X-Fi + I/O Panel + Optical Audio Cable +Receiver's SubWoofer = 2.0 output not 2.1
Discussion in 'General Hardware' started by EastCoasthandle, Jun 14, 2008.
  1. EastCoasthandle
    EastCoasthandle New Member
    Apr 21, 2005
    6,889 (1.87/day)
    1,506
    Hello,
    How do you enable your receiver's sub woofer if you are using your X-Fi's I/O Panel to output sound using Optical Audio Cable? I have tried adjusting few settings found within the X-Fi control panel but nothing has worked so far. I wasn't able to successfully google an answer to this as of yet. Any help is appreciated.
  2. imperialreign
    imperialreign New Member
    Jul 19, 2007
    7,043 (2.46/day)
    909
    Sector ZZ₉ Plural Z Alpha
    I'm not sure how much help I can be as I've never used optical connections - but, just to make sure, you do have the I/O panel plugged into power, and your subwoofers power is on, right?
  3. btarunr
    29,733 (10.68/day)
    14,195
    It boils down to the AC-3 filter, nothing really to do with the card or its driver, once you set the speaker out as "2/2.1 speakers"
    Here's a shot of the drop-down list of the speaker modes available at the AC-3 filter. x.1 is x + woofer.
    [​IMG]
    EastCoasthandle says thanks.
  4. EastCoasthandle
    Apr 21, 2005
    6,889 (1.87/day)
    1,506
    Correct
  5. EastCoasthandle
    Apr 21, 2005
    6,889 (1.87/day)
    1,506
    Maybe I need to download this program? :eek:
    Thanks!
    Do I need to do anything special? This will be the 1st time I use this program.
  6. btarunr
    29,733 (10.68/day)
    14,195
    Google for "K-Lite Codec Pack". It packs a lot of goodies.
  7. EastCoasthandle
    Apr 21, 2005
    6,889 (1.87/day)
    1,506
    oh snap it works! I even get 5.1 through Dobly ProLogicl II! Thanks a bunch! That's all I really needed.
  8. EastCoasthandle
    Apr 21, 2005
    6,889 (1.87/day)
    1,506
    It's mind boggling why a program similar to this isn't included with X-Fi installer to allow users to use their receiver if they so choose.
  9. btarunr
    29,733 (10.68/day)
    14,195
    Because the best brains (like Daniel Kamakawi and Alexander Vigovsky) aren't snobbish MIT graduates that usually make it to companies like Creative or <insert greedy company here>. Diamonds are sometimes found in Coal mines.
  10. EastCoasthandle
    Apr 21, 2005
    6,889 (1.87/day)
    1,506
    this is true, yet tragic of how resources like that are not used properly.
  11. imperialreign
    Jul 19, 2007
    7,043 (2.46/day)
    909
    very true . . . but, then again, in the majority of hardware areas, it's 3rd party independant users who tend to come up with the most useful ideas and software
    nice to see you got your setup working, sorry I couldn't help much further - had to fix a coolant leak on my car. :ohwell:
  12. EastCoasthandle
    Apr 21, 2005
    6,889 (1.87/day)
    1,506
    Don't worry about it :toast:
Share This Page
