Wired / Wireless Problem
Discussion in 'General Hardware' started by HellasVagabond, Jun 5, 2007.
  1. HellasVagabond New Member
    Jan 19, 2007
    3,404 (1.18/day)
    162
    Athens , GREECE
    I dont like wasting anyones time so heres my problem.
    I have a wireless router which i want to connect to my IPTV BOX which i have with my 55 inch LCD. However the IPTV BOX doesnt have a wireless connection and it needs a cable which i cant use since the router is 3 rooms away.
    Any way i can make it work ? I was thinking about an adapter that can go behind the IPTV BOX and make it wireless but i dont know if that exists.
    Ideas guys ?
  2. Jimmy 2004
    Jimmy 2004 New Member
    Jan 15, 2005
    5,491 (1.51/day)
    267
    England
    Where do you live? Sounds like you need a wireless bridge - they're essentially wireless adaptors that plug into a standard network port.
    Here's a couple in the UK:
    http://www.ebuyer.com/UK/product/61885
    http://www.ebuyer.com/UK/product/52459
    I know some brands let you link two separate routers (such as Belkin) but those two devices should do what you want.
    Edit: you could even try powerline adaptors, but I think that would work out slower and more expensive.
    HellasVagabond says thanks.
  3. HellasVagabond New Member
    Jan 19, 2007
    3,404 (1.18/day)
    162
    Athens , GREECE
    Exactly what i need thanks.
    However 60-80euros aint cheap so ill search for something cheaper. Besides its an IPTV BOX so nothing too special as gaming or so.
  4. Namslas90 New Member
    Aug 27, 2006
    4,851 (1.60/day)
    555
    Earth
Share This Page
