Working on a water cooled build, looking for help.
Discussion in 'Overclocking & Cooling' started by Tabbywabby, Mar 29, 2012.
  1. Tabbywabby New Member
    Mar 28, 2012
    7 (0.01/day)
    0
    Hello,
    My current build consists of,
    Antec DF-85
    Asrock Z68 Extreme 3 Gen 3
    Intel i5-2500k @ 4ghz (I want higher)
    16 Gbs of DDR3 1600
    250 GB Sata3 hardrive
    60 GB SSD for cacheing with the Z68
    I only have the stock cooler for the cpu in anticipation for water cooling.
    Sapphire Radeon 6950 Dirt 3 edition
    So what i have is all found on frozencpu.com. This is a all inclusive cooling system where AESTHETICS MATTER! I want as much to be red as possible. I am a noob at moding and especially liquid cooling, i have read multiple guides for it but i always feel like i missed something, here what i have so far.
    Magicool Extreme Dual 140mm Radiator - Slim Profile (MC-RADI280)
    Select G 1/4" Fittings (Qty. 2): 3/8" ID Barb ($5.98)
    EK Supreme LTX CPU Liquid Cooling Block - Electroless Nickel Plated (EK-Supreme LTX - EN (Nickel))
    Select G 1/4" Fittings (Qty. 2): 3/8" ID Barb - Black ($6.50)
    EK VGA Supreme HF -Bridge Edition- Universal High Performance VGA Cooling Block - Acrylic (EK-VGA Supreme HF Bridge Edition)
    Feser Tube Active UV Hose - 3/8" ID (1/2"OD) Anti-Kink Tubing - UV Red
    Bitspower Galaxy Freezer Universal RAM Module Liquid Cooling Block - 4-DIMMs - Ice Red (BP-RAMS44-IRDBK)
    Steel Spring Hose Clamp for 1/2" OD Tubing - Black
    Enzotech BCC9 Memory Ramsinks - 8 Pack (BMR-C1L)
    Danger Den Monsoon "Premium" D5 / MCP655 Dual Bay Reservoir - Black / Black Face / Red Trim / Red LEDs (RES-304) - New Revision!!
    Swiftech MCP655-B ($89.95)
    PrimoChill Anti-Kink Coils - 1/2 OD" Tubing - UV Red
    Again i have no other parts, so whats there is all i will get. Am i missing something? I am slightly confused how to get MOSFET heatsinks for my VGA.
    Also if i can get kinda the same look with somewhat comparable cooling for less, and you know of these parts, or part stores, where i can get this stuff, i would really appreciate a link.
    Thanks in advance
    Tabby
  2. t_ski
    t_ski Former Staff
    Apr 11, 2006
    11,266 (3.38/day)
    5,035
    Technically, your post should be here:
    http://www.techpowerup.com/forums/forumdisplay.php?f=61
    However, I think you have most of what you need, but I don't see any fans. If you are looking at cooling the CPU and GPU and have a "slim" radiator, you may not get the most cooling available. The ram cooler is probably not necessary, unless your ram is a high-voltage kit that needs it. As for VGA cooling, you can either go with a full coverage block to cool the mosfets, or just buy some Microcool or Enzotech mosfet heatsinks and apply them with frag tape.
    Tabbywabby says thanks.
    Crunching for Team TPU
  3. Tabbywabby New Member
    Mar 28, 2012
    7 (0.01/day)
    0
    Sorry. + Thanks
    It said cooling so i assumed this is where it went. A full cover block does not exist for this card, or at least that i know of. The ram cooler is just mostly for future proofing the system. I do wish i could find some motherboard MOSFET blocks. I have tried coolingconfig but the only recommend a blocks that they do not actually sell. Also if you look at the case could you recommend other radiator placements? I could try to use 2 radiators one dual 140mm and one dual 120mm, however I'm not sure if it will fit in the case correctly. I want this to be entirely contained in the case, i abhor external radiators. However i would make it possible that i could have quick disconnect to an external radiator tower. But i feel as though i am WAYYY over complicating this.
    Thanks,
    Tabby
Share This Page
