Would adding silver heat compound help my stock cooler? X1800GTO
Discussion in 'Graphics Cards' started by JC316, Aug 26, 2006.
  1. JC316
    JC316 Knows what makes you tick
    Jan 24, 2006
    9,364 (2.74/day)
    914
    Title says it all. I was going to get aftermarket cooling, but I have since seen that it dosen't make a whole lot of difference, espically since I am constantly running 100% with my stock fan. I have an 8,000 RPM hard drive that sounds like a v-tec with 20LBS of boost and a fart pipe, so I really don't care about noise.
    I just bought some silver compound for my other computer and I was wondering if it would help my X1800. Thanks.
  2. Corrosion
    Corrosion New Member
    Feb 27, 2006
    821 (0.24/day)
    74
    Maplewood, Mn
    i think it might bring you down maybe 3 - 4C idle and ??? load
  3. BigD6997
    BigD6997 New Member
    Sep 20, 2005
    891 (0.25/day)
    9
    it will help but only by a few degrees (worth it imo since its easy)
    get poge or infared (there modding service) to lap it for you, that combo of AC5 and a nice lap will drop the temp a good amount
  4. JC316
    Jan 24, 2006
    9,364 (2.74/day)
    914
    Alright, thats what I figured. I will give it a shot. One more thing, what do I do about the memory? Are the heat pads reusable? Thanks
Share This Page
