gaming.
  20. ChaoticAtmosphere
    ChaoticAtmosphere
    Oct 27, 2008
    2,215 (0.96/day)
    1,606
    Nice!! They're solid, enjoy! Mine are just great.
    And the GT's? http://www.corsair.com/products/dominatorgt/photo3.jpg
    Oh yeah!!:rockout:
    I agree. I'm at 1.9v 960Mhz
    Too bad about the board mate. Keep them though. Test them in another system with another board.
  21. CDdude55
    CDdude55 Crazy 4 TPU!!!
    Jul 12, 2007
    8,179 (2.93/day)
    1,277
    Virginia
    Dominators are awesome, they should stay cool. As said, as long as you don't push em to far.
  22. 3dsage
    3dsage New Member
    Nov 8, 2008
    1,797 (0.78/day)
    330
    NW Burbs of Chicago
  23. LittleLizard
    LittleLizard
    Nov 22, 2008
    3,777 (1.65/day)
    575
    Latin America, Uruguay
    why do you think that they also sell dominators without the fans. they are not strictly required, just a bonus on cooling
  24. ChaoticAtmosphere
    ChaoticAtmosphere
    Oct 27, 2008
    2,215 (0.96/day)
    1,606
    Sweet!! I just bought my rig so by the time I can afford to build another they'll probably be up to DDR4 quad-Channel :eek:
    Well, I think they sell those for the serious gamer who doesn't overclock.
  25. SonDa5
    SonDa5
    Aug 3, 2008
    1,645 (0.68/day)
    344
    They do have great customer service. Too bad the 2x2GB PC28500 didn't work out for my MB.
Share This Page
