alexp999
Staff
- Jul 28, 2007
- 8,012 (1.32/day)
- Dorset, UK
System Name | Gaming Rig | Uni Laptop |
Processor | Intel Q6600 G0 (2007) @ 3.6Ghz @ 1.45625v (LLC) / 4 GHz Bench @ 1.63v | AMD Turion 64 X2 TL-62 2 GHz |
Motherboard | ASUS P5Q Deluxe (Intel P45) | HP 6715b |
Cooling | Xigmatek Dark Knight w/AC MX2 ~ Case Fans: 2 x 180mm + 1 x 120mm Silverstone Fans |
Memory | 4GB OCZ Platinum PC2-8000 @ 1000Mhz 5-5-5-15 2.1v | 2 x 1GB DDR2 667 MHz |
Video Card(s) | XFX GTX 285 1GB, Modded FTW BIOS @ 725/1512/1350 w/Accelero Xtreme GTX 280 + Scythe sinks| ATI X1250 |
Storage | 2x WD6400AAKS 1 TB Raid 0, 140GB Raid 1 & 80GB Maxtor Basics External HDD (storage) | 160GB 2.5" |
Display(s) | Samsung SyncMaster SM2433BW @ 1920 x 1200 via DVI-D | 15.4" WSXGA+ (1680 x 1050 resolution) |
Case | Silverstone Fortress FT01B-W ~ Logitech G15 R1 / Microsoft Laser Mouse 6000 |
Audio Device(s) | Soundmax AD2000BX Onboard Sound, via Logitech X-230 2.1 | ADI SoundMAX HD Audio |
Power Supply | Corsair TX650W | HP 90W |
Software | Windows 7 Ultimate Build 7100 x64 | Windows 7 Ultimate Build 7100 x64 |
Benchmark Scores | 3DM06: 19519, Vantage: P16170 ~ Win7: -CPU 7.5 -MEM 7.5 -AERO 7.9 -GFX 6.0 -HDD 6.0 |
UPDATE:
Okay, I've just come to doing this, but There is one screw I cant get out. have tried loads of different screwdrivers, it wont budge.
And the more i try the worse the bore is getting.
Any ideas.
__________________
As title says. i want to see if I can get my temps even lower without buying an aftermarket cooler.
Only thing I'm worried about is the ram chips. Am I right in thinking they use pads?
I take it I cant replace that with tim cus it wont make contact?
Are they reusable? Or should/can I pickup replacements? or maybe better ones?
Any ideas.
__________________
