Without pci-e power connectivity
Discussion in 'NVIDIA' started by perfectenamy, Jan 22, 2011.
  1. perfectenamy New Member
    Jan 22, 2011
    16 (0.01/day)
    0
    hey guys ....(sorry for my bad englis)
    I have XFX 9800gtx+..so guys please tell me is there any way to know weather my vga card is working or not (at least detect..) without connecting pci-e power to my vga...
    without pci e power.. vga fan spinning 100% speed with red light
  2. Batou1986
    Batou1986
    Oct 2, 2005
    2,837 (0.75/day)
    574
    Baltimore MD
    no it has to have power or it will not even detect it,
    it will also keep the computer from starting if it has no power
    perfectenamy says thanks.
    10 Year Member at TPU
  3. perfectenamy New Member
    Jan 22, 2011
    16 (0.01/day)
    0
    yes i'm using onboard vga...but vga is in pci slot...
  4. mlee49
    mlee49
    Dec 27, 2007
    8,514 (2.87/day)
    2,125
    Kansas City
    It's telling you it's not going to work without the pcie power supply with the fan spinning at 100% and a red light.
    There are some "green" versions of the 9800 that do not require the pcie connector, perhaps that would suit you better?
  5. Swamp Monster
    Swamp Monster
    Oct 22, 2010
    570 (0.29/day)
    88
    Latvia
    Do you mean 6-pin connector? I guess it is not fully working until you plug it in. So you cannot detect if it is working, because it is not, until you plug it in.
  6. perfectenamy New Member
    Jan 22, 2011
    16 (0.01/day)
    0
    ok i'm telling you the actual problem...
    i have seasonic s12 520w psu... when i power up vga with 2 6pin power connectors...my pc wont start. Even the psu is also not working...whole machine not working
  7. Swamp Monster
    Swamp Monster
    Oct 22, 2010
    570 (0.29/day)
    88
    Latvia
    Only not working when you connect 6 pin connectors? By not working you mean PSU fan not spinning? What does it do, Does it spins for a sec, and then turns off or what?
  8. perfectenamy New Member
    Jan 22, 2011
    16 (0.01/day)
    0
    please tell you ideas..where would be the problem..i get that psu brand new..before i had amacroax 500w when i was using it this problem occurred ..so i thougt that problem is in psu and got that seasonic one...but problem is still....
    is my vga dead?
  9. perfectenamy New Member
    Jan 22, 2011
    16 (0.01/day)
    0
    yes it spins for a second..then turn off...vag's green light on and immediatly disappear
    Only not working when i connect 6 pin connectors
  10. Radical_Edward
    Radical_Edward
    Jan 24, 2010
    3,586 (1.62/day)
    1,927
    Oregon, USA
    Sounds like a dead 9800. RMA it if it's still covered.
    Crunching for Team TPU
  11. Swamp Monster
    Swamp Monster
    Oct 22, 2010
    570 (0.29/day)
    88
    Latvia
    It means that Graphics card is consuming too much power, and PSU immediately turns itself off. This can be because of
    your Graphics card is dead, causing short circuit.
  12. perfectenamy New Member
    Jan 22, 2011
    16 (0.01/day)
    0
    if is it short circuit ..is it possible to repair? why is it short circuit?
  13. perfectenamy New Member
    Jan 22, 2011
    16 (0.01/day)
    0
    yes...but i removed the heatsink and cleaned...but nothing happened
  14. Swamp Monster
    Swamp Monster
    Oct 22, 2010
    570 (0.29/day)
    88
    Latvia
    Short circuit can be caused if Voltage regulating Mosfets were overheating and heat destroyed them. To repair you need very good soldering skills, multimeter and replacement mosfets, which can be expensive.
  15. perfectenamy New Member
    Jan 22, 2011
    16 (0.01/day)
    0
    is oven baking thing help for that problem?....
  16. Swamp Monster
    Swamp Monster
    Oct 22, 2010
    570 (0.29/day)
    88
    Latvia
    Oven baking helps only if GPU processor has bad soldering contacts (dry soldering). But in your case current flows uncontrolled thru dead Mosfets. Dead component is dead component, you cannot revive that by reflow techniques.
  17. Radical_Edward
    Radical_Edward
    Jan 24, 2010
    3,586 (1.62/day)
    1,927
    Oregon, USA
    I'm not saying clean it, I'm saying return it for a replacement to XFX IF it's still covered under warranty.
  18. perfectenamy New Member
    Jan 22, 2011
    16 (0.01/day)
    0
    no it is not possible. In sri lanka there is no xfx dealers.. I got it from friend
  19. NdMk2o1o
    NdMk2o1o
    Apr 21, 2010
    3,763 (1.77/day)
    1,153
    Redditch, Worcestershire, England
    225w for a 9800gtx are you for real :rolleyes: a 9800gtx probably consumes 100-120w max
    OP try an 4pin>pcie 6pin adaptor your PSU should handle that system easily
    Swamp Monster says thanks.
  20. Swamp Monster
    Swamp Monster
    Oct 22, 2010
    570 (0.29/day)
    88
    Latvia
    Oh, sh.. I am sorry, I overlooked TPU review, it was all system's power consumption.
  21. segalaw19800
    segalaw19800
    Jan 26, 2010
    383 (0.17/day)
    65
    Lost in space
    I will take that card and put it in a friend rig for testing :toast:
  22. perfectenamy New Member
    Jan 22, 2011
    16 (0.01/day)
    0
    in sri lanka there are very few people are using power hungry cards wich needs goods psu. I dont have a friend with good psu. That is the problem
  23. segalaw19800
    segalaw19800
    Jan 26, 2010
    383 (0.17/day)
    65
    Lost in space
    find a friend who has a psu that is 550watt to try it with :respect:
  24. segalaw19800
    segalaw19800
    Jan 26, 2010
    383 (0.17/day)
    65
    Lost in space
    is there a computer shop around there
