Would a water cooling loop fit in an Antec 300
Discussion in 'Cases, Modding & Electronics' started by p_o_s_pc, Dec 8, 2008.
  1. p_o_s_pc
    p_o_s_pc F@H&WCG addict
    May 2, 2007
    13,009 (4.06/day)
    2,183
    Newark ohio
    I have an Antec 300 and i have been looking at some water cooling kits. I am looking at the Swiftech 220 compact and i want to put it in the front of the case if possible without mods if it won't fit there is there any place else i could put it IN THE CASE WITH NO MODS?
    also would the case fit all the water cooling stuff?will be cooling CPU only
    here is a link to the case
    here is a link to the water cooling kit
    Crunching for Team TPU
  2. erocker
    Jul 19, 2006
    41,046 (11.76/day)
    16,143
    The radiator would pretty much have to be external, as you will need room for the pump and resevoir.
  3. p_o_s_pc
    May 2, 2007
    13,009 (4.06/day)
    2,183
    Newark ohio
    the rad and res are in one and the CPU block and pump are together
  4. cdawall
    cdawall where the hell are my stars
    Jul 23, 2006
    21,664 (6.21/day)
    3,538
    Houston
    unless you knock out the drive bays it wont fit
    you could skip the kit and do dual 120mm rads one in the back adn one at the top of the case
  5. Paulieg
    Paulieg The Mad Moderator Staff Member
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    Wherever I can find the iron.
    I had the 120 version of that kit. I can't see a way to mount the 240 rad/res inside the case w/o a mod.
  6. p_o_s_pc
    May 2, 2007
    13,009 (4.06/day)
    2,183
    Newark ohio
    the top of the case is 140mm but not a bad idea. maybe i will just put teh rad on the back of the case if i get it
  7. erocker
    Jul 19, 2006
    41,046 (11.76/day)
    16,143
    You could just get a radbox for the back to mount the radiator to.
    p_o_s_pc says thanks.
  8. cdawall
    Jul 23, 2006
    21,664 (6.21/day)
    3,538
    Houston
  9. p_o_s_pc
    May 2, 2007
    13,009 (4.06/day)
    2,183
    Newark ohio
    thanks cdawalll but i would like to get a kit that or atleast get e everything in one place and but <$150
  10. cdawall
    Jul 23, 2006
    21,664 (6.21/day)
    3,538
    Houston
    than wait for petra's to get 120mm rads back in stock and order it all there
  11. p_o_s_pc
    May 2, 2007
    13,009 (4.06/day)
    2,183
    Newark ohio
    did they have the 140mm rads there?
  12. Paulieg
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
  13. p_o_s_pc
    May 2, 2007
    13,009 (4.06/day)
    2,183
    Newark ohio
  14. Monkeywoman New Member
    Jan 2, 2008
    157 (0.05/day)
    7
    Ottawa, Ontario, Canada
  15. Binge
    Binge Overclocking Surrealism
    Sep 15, 2008
    6,981 (2.58/day)
    1,753
    PA, USA
  16. p_o_s_pc
    May 2, 2007
    13,009 (4.06/day)
    2,183
    Newark ohio
    thanks. could you please tell me or link me to the adapter for AMD
